The workbench thread. Dez
@dez
Club Retro Rides Member 34
Irwin bought record years ago, but it’s generally accepted they’re not as good quality as the older ones. I have a guide to the numbers somewhere, but the 73/74 autovices are pretty desirable, as are the 112/114 steel models.
Paramo are also very good, Woden are ok too. Record are by far the most common in UK/commonwealth markets though.
Last Edit: Mar 27, 2020 9:28:35 GMT by Dez
@dez
melle
South West
It'll come out in the wash.
Mar 27, 2020 23:34:39 GMT
My favourite vice is made by Heuer. It's a nice and slim design and very tight and sturdy. I also have a very nice no-name '60s vice with a moving back jaw that is also made in Germany. I have a No. 3 and a No. 4 Record (old ones that I've restored); I think they're OK but definitely no match for German vices.
For general tin bashing will a normal record etc be ok? I had a cheap cast iron vice that cracked when I took a heavy swing at something..
Hoping that was just the cheapness and not the cast iron part.
@dez
Should be fine I reckon. I’ve smashed one in half but I was stood on the bench swinging a sledgehammer over my head at what was held in the vice 🤣
Mar 28, 2020 10:41:33 GMT
Excellent. Well, my two workbenches are now built, installed and the undersides filled with camping gear. Will take some photos and post them here tomorrow once the clamps have come off the wet bench. Already considering a modification, as I have extra steel, and I'm worried 2 layers of ply won't be enough to cope with keeping the vice in place. But I need to find a vice first! Edit* New benches. Second one is a stone top I pulled from a job. Nothing like 1k worth of stone to use as a wet bench. And camping storage underneath. There's juuuust enough room between for a pillar drill when I can find one on the cheap.
Last Edit: Mar 29, 2020 12:27:24 GMT by varelse
Apr 15, 2020 11:40:51 GMT
Some more Vice action, Prentiss Vise, spins all the way round on the base...complete with welded repair! and Record 84, reclaimed from a scrap bin,
Apr 20, 2020 20:42:36 GMT
I'm part way through building a new workbench in my shed. I have a few architects plan chests, which are great things, if a little deep. They are strong steel drawers with ball bearing runners, perfect for keeping loads of small parts, gaskets, clips etc. These rather dictated the size, though I may have gone a little overboard... The bench itself is around fifteen feet long and three and a half feet deep (due to the plan chests). I built an eight legged frame from 4"x4" timber bolted to the wall and to the floor. I topped this with 6"x3" timber laid on it's side with a layer of 3/4" sterling board, then a layer of 3/4" plywood. I came by way of a quantity of catering worktops from a school so the whole bench is finished off with 2.5mm stainless. I have a another sheet of 3/4" plywood which locates on the top with pegs if I need to strip a gearbox or similar, and I also have a sheet of 6mm rubber which can cover the other half if I need something softer. The back wall and the white spaces between the wall cupboards are covered in GRP-faced 6mm ply so wipe easily, reflect light and are virtually indestructible. There are sockets on the front for grinders etc, and there will be sockets on the back wall as well. I have a huge old Record steel vice which will go on the right hand end. The wall cupboards are from a friend who was fitting a new kitchen, and they will be fitted with a pelmet top and bottom and have LED lighting underneath. I have a pair of big steel ex-MOD cupboards, one on either end and a shorter one under the bench behind the stool. Kickboards under the planchests are a must - I don't want to lose anything that rolls under there. It's obviously still a work in progress, as I have yet to paint it or trim the timber with yet more stainless I've picked up, but it's getting there.
Apr 20, 2020 23:23:16 GMT
Ooh i just got a little bit ‘excited’ looking at that set up.
Apr 20, 2020 23:30:04 GMT
I had another chest and more stainless worktop left over, so I knocked up another bench in the opposite corner. This will take the small pillar drill, linisher, bench grinder and the polisher, along with a vice to hold the bead roller and shrinker/stretcher. The gap on the left will take an old rollcab I keep my bodywork hammers & dollies in. Again, this is a work-in-progress photo, so excuse the mess.
That's a nice looking setup. Looks proper permanent!
I'm hoping I can obtain an island prep bench or something similar from a restsurant, etc once work ramps back up again as it would be good to have a mobile trolley for dirty parts.
Apr 21, 2020 15:06:27 GMT
Just to class up the joint ... This was a temporary arrangement (only lasted 2 years *cough* ) Will find a picture of my current workbench ... but I'm about to start a project to replace that again soon.
Apr 21, 2020 15:40:21 GMT
^^^ that's luxury compared to what ive got at present, I have to drag an old workmate out and clamp a vice on it! the set up airspeed has got looks great though
Apr 21, 2020 23:51:31 GMT
^^^ that's luxury compared to what ive got at present, I have to drag an old workmate out and clamp a vice on it! the set up airspeed has got looks great though Doesn’t he complain? I mean his back must ache after a while.
At least he can pick up dropped tools for you.
oldisbetter
If it has a ECU it's complicated :)
This picture triggers my OCD for some reason.
It does look like "everything in its place and a place for everything", but in the smallest possible area!
oldisbetter
Apr 27, 2020 23:33:00 GMT
If you are looking for work bench and work shop shelving always keep an eye out for roofing timber from building sites and skips, i have made plenty of benches from off cuts and they are still going strong, I had to buy some timber today but that was for the man cave to house the Haynes type manuals which are in storage but i think i have about 100 now.
bstardchild
Club RR Member Number: 71
The workbench thread. bstardchild
@bstardchild
Club Retro Rides Member 71
May 10, 2020 17:20:07 GMT
This was advertised at work as "surplus to requirements" ie going to be skipped I had no need for storage but my work bench at the time was a length of free kitchen worktop on top of a stack of storage bins Chopped in half - one half topped with the previously used length of kitchen work top the other half topped with some 5mm steel to make a nice length work bench with a welding end and plenty of under bench storage. I should have made it narrower as it's currently buried under "Stuff"
May 11, 2020 10:17:24 GMT
I should have made it narrower as it's currently buried under "Stuff" It's been a good few years since I had the luxury of a workbench, but harking back to my Dad's days, as a kid, I always thought they came pre-buried!
