Here we have my interior which I removed from a ST170 several years ago - kept it incase I ever bought another but with several projects I doubt it will happen.
It can be fitted in any* four door Focus (MK1 or MK1.5), with or without electric rear windows and can be adapted to go into an estate (*rear bench would need spacers making for the latch on the top piece of the rear bench and the rear doors cards will not fit but everything else can go in)
What's included:
• Two front seats, drivers (which has the electric motor to raise and lower) bolster has a small bit of normal wear to it however it didnt get any worse (I treated it every six months) - they have storage Mark's on them right now, they should return back to normal once they're sat on/left to relax.
• Rear bench (with caps and seat belt)
• Four door cards (rears have been drilled to allow for winders to be attached incase you don't have electric rear windows - these can be blanked if not needed)
• Various door furniture including switches
• Leather steering wheel
• Dash trim with boot button (where you have the gauges to the left of the clocks)
• Centre console with infill, leather gear stick gaitor and hand brake gaitor and traction control switch.
• Various bolts etc which were removed from the interior when it was removed.
The interior has been in storage for several years and so needs a good through clean as its covered in dust etc.
I'm located in IG3 area (not far from Ilford)
Any questions please ask.
What's included:
