penguin45
Still welding......
Sept 28, 2019 17:09:29 GMT
Greetings,
I'm trying to find a silencer box where the inlet and outlet pipes are at the same end. The only thing I'm finding at the moment is the C1/Aygo/107 back box, which might be a trifle small.
Any pointers towards similar style silencers would be gratefully received. There's no need for exact dimensions - whatever happens I'll finish up breaking out the magic sparkie machine to adapt it for my purposes.
Cheers,
Chris, P45.
Midas
Club RR Member Number: 14
Sept 28, 2019 17:56:26 GMT
MGF back box? If you are going to modify it anyway one of the outlets would need to be blocked off.
Sept 28, 2019 18:25:48 GMT
you could use two old motorbike end cans or two cherry bombs on a 180 degree bend
Last Edit: Sept 28, 2019 18:29:33 GMT by dickie12
Sept 28, 2019 18:44:05 GMT
Daewoo Matiz, not sure on the pipe sizes but I have a new one somewhere!
Club RR Member Number: 160
Sept 28, 2019 18:46:46 GMT
You could use a Vauxhall Omega silencer with the single inlet blanked and the twin tailpipes as in-out. I used one similarly to make a twin exit exhaust for a Mazda 323F once.
Sept 28, 2019 20:09:31 GMT
Lots of Mercs have that setup. W124 and w210 both do.
Phil H
Club RR Member Number: 133
Sept 28, 2019 20:23:57 GMT
Mk1 Mondeo has them on some versions - think the 2.0 and V6?
Darkspeed
Club RR Member Number: 39
Sept 28, 2019 20:39:02 GMT
I think the Dolomite Sprint exhaust did that twice!
Last Edit: Sept 28, 2019 20:40:37 GMT by Darkspeed
penguin45
Still welding......
Sept 30, 2019 12:38:34 GMT
Nice one, chaps. Had completely forgotten the Triumph one, Mondeo looks interesting.
Cheers,
Chris.
Sept 30, 2019 17:59:50 GMT
FN/FK civics have one, quite large pipes, though its quite sizeable.
Sept 30, 2019 18:28:21 GMT
I think the Dolomite Sprint exhaust did that twice! Stole my line! But yes, that's the one that came straight to my mind. It's far from a cheap exhaust system in that format, which is why many are on sports systems.
