Aug 11, 2020 14:25:06 GMT
I think I’d be happy with that. I love the gear selector on this. It’d be great if you could incorporate it in to the finished car if the engine and gearbox end up going. What is the performance like with the standard engine and gearbox? There’s not much point putting loads of time and effort into them if they’re disappointing even when in fine fettle. Is the rear axle a bought-in proprietary item like a Dana, or is it an A-S factory built one? Yes i agree about the gear selector . the stock car , with twin dinky 1"and a bit carbs puts out 150 bhp at 5k rpm , car weighs around 1.55 ton . 0-60 is 13 ish ,and top speed 100.4 apparently ...so for its day ,and size , pretty blimmen fast . engine is 7:1 cr , pk torque is around 2400 i think , so what they have done is put in a 190 @ .050" odd degree cam , small carbs for bottom end response , then a pretty free flowing head so it revs to 5k pk power . i think what appeals to me would be check valve to piston clearance , then skim the head as much as possible .port the head ,exhaust manifold .design and make a twin 1.75" su inlet . maybe a cam reprofile with around 210 ,and break 200 bhp ...alternatively , run an old eaton m90 i have here . time will tell ! rear axle i have no idea . i now find out by the way , the car has twin leading shoe 12" drums on it , apparently off a truck , and is as good on the drums ,as it pretty much was on the later stat sapphire discs ...woof. regards robert
glenanderson
Club RR Member Number: 64
The Temptressglenanderson
@glenanderson
Club Retro Rides Member 64
Aug 11, 2020 15:54:10 GMT
Sounds good.
With that level of performance available, from the original state of tune, I would have thought that a man with your experience should be able to achieve 200bhp one way or another. From what I can see the factory twin carb option made quite a difference, and that wasn’t exactly an exotic spec.
I suppose much will depend on the state of the engine, and what it will cost to bring it up to running condition. It appears to have been a robust and reliable unit, so would likely be quite capable of withstanding some increase in output without becoming hideously unreliable. Your experience with LPG, and all the various sensors/controls etc will no doubt add a level of safety margin to things. It would be really cool to get true modern day performance out of the original powertrain.
With regard to running a second gearbox backwards, to provide an overdrive, would you have the ratios selectable on the move, or would they have to be chosen when at a standstill?
My old Rover P4 has a very clever selection of limit switches, throttle switches and relays that meant that you could only engage overdrive on a trailing throttle, you could only knock it out if you took power, and when “in” you could floor the throttle and it would drop out automatically, and come back in when you backed off. It made driving the car very smooth, and changing down to overtake a simple case of flooring it.
Big drums are surprisingly good.
As for axles, if you can identify your stud pattern then you may find other big stuff of the period that shared it had higher gearing, although 4:1 is higher than a lot of stuff you’d find with big wheels and tyres. A 5000 rpm and 100+ mph capability was like warp speed for the time.
Aug 11, 2020 17:45:55 GMT
What i did with the tvr was have a second horizontal gear lever , it actually hit 165 mph with 20 psi boost at 4200 rpm .noice ...so i would prob do the same , have a 2nd gear lever wrapped in Moroccan suede dyed the correct colour dhhhalink
Aug 11, 2020 17:50:42 GMT
Quick bit of photoshoppery, as i can never resist. Sure you wouldn´t fancy a coupe?
Aug 11, 2020 18:44:49 GMT
Quick bit of photoshoppery, as i can never resist. Sure you wouldn´t fancy a coupe? That's exactly what I had in mind; what was the only boxy line on the car now matches all the swoopy lower ones. One piece front door glass, or at least blacking the quarterlight chrome would relieve another fussy area. The taillights could do with tipping forward slightly........ The key to this sort of customising is knowing when to stop.
Aug 11, 2020 19:08:50 GMT
very nice . thank you Horrido , i would have the rear window higher so the roof to window line stayed the same.... the lowering and slamming really accentuates those lovely deco curves ...
i can only assume some time travelling romantic throwback from the purple era was hired to design the car , then he went off to the south of france with a rich italian heiress , and the roof was designed by the local conservative mp.
The Temptressstealthstylz
@stealthstylz
Club Retro Rides Member 174
Aug 11, 2020 19:32:13 GMT
I've no idea if it would work but in my head a Mk10 Jag roof would suit it. A lot of British cars of that era had curse word roofs. No idea why but it nearly ruined as many nice cars as a Rolls Royce grille.
