scimjim
Club RR Member Number: 8
Rover T series will bolt up to the LT77/R380 IIRC? 200BHP in turbo form and allegedly limited to protect the gearbox?
I think a n/a version found its way into one model of Discovery?
glenanderson
Club RR Member Number: 64
You need a Sherpa flywheel housing (flywheel and starter too I think), from a van with a Perkins Prima engine and LT77 gearbox, to bolt a T16 straight to a Land-Rover gearbox. Not impossible to find, but getting thin on the ground. Obviously you can fabricate something, but the "bolt on" solution is pretty rare. I looked into it when plotting what I could replace the engine in my P4 Rover, and even 12 years ago things were getting hard to find at reasonable prices.
madmog
Club RR Member Number: 46
Not sure if it's why the originator of the question asked but if you live around London , older diesel of any sort in commercials are pretty much a no go now, I suspect there are many people who will need to go petrol or sell the vehicle. OP has a '74 so I _think_ will be exempt as a classic. You can check here. www.ulezchecker.com/I'm wondering how cheap diesels on Autotrader will become as owners inside the N & South Circular roads start having to pay.
Last Edit: Dec 9, 2019 19:18:26 GMT by madmog
Pinto onto the standard l/r box has been done a few times so the info should be out there, in which case a Zetec should also bolt up to whatever plate you use.
I always kicked myself for not fitting a V8 in my series, as it would have been just as economical as the 2.25 diesel and I could have fitted LPG.
Feb 28, 2021 13:25:00 GMT
If going for a petrol four-banger, I guess you'd want a lot of low-down torque; maybe the 2.5-litre Porsche 924S engine would be quite good, with 150bhp and 143lb/ft @ 3,000 rpm, quite an increase on Land Rover's 2.5 litre petrol engine which gave 83bhp @ 4,200 rpm and 133 lb/ft @ 2,000 rpm, then there's also a Subaru 'EJ' 2.5-litre flat four as used in Forresters, which gives around 173bhp @ 6,000 rpm and 170 lb/ft @ 3,800 rpm, and the 2nd generation Jeep Cherokee (XJ) had a 2.5 litre four-pot, giving 130 bhp @ 5,250 rpm and 149 lb/ft @ 3,250 rpm... I'm also interested in putting a 4 pot petrol in my 1974 series 3 (currently has an 11j diesel in it that you hear before you see it!).
Has anyone done the Porsche 924s swap and what is needed for transmission marrying up?
Last Edit: Feb 28, 2021 20:10:22 GMT by isambard
