Oct 14, 2019 10:08:51 GMT
It's a side valve so performance is subjective! It has other mods as well, all done at the same time so attributing gains to any one thing is impossible. What I can say is that it is very torquey and will run at higher speeds than before the work with a feeling that it is doing it easily, little throttle being required to do so. Before it was hard work above 55ish with foot to the floor! Cruises at 70 nicely now. One thing I did notice was where the hot bit was (you know, the story about paint a white stripe and where the burnt bit ends is the correct length), it's at the end of the manifold. Weird. Hope that helps. Oh, it sounds like a barrel of wasps!!!!
Phil H
Club RR Member Number: 133
Making a tubular manifoldPhil H
@philhoward
Club Retro Rides Member 133
Oct 14, 2019 10:30:21 GMT
A quick google search for Austin 7 race exhausts shows the tubes being probably 4ft long (which is about the only sidevalve I could think of which might have race-spec exhausts for), so it figures..
Oct 14, 2019 10:57:30 GMT
A quick google search for Austin 7 race exhausts shows the tubes being probably 4ft long (which is about the only sidevalve I could think of which might have race-spec exhausts for), so it figures.. Apart from the long, and current, history of racing ford sidevalves? 😉 No idea what they use these days though, i just put an aquaplane on mine.
Oct 14, 2019 10:59:39 GMT
It's a side valve so performance is subjective! It has other mods as well, all done at the same time so attributing gains to any one thing is impossible. What I can say is that it is very torquey and will run at higher speeds than before the work with a feeling that it is doing it easily, little throttle being required to do so. Before it was hard work above 55ish with foot to the floor! Cruises at 70 nicely now. One thing I did notice was where the hot bit was (you know, the story about paint a white stripe and where the burnt bit ends is the correct length), it's at the end of the manifold. Weird. Hope that helps. Oh, it sounds like a barrel of wasps!!!! I'm unfamiliar with the paint stripe thing, ill look it up. I had the same with my ford sidevalve, did eveything at once so hard to pinpoint. They may be a bit agricultural but i really enjoyed squeezing power and economy out of the old sidevalve.
Phil H
@philhoward
Oct 14, 2019 11:18:37 GMT
It was the first one that came to my mind, anyway..mainly because I was surrounded by them at a Hillclimb earlier this year..
Oct 14, 2019 11:27:46 GMT
Ill see if i can find all the relevant details for the calculator and get some results from it. I had a quick look at it but i don't know any of the needed info yet.
Oct 14, 2019 11:57:04 GMT
Appears i cant find any of the cam info i need. Maybe when it comes apart next ill work it out.