Aug 11, 2020 19:53:53 GMT
i think it was so they could sit in there with thier big snooty iambetterthanyoudontyouknowiwenttoeaton#richdaddy...hat on .
Aug 11, 2020 20:27:49 GMT
had a look at the grill today .. it has an interestingly weird jet engined sphinx on top .. i had a little go with some body compound at cleaning it up .. a little bit better , definately patinated .. i did the badge as well.. and then tried the side .. also did a bit of a fin as you can see . not going to win any prizes , but could be worse .. i think it may be thunderstorms will stop play tomorrow , already have a bit of thunder here right now . regards robert
Last Edit: Aug 11, 2020 20:29:45 GMT by ivanhoew
Aug 11, 2020 20:32:11 GMT
A temptress indeed! I was watching this on ebay as I've always really liked these Armstrong Siddeleys and thought it had probably gone for banger racing, so will be following this thread with great interest! If it's of any help to identify some of those parts or how things should look, I have quite an extensive collection (approx 1GB) just of Sapphire 346 photos. I can also recommend a couple of good AS books if that's any help? Alterntively, would be happy to scan any pages as needed. Yes, the roofline height is almost certainly so that passengers can still wear hats - this was the product of the early '50s, and the (vastly underrated) baby Sapphire 234 / 236 was blighted by an overly tall roof for the same reason. The big Sapphire always carried it off better though. Also, I'm very glad to see that it still has its twin jet engined Sphinx Oh, and a Jaguar MkVII was more Terry-Thomas' style - much more caddish!!
Last Edit: Aug 11, 2020 20:33:20 GMT by Paul H
Aug 11, 2020 20:39:27 GMT
Oh this is a perfect candidate for a Datsun LD28 with turbo. Pop the bonnet at the posh car show, all that patina, roof chop etc plus a dirty old Japanese diesel
bricol
Aug 11, 2020 21:24:56 GMT
How about going the other way to a roof chop . . .- this popped up on the MIG welding forum:
Aug 11, 2020 21:43:55 GMT
Quick bit of photoshoppery, as i can never resist. Sure you wouldn´t fancy a coupe? That is nice... I've done quite a few roofchops, and most of the time I tried to convince the owner of the car to go for what I call a "gentleman's chop". Just enough to clean up the lines, and get the proportions right, but no more than that. That takes a leap of faith of the car's owner, because its not any less work than slamming it, so its not any cheaper...
Lovely project. The photoshopped chop is spot on. If anyone wants a tough o/drive have a look at Gear Vendors in California. Been going years and the o/D's have huge power handling capacity
i agree metalshapes , i think it may be well beyond my skillset to achieve that flowing look but hey ...
Paul thank you for that offer , it would be handy to be sure of what the crank bolt size is , i am assuming its a 1 1/2" AF since it measures 1.48" across the flats .which books would you recommend ? Also , a scan of a page of recommended torque settings for the engine would be great in case i decide to get the head off and go that way.
regards robert
Last Edit: Aug 12, 2020 8:18:12 GMT by ivanhoew
glenanderson
@glenanderson
1.48” is 7/8” WW (1”BSF).
I would suspect that a lot of the fasteners are Whitworth or BSF if they’ve not been disturbed by previous owners.
glenanderson
@glenanderson
There’s a good comparison table here: link
. Almost 4 day old thread, Nearly 3000 views.Must be doing something interesting. To me a lot of the technical stuff that guys like glenanderson sprout, and that inhabits Roberts ivanhoew head just sounds like WOOOOOSSSSHHHH. But I find these builds absolutely addictive.
Last Edit: Aug 12, 2020 8:21:00 GMT by grizz
Aug 12, 2020 17:26:52 GMT
Quick bit of photoshoppery, as i can never resist. Sure you wouldn´t fancy a coupe? That really does look good, I agree that tilting the rear lights forward slightly would improve the flow, and mabie 2-toning it with the split on the flow of the front arch that meets level with the bodyline in the rear arch. The combination of lowering and roofchop is something that is easily overdone, its great for the chop to be obvious, but I think its better for the chop to compliment the rest of the body to the point that it looks like nothing has been done. Thats what I tried to acheive when I did a chop on a Matchbox (not trying to compare it to the work needed on a real car!). The car was lowered, the body was lowered onto the chassis, it had a roofchop and the top of the rear of the van box was chopped off, but dispite all the work done the intention was to make it look 'right'.
penguin45
Still welding......
Aug 12, 2020 17:30:45 GMT
Roof chop makes it look so Bentley. Now the van.....
P45.
