1947 ford ranger...Dez
@dez
Club Retro Rides Member 34
Next I cleaned everything up, straightened any bent bits, and started on welding the stress cracks up, and tacking the inner panel back together. The best thing about this is the edges fit back together perfectly, so they’re easy to fit together and act as a good reference for pulling things back to shape. A bit of hammer work and some more welding and grinding, and it’s all back together. You can see the three remaining holes are where the rivets on the hinge are meant to go, although they are rather chewed. As I’m not going to de-skin the door to redo the hot rivets for the hinge, I’m just going to weld the hinge to the re-enforcing plate. But to do that I need to use that bit I cut out as reference, as the aforementioned holes are a bit baggy. With that dropped into place and the gaps set where I cut it, i can weld one side of the hinge on. Then the outer skin was welded back in, and spot welded through to the rear-enforcer where it was originally. Then I neglected to take any more pics, but I cut some infill panels for the remaining big bits of missing outer skin, ground everything up and chucked some paint that’s a similar colour over it. I need to revisit that inner corner edge but I need some different tooling to work around the rivet heads before I do. I’m tempted to weather that paint down a bit then leave it at that so it looks like an old repair, rather than attempting to totally hide it, as the outer skin will always be a bit damaged around the hinge. For the minute it just means the door can be hung properly.
Last Edit: Feb 2, 2020 20:13:39 GMT by Dez
So, trying. To be organised, I did a list. By no means comprehensive or in any kind of order for that matter ether, but it is sort of the next ‘batch’ of things that need doing, and gives me something to be going at in between other stuff. So what did you do after lunch?
The hinge itself is bent (using the other door for reference) so that went in the vice and got some BFH til it was straight again. This has to be my favourite phrase of the year so far.
@dez
This is the last bit of welding I had to do on the cab before I can paint the bottom side and refit it to the chassis. It’s the recess for the removable trans tunnel on the firewall and toeboard area. It doesn’t seem I’ve mentioned it and I can’t find any pics, but after I dropped the cab down onto the chassis by putting the prop tunnel in, I also had to raise up the top of the actual trans tunnel panel for it to work. To do this I split it in half horizontally and added a 4” strip all the way round so it was tall enough to cover the ranger gearbox. If you scroll back to where i finished up the firewall once the cab was removed, I’d already finished this recess on the back edge where it met the tunnel. I could have just hacked the lot out and added a big conical tunnel like I would on most builds where cost is a consideration (I.e. a customer wants to spend a couple hundred on a new tunnel, not a couple of grand!) but as this is mine and cost of labour isn’t a consideration, I wanted to go all out and make it look to the uninitiated like it could be stock, hence reworking the stock panel and recess. Adding 4” of height meant this panel now met the firewall 4’ further up too, above where I’d had to notch it out for the bellhousing area of the gearbox. and was longer so had to be extended forward. I’d done most of that previously but didn’t take any pics it seems. Mostly cos it was an awful job to do I guess. This was the tunnel panel after extending, and the firewall/toeboard area cut back to where the two would now meet. You can see the back end still has traces of black paint, that’s the original panel, all the front bit in front of where the old shifter hole is panelled in is new. The smaller hole on the right is for the handbrake. Here at the front is where I will be working. You can see the bit that bolts down onto the floor has a slight flange to the edge which sits in a recess, which is what I’m trying to emulate. First job is to determine the profile of the original recess, and make up a few straight lengths of it for the 3 long sides. Here it is, I beadrolled the step then tweaked the angles a bit in the vice after as I didn’t have dies that were exactly right. Then I did the return on the edge in the brake. I put the top section in first so I could then add some extra screws for the trans tunnel to hold it solid in relation to everything else. That stiffened things up a lot, so then I did the slightly easier drivers side. Slightly easier as the floor was flatter, and it was a continuation of the existing recess so I had something to work to. Then the slightly trickier passenger side. On this side I cut all the old swage out and straightened the line of it up, I’ll tweak the tunnel panel so the edge on that is straighter afterwards. Then some grinding, on both sides. This is with the removable panel fitted, and one of the only half decent pics of it. Lots of construction lines are still evident on the bottom side, which show how I split it to extend it. It also shows the two tricky corners that are left to do. I did the drivers corner first as again it was easier, but still rather difficult given as well as the actual shape of the recess and the return, the panel curved around between the firewall and the toeboard too. I didn’t actually take any in progress pics as I was too busy concentrating on the work, but I used a similar method of bead roller first, it then I hand tipped and hammer/dolly formed the flange after. Mucho grinding back both sides and it looks like this. The other side was even trickier, and I’ve had to reshape a big area of lower firewall to give me room to get the panels to curve rather than meet at sharp edges. I fitted in this little corner piece first, which adds strength to the corner to allow me to work it all a lot more with the hammer, and also shows the corner on the firewall behind stick out too far, it’s already over the panel. So I radiused that corner back a lot to allow me bring it back earlier. I then formed a new corner that I let in, which I then tipped the edge on so it reverse-curved to the recessed area. Again I'm scant on pics, but once welded up and roughly ground, it looks like this- It needs revisiting before paint for a little more finish grinding, but I’m pretty happy with that so far, and it’s an awful job I didn’t want to do ticked off!
