Feb 16, 2020 10:50:04 GMT
LR the wing steady bar went right through from series one to defender I think, so 1948 to 2018 ? James I've been told that the only component that was used throughout the Land Rover production, from Series 1 to the last of the original Defenders, was this - the steering swivels oil filler plug. I can't confirm this (wouldn't they have switched to a metric thread, at least, at some point?) but that's the legend. Apparently the only component that never changed on the Mini was the saloon roof panel (although BMC did change to thicker metal early in production). The windscreen seal lasted a very long time unchanged, until Rover came up with a wider version in the 1990s, which was better at keeping leaks out. You'd think they would have addressed that problem before!
Feb 16, 2020 11:54:36 GMT
Peugeot TU engine was about 30 years iirc. very close, 28 years, though the EC 1.6/1.8 is very closely related. the xud ahould only made till 2001 really lives on as the dw crank and block are derived from it, the turbo crank is the same part number as the old 1.8 turbo that was in the bx, 205 405 309 and rover 218/418.
Lancia Delta Indicator stalk from 1979 is the same on the one Ferrari F40
ZXRob
Feb 17, 2020 11:58:07 GMT
The parts must be external - engines are not as standard an external part unless you have a hot rod! Smith gauges are in everything - they would win outright but the part needs to be branded to the car The fiat / ferrari indicator lenses are probably one of the best - they really are on every italian motor across a huge period. I worked at a Ferrari place for a while and on one of our track days there was a line that included 512bb, Testarossa, F40, F50 and the then new Laferrari. My colleague parked his 1996 punto next to them and pointed the side repeaters out too me!
Feb 17, 2020 12:04:30 GMT
1979 astra (yes i know its a picture of an 83 model) its chassis carried right through unchanged to 1993 in the mk2 astra, then through to 1998 with a front subframe in the mk3 astra, and right the way through to 2016 in daewoo cielo in south america.
Last Edit: Feb 17, 2020 12:05:56 GMT by darrenh
Feb 18, 2020 14:49:00 GMT
The Bentley L- Series engine was introduced in 1959 and is only being ended once the current Mulsanne goes out of production. 60 years!
Well, that's won me over. * abandons logic*
