Ritchie
Club RR Member Number: 12
Reusing rod boltsRitchie
@ritchie
Club Retro Rides Member 12
Nov 29, 2019 12:00:48 GMT
Have you contacted ARP Racing bolts? They have a huge range and I would be amazed if they didn't have something suitable. I would be reluctant to re-use due to all of the other work that has gone into the engine.
List of UK dealers here if you click the tabs...
Last Edit: Nov 29, 2019 12:01:42 GMT by Ritchie
Reusing rod boltsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Nov 29, 2019 12:55:26 GMT
Unless they're obviously damaged (heads rounded off normally) or being replaced by performance items I reuse rod bolts in every engine I do (5-10 a week) and not had any issues. On some engines they need measuring to make sure they're not over stretched but never had any that are.
Nov 29, 2019 13:23:37 GMT
If they are not torque to yield (ie torque then angle) and have no signs of necking (bolt shrinking in diameter when stretched, check with micrometer or good quality calipers) they should be fine to re-use.
Nov 29, 2019 14:40:19 GMT
I do have 4 new genuine GM bolts in stock if that helps, I may have others but would need to look, the Lotus Carlton straight 6 24 valve used different bolts to your 12 valve engine
Last Edit: Nov 29, 2019 14:42:09 GMT by gtviva
Nov 29, 2019 15:12:56 GMT
They look like ARP bolts to me, I may have some part numbers for them but what is the dimension from under the head to end of the thread possibly 47mm or 55mm? are you able to work out if the thread is metric or imperial?
Nov 29, 2019 15:13:57 GMT
Have you tried Risse Motorsports in Germany? Mostly all about the 2.0cih engine as I recall but I think they're pretty good with most things Opel. Might be able to supply you or point you to a supplier.
Nov 29, 2019 15:40:43 GMT
Their use of English isnt amazing (and why should it be) but they're very helpful.
Last Edit: Nov 29, 2019 15:51:26 GMT by Deleted
