Nov 12, 2020 10:17:15 GMT
Surplus to requirements now is my 1 litre Seat Arosa. It's in great condition even though it looks rough. I'm ideally gonna break it then weigh but thought I would put it up on here. Alloys are available elsewhere on here. £150
Nov 12, 2020 10:22:45 GMT
tom13
Nov 13, 2020 14:13:34 GMT
What's actually wrong with it. Does it run and drive fine and can you see it going through an mot easily enough? Cheers
Nov 13, 2020 18:34:09 GMT
What's actually wrong with it. Does it run and drive fine and can you see it going through an mot easily enough? Cheers Clutch is high, Wheel bearing gone, Crack in windscreen Power steering has gone There the bits I know of
tom13
Nov 13, 2020 20:30:08 GMT
What's actually wrong with it. Does it run and drive fine and can you see it going through an mot easily enough? Cheers Clutch is high, Wheel bearing gone, Crack in windscreen Power steering has gone There the bits I know of Appreciate the reply but not worth the effort for me as I only need it short term.
Last Edit: Nov 13, 2020 20:30:33 GMT by tom13
nitro
Nov 16, 2020 21:38:26 GMT
Where abouts are you located mate?
Where abouts are you located mate? It's at my unit near Penistone but we border Sheffield S36 9NN
Jan 26, 2021 10:04:54 GMT
Bump
Jan 30, 2021 14:19:48 GMT
Anybody want this for £100
japman
Jan 30, 2021 17:05:36 GMT
Where you are from me... And for me to come and collect this... I'd offer you £50 for it.
I can come today or 2moro even. Load it on my truck and off it goes.
Pm me with your number if you agree.
Regards
Jan 30, 2021 18:12:32 GMT
Where you are from me... And for me to come and collect this... I'd offer you £50 for it. I can come today or 2moro even. Load it on my truck and off it goes. Pm me with your number if you agree. Regards £100 and its yours
japman
Jan 30, 2021 18:51:38 GMT
With the current climate and market. Its just not viable. The amount to spend on it.. It will equate to a car much bigger and cleaner. So my offer stands since its not roadworthy due to windscreen and bearing gone. Probably not mechanically right too since the power steering is shot...it may just seize, snap the belt and cook the engine.
Regards.
Jan 30, 2021 20:37:17 GMT
Slacker have you tried scrap car comparison? They'll probably offer you a ton for it.
Jan 30, 2021 21:30:36 GMT
i got 150 for a berlingo with no battery this week off a local lad with a beavertail, find the decent ones not the ones that'll just weigh it straight in for £50.
Jan 31, 2021 11:09:20 GMT
With the current climate and market. Its just not viable. The amount to spend on it.. It will equate to a car much bigger and cleaner. So my offer stands since its not roadworthy due to windscreen and bearing gone. Probably not mechanically right too since the power steering is shot...it may just seize, snap the belt and cook the engine. Regards. I ran it for over 12 month with no power steering
Jan 31, 2021 11:11:00 GMT
i got 150 for a berlingo with no battery this week off a local lad with a beavertail, find the decent ones not the ones that'll just weigh it straight in for £50. Exactly what I will do, I'm not letting it go for £50. I'd rather tip it on its roof, cut the floor out and turn it into a hot tub.
japman
Jan 31, 2021 11:41:21 GMT
Your thing, do what you want with it.
I am trying to help out by taking it away to save you the time and headache. Weighing under 850kg and scrap value being low. Its not worth it at 100..
I'll give you £65 for it.
And I'll leave as soon as you PM your number should you wish?
Last Edit: Jan 31, 2021 11:43:19 GMT by japman
Jan 31, 2021 14:35:39 GMT
Your thing, do what you want with it. I am trying to help out by taking it away to save you the time and headache. Weighing under 850kg and scrap value being low. Its not worth it at 100.. I'll give you £65 for it. And I'll leave as soon as you PM your number should you wish? Such a gent offering to save me time and stress ffs 😂
japman
Jan 31, 2021 14:47:15 GMT
I'm not bothering anymore. You keep it and screw it. Do the hell you want with it.
Jan 31, 2021 16:41:25 GMT
I'm not bothering anymore. You keep it and screw it. Do the hell you want with it. 😆 I intend to
