Jan 17, 2020 13:56:03 GMT
The was working OK up until 30 minutes. I had driven how to walk my dog, did that, started driving back to work. I got 1/2 and it just wouldn't go over 3000rpm and became really sluggish and slow then stopped completely.
I managed to limp to a nearby car park. where it wouldn't really move or go over 1000rpm.
Jan 17, 2020 15:19:25 GMT
So if you dip the clutch, does it still not rev above 1000rpm in neatral? Does it idle ok?
Jan 17, 2020 15:53:56 GMT
Nope, it won't rev higher than 1000rpm, and the idle sounds shocking.
I have a video but I'm unaware of how to add it
Jan 17, 2020 16:28:42 GMT
I've also been on the classic audi forum and they suggested the relay 30
Jan 17, 2020 18:31:27 GMT
What's your rotor arm like? I had a weird issue on my Audi coupe years ago which turned out to be the rotor arm. It had a mechanical rev limiter (a sliding contact on a spring, above certain rpm it would slide and break the contact) and it was causing an intermittent short. Took ages to figure it out, it ended up in an Audi main agent to have a look, and a regional manager happened to notice it and ask what was up. He'd been a mechanic when they were current, and suggested the rotor arm might be at fault.
Jan 17, 2020 22:23:52 GMT
After work I got back to the car and was met by the aa man (who was awesome) he had a good look around the engine bay and checked the oil, which said was really low. I put about 1.2 litres of oil in and fired the car up. He followed me home and the car was fine.
I still have no idea what is causing these sudden random drops in power
Jan 18, 2020 17:35:01 GMT
I checked the relay and couldn’t see any obvious problems
Phil H
Club RR Member Number: 133
Jan 18, 2020 17:42:12 GMT
Don’t certain VAG cars of that period have the oil pressure switch hooked into the ignition system? I vaguely recall someone had a malfunctioning oil pressure light and wierd things ensued. Might have been on a Mk2 Golf or a Polo but it’s a similar vintage..
Jan 18, 2020 17:52:54 GMT
Sorry to sound thick. Could you explain that in a bit more detail?
Phil H
Jan 18, 2020 18:20:11 GMT
It’s a vague recollection of there being possibly two oil pressure switches - one activates the dash lamp and another one at a different pressure is a sort of protection (can’t recall if it affects the ignition or fuel).
VWs aren’t really my thing so it was something I read but didn’t fully retain..
Phil H
Jan 18, 2020 18:22:00 GMT
Jan 19, 2020 17:31:05 GMT
So you’re saying that it’s a possibility that the low oil is causing the car to protect itself by controlling the revs?
Phil H
So you’re saying that it’s a possibility that the low oil is causing the car to protect itself by controlling the revs? 👍
Well this all makes sense. I bought 5 litres of oil and managed to get over 1 litre in it until it was up to the mark on the dip stick. Drove to work today, no smoke no problems.
I must have an oil leak somewhere. The underneath of the car is covered in oil so I will need to give it a clean and see where the oil is coming from.
I do need to find a reasonalby cheap exhaust as this one sounds terrible.
60six
Jan 20, 2020 17:34:32 GMT
The first link I think I bought a complete system from them before - Absolutely fine - assemble / seal with RTV silicon and you will be fine
Jan 21, 2020 15:07:37 GMT
Great stuff. I can order that come pay day. Then my exhaust won't sounds like a teenagers modded corsa
tofufi
South West
Does the car mostly do short journeys?
Mayo in breathers can be caused by short journeys not allowing the car to get up to temperature fully.
I took the air filter apart and there was a piece of plastic floating around loose in there. Not a great start. The more I took apart the more yellow sludge seemed to appear.
When I was pulling part of the air hose from the next joint, I thought it was a rubber hose that would bend. It wasn't and it didn't so now I'm on the hunt for a new Air intake vent hose.
I was having a conversation with my uncle last night, he's said that the short commute I do will cause moisture to develop as the engine isn't getting warm enough. He has also suggested fully synthetic oil as opposed to the semi synthetic 10w40 I've been using.
*Why is there so much oil in this system anyway? *Where is this moisture coming from? *Surely people have short commutes and don't have to deal with this problem regularly?
Phil H
*Why is there so much oil in this system anyway? *Where is this moisture coming from? *Surely people have short commutes and don't have to deal with this problem regularly? 1. It’s the breather system - looks reasonably normal if it’s got some miles on it and never been apart, or not recently. 2. The outside air - it’s cold and damp this time of year. 3. Yes, they do - a good long run (20-30 miles) once a week normally keeps it at bay.