Last Edit: Feb 9, 2020 10:18:51 GMT by Dez
@dez
These two pics are the only ones I can find that show what that area looked like as stock- And what the tunnel panel looked like before modification, and how the holes had to be cut out bigger at the front and back for the ranger gearbox-
That came out really nice.
This build just keeps getting better...
@dez
Feb 27, 2020 22:26:55 GMT
Well, I’d not done much on this for a few weeks as I was feeling a bit burned out on it, plus it was costing me lots of monies buying everything it needed. A couple of weeks off from it whilst I worked on other things and I feel ready to get back to it now. In that time this turned up. These switches are amazing. Such a good design. Another car I’m wiring at the moment came in with one on and after rewiring it knew it was the one I needed for this. Quite why it comes with a technical drawing of the actual switch but no wiring instructions is anyone’s guess though! It’s a Cole Hersee 75228-03 wiper switch. It’s two speed with dynamic parking and a electric push-for-wash function. American made and pretty good quality. Only came to just over £25 as well. What it means is I can fit a generic Lucas 2 speed wiper motor and spindle boxes as came fitted to loads of stuff, and it’ll all work correctly and park as it should. The knob is just on a grub screw onto a flat on the shaft so is easily changed for something more appropriate looking. So, feeling bouyed on by that, I decided next job would be to refit the fuel lines and do the brake lines before the body went back on. The fuel lines were in good order, kinda as you’d expect from coated hardlines that have only carried diesel, so were just cleaned and were ready to go back on. All the clips were removed and scrubbed as clean as I could get them too- This showed up a couple of the steel brackets were well gammy. The top two will reuse now they’re wire wheeled up, it I’ll have to do something about them bottom two. First one squashed flat to act as a template. They’re only 1.6mm so easy to fab. Some cutting and drilling- Just like that- Other one was a little trickier to do the bend on but not terrible really. I then chucked some paint on em and they’ll be ready to fit tomorrow once it’s dry. Just waiting for brake hoses to turn up as well then I can do the rear axle lines and main run down the chassis. They’re just replicating the stock stuff so pretty easy. At the front the tabs for the flexis have been moved from the body onto the chassis, plus the master cyl has changed sides, so a little more thought will be required there.
Last Edit: Feb 27, 2020 22:29:12 GMT by Dez
@dez
Well with the brackets painted and fitted I decided to do the main brake line from front to rear. This is a bit of a monster, it requires nearly 15 feet of pipe. I’m using kunifer, not worth using anything else to save literally pennies. It wiggles around a lot so the installed length is about 12 feet. I used the old crusty steel one as a template. It starts at this bracket that attaches to the front suspension crossmember and takes a body-to-chassis flexi hose. Well engineered! It then hugs the chassis rail and steps up to meet the same clips as the fuel pipes where it goes under the cab. It then mirrors the fuel pipes down as far back as the tank, using the same clips again. Behind that it goes out on its own to the back of the tank- Here it deviates from the norm as I'm relocating the brake flexi slighlty. I’ve run it back to the new extra crossmember I’ve put in then along the bottom of it to come at the flexi from the other side. The reason I’m relocating the flexi is to stop any pull or collision of the ends if I end up bagging the truck. Obviously there will be a larger range of movement so I need to make sure the brake hose isn’t limiting it. It’s a minor change to make now but will hopefully save any issues in the future. Instead of mounting on the other crossmember near the tank, it’s going to go here. The axle end is as per stock, as is the hose. You can see there I’ve actually already welded it on. I touched in the paint and left to dry to dry overnight before finishing the brake line. Here it is done and the line finished off. I added some extra clips and coppergreased all the screws and that’s about it. I didn’t bother putting the original clip holes back in after I repaired this area as all the origiinal plastic clips broke during removal, so I’ve just used stainless rubber lined p-clips and tek screws instead. I then made the longer of the two axle lines, again rerouted slightly to try to accommodate future plans. Again more stainless crews and p-clips were used to attached to the original brackets. I only made the longer one as I didn’t have enough kunifer left to do the short one. A new roll is ordered so I’ll finish that when it turns up.
