Apr 17, 2024 19:08:40 GMT
Compression has to be really quite low to stop firing and compression tests on cold engines that have been standing for months/years can be seriously disappointing.
If you’ve got 60+psi on most pots it should run after a fashion and once you’ve got it thoroughly warm, another compression test will give a better indication.
Apr 23, 2024 13:45:40 GMT
Club RR Member Number: 160
1967 Daihatsu CompagnoRich
@foxmcintyre
Club Retro Rides Member 160
Apr 23, 2024 20:22:05 GMT
Id just find an internally regulated alternator to adapt to fit it rather than use the external regulator. Far more reliable. Kubota used some really wee ones if space is a premium.
Apr 23, 2024 20:36:31 GMT
Ditto what rich said.
You'll have more, better regulated power, less wiring, tidier engine bay. There's a whole range of units to choose from that you could bag from a wreckers cheaply.
Well this is a cool little thing. Have you contacted Daihatsu themselves to ask about parts? On something so rare they might be interested in helping.
There are a few companies that make bespoke head gaskets, you can also buy sheets of the correct gasket material and make your own, I've never done a head gasket but it's the same material used for exhaust manifolds and is fine for small engines like yours.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Apr 25, 2024 18:28:08 GMT
Oh wow yeah common sense really eluded me there... Obviously a newer internally regulated alternator is the answer.
(This is the reason I'm here, so you guys can help me not be a dumbass 😂)
Just so happens I have a bunch of engines lying around that still have alternators on, so I will take a few up when I next go. Thankfully because a lot of my spare engines are daihatsu based they have quite diddy alternators anyway, so size shouldn't be a problem.
Cheers guys.
Apr 25, 2024 18:39:43 GMT
