jikovron
mechanical chaos
SOLD I've started stripping a 4HU jag diff for its lsd center and the Cwp/ housing are surplus, I hoped to get £60 for the lot as it looks to be in great order with a reasonably good contact pattern. Can post the cwp but the housing is majorly heavy so that would be more a pickup or I can deliver to a reasonable distance of Chesterfield.
Last Edit: May 24, 2020 16:02:24 GMT by jikovron
jikovron
mechanical chaos
I picked up this BL answer to the pinto at the weekend principly for its gearbox, It's the 2 litre triumph slant 4 with its in block waterpump madness, it rotates by hand but has been stood a long time so I've no idea about its internal condition aside from it looking reasonably clean under the cam cover. It has all of the ancilleries still attached, so alternator,startermotor,flywheel and clutch,carbs with complete airbox,dizzy etc I'm hoping for £150 for that.
jikovron
mechanical chaos
I bought these to get my 1.1 alto through an mot, however a cracked engine block and rust put paid to efforts to save it, 1 week used radiator and fan,used alternator, wheel cylinders, one fitted then removed straight away,handbrake cables fitted then removed,lower suspension arm again fitted and removed, wiper blades 1 week old,new window regulator. I can post the lot for £50
jikovron
mechanical chaos
May 24, 2020 15:59:47 GMT
4HU is gone SOLD Also got a Honda gx390 13hp engine, bought as a runner but its shape is no good for the intended project, so I'm looking at other engines. Badly painted but an honest engine with excellent parts backup although it is fully complete. £75, abit too heavy to post really. Also I've got a bare rover v8 4 barrel inlet manifold that I converted from a SU one into a Dual plane holley or edelbrock 500 one It's a 5/8 alloy flange bolted rather than welded to prevent warp and is nicely gas flowed I ran it one an engine briefly and it functioned as intended. £125 plus £10 post.
Last Edit: Aug 11, 2020 14:02:18 GMT by jikovron
jikovron
mechanical chaos
Aug 11, 2020 14:07:42 GMT
Volvo 204bhp 2.9 Na straight 6 I was going to fit this to a dolomite and got as far as starting to adapt the sump with a fabricated flange and remote filter gallery! Head is off as I was going to change all the HG and cambelt etc but all the parts have been kept so is a complete long engine apart from the obvious consumables £40
