Hi all, finally sorted my engine upgrade out for the Viva so the Pinto and gearbox is up for sale, it comes with everything in the pictures Carb, alt, starter, Radiator and hoses, new ally distributor, fresh water pump, fresh fuel pump, has an ally bat wing sump, runs good and strong, things it needs are a rear main oil seal, could do with valve stem seals puff of smoke on start up when hot, and a clutch it doesn't slip but it's been in there a while.
Forgot to say the engine is still in the car and hooked up, if you are interested you can see it running then i will pull it if you want it, i can also send clips of it running as well if you let me know, cheers