Lovely neat work as per,Dez.
@dez
Well Seeing as I can’t finish the brake pipes yet, and I’m waiting for parts for the other two cars I’m doing, I decided to move on to the next bit. I decided that would be finishing off the little bits on the bed so it can go for blasting and paint. First I trimmed out the cutouts in the return flange so they don’t catch on the bed supports as it’s slid on. That was just some grinderage and filing. Then I decided I needed to do the bolt holes to mount the bed infill panel thingies that don’t really do anything. Marked out for some holes- Drilled em- Then clamped them to the return lip, marked through the holes, unclamped them, drilled the return lip then bolted em up. So that’s them fitted up. Next I had to bolt up the rear valance too. This just drills and taps through into the rear bed frame drop panel, as it’s 3mm thick. I marked out the holes on the valance so they were all evenly spaced and pilot drilled it. Then It was clamped up and drilled through, then tapped to m6. The holes in the valance were opened up to clearance then it was bolted up. I ran out of bolts though so need to get some more, ideally shorter. So that’s that lot ready to blast and paint I think.
@dez
Mar 30, 2020 18:37:13 GMT
Crawling along, but progress is progress. This battery clamp turned up from the states, correct one from the original ‘47 truck tray I had blasted and painted, so I can now order a battery and mount the tray. When bashing about finishing the floor there was a lot of stuff falling out of the bottom of the drivers A pillar. Unfortunately some pinholes then appeared too, so I opened it up to sort that lot out. As you can see it was entirely hard-packed with Arizona dust, which I think was adding structural integrity to the rather thin overlying metal! The then picked apart the inner arch bit that needed replacing too. This lead to finding the closing panel on the inside also ideally needed replacing. It was holed in the middle but a larger area was also heavily pitted. That was also removed. Then replicated in the appropriate gauge steel, swages and everything. I also replaced the little return lip at the bottom that the outer attaches to as it was frilly.
Last Edit: Mar 30, 2020 18:38:45 GMT by Dez
Mar 30, 2020 18:57:56 GMT
nasty case of "grinders cuff" there!
I love seeing this project come together...great work!
JP
Did you clean back the surface rust before you welded that in or just put more heat through it? Truck is coming along well.
@dez
nasty case of "grinders cuff" there! All my clothes are ruined. You should see the pocket area of all my hoodies!
@dez
Did you clean back the surface rust before you welded that in or just put more heat through it? Truck is coming along well. It was cleaned back. It’s actually cleaner than the pics make it look, the camera highlights it. A lot of what appears to be surface rust is actually dried dust as well.
jamesd1972
Club RR Member Number: 40
1947 ford ranger...jamesd1972
@jamesd1972
Club Retro Rides Member 40
nasty case of "grinders cuff" there! All my clothes are ruined. You should see the pocket area of all my hoodies! Yeah been there ! Once managed to set fire to the 'pocket area' of my jeans. The nice warm feeling was soon replaced by mild panic ! Nice work & updates - thanks for sharing. James
@dez
Mar 31, 2020 18:36:55 GMT
All my clothes are ruined. You should see the pocket area of all my hoodies! Yeah been there ! Once managed to set fire to the 'pocket area' of my jeans. The nice warm feeling was soon replaced by mild panic ! Nice work & updates - thanks for sharing. James I’ve recently gone from cheapy screwfix work trousers to carhartt double fronted ones as they’re much less flammable!
@dez
Mar 31, 2020 18:48:22 GMT
So, inner skin done, time to sort that outer. It looks quite simple but there’s some deceptively subtle shapes going on, plus experience told me that given the original shape it was going to heat pop when welded, so that would dictate what order I needed to do things in. So, I’d do the most visible outer side first so I could still get in to dolly it after welding and grinding before closing the cavity in. First bit made. It has a very subtle curved bend along its full length plus the tipped edges. Trimmed and stuck in, then ground back and tapped straight, as it did pop exactly as I predicted. You can almost see the curved bend here that effectively makes the panel a concave curve. Then I beat out a curved panel to fill the remaining hole. As this was quite curved it was much more ‘stable’ when being welded so I didn’t have to worry about it moving much. Neglected to take any more pics til it was welded in and flapped back. Some primer on it shows the shapes better. You can also see the very bottom edge wraps round bottom bottom of the panel behind, so had to be dollied over and trimmed once fitted. But that’s that, 2 steps forward and one back as I didn’t even think I needed to do it, but progress is progress. Also kinda good that I could do it in the position it’s in with the cab flipped on its back, as it would have been much worse to do with the cab on the chassis.
Last Edit: Mar 31, 2020 18:51:44 GMT by Dez
