1934 ford hot rod truck. Dez
@dez
Club Retro Rides Member 34
Feb 18, 2021 20:46:02 GMT
A lot of stuff does change hands under the radar before it’s ever advertised openly. Once you’ve been into this stuff for a while you sorta become part of a underground network of parts hoarders 🤣 A lot of trading of those hoarded parts happens rather than cash changing hands. All this sort of thing is as old school as the cars themselves! Thanks Dez, I suspected your last point may have been the case. I guess often you grab hold of parts you don't need but know are desirable in the hope they can be swapped sometime down the line too! I'll keep my eyes peeled, I strongly suspect I'll be going down a fibreglass route myself or chopping up something British! I can always transfer parts between cars later if the right things come up for sale. I’ve bought and sold parts this week that I had no intent of keeping, but furthered y overall build by means of a few deals. If you let me know what you want to build and why sort of budget you have I can keep an eye out, I goer offered stuff all the time.
@dez
Feb 18, 2021 21:05:14 GMT
So I’ve got a chassis with a front bit, a back bit, and some bits down the sides. Next bit is a bit in the middle. These chassis have a centre ‘X’, that is formed by those previously mentioned inner rail boxing plates taking a dive across to the centre of the chassis, being joined together by a few extra bits behind the gearbox that acts as the gearbox mount, then going back out to the rails again before the rear kickup. This provides lots of diagonal bracing and makes for a pretty stiff but compliant chassis, as all bracing is centred around the torque origin of the gearbox. Originals are nearly always hacked up, usually to allow different gearboxes, but a friend has a mildly rusty and only mildly damaged one out of a pilot up on his farm, so I went and got that. The two round bits are the rear gearbox mounts, so it’s front down there. The pedal assembly also mounts to the front section, and the rear end of the front wishbone mounts to the bottom of it, but not much else is attached, it’s all just bracing. I went and got it sandblasted before I did much of anything with it. That’s roughly how it fits. You can see the wishbone mount there in the middle, basically half a ball socket. You can see it’s not quite symmetrical, it should be though. That’s the bit of damage I referred to, one rear leg was bent. Here I’ve trimmed it down and bent it about a bit, and am using the gearbox and pedal assembly to determine position, along with some measurements taken off the motor. You can see here how the gearbox mounts work. And here how the pedal assembly mounts. Again this it was all quite complicated as I was working in two planes, and to imaginary reference points. It was also at this point I cocked up, but it took me a good while to recognise it. Thinking the X member was in the right place, i made a jig to centre it around the gearbox mounts, and welded it in at the front, tweaked the bent back legs to where they should be, and welded those too. That will come back to cause me loads of problems later...
Last Edit: Feb 18, 2021 21:08:54 GMT by Dez
bstardchild
Club RR Member Number: 71
1934 ford hot rod truck. bstardchild
@bstardchild
Club Retro Rides Member 71
Feb 18, 2021 22:37:48 GMT
Again this it was all quite complicated as I was working in two planes, and to imaginary reference points. It was also at this point I cocked up, but it took me a good while to recognise it. Thinking the X member was in the right place, i made a jig to centre it around the gearbox mounts, and welded it in at the front, tweaked the bent back legs to where they should be, and welded those too. That will come back to cause me loads of problems later... Plot twist - I do like a good plot twist
If this was a car flipper show, the plot twist would be it was welded to the wrong chassis, and then it would turn out that the original owner of that chassis was your lost brother/mother.
Was the front also out of shape?
Chris™
This is clearly filler material.
Feb 23, 2021 13:41:40 GMT
If you let me know what you want to build and why sort of budget you have I can keep an eye out, I goer offered stuff all the time. Very kind of you, thanks Dez - I've sent you a PM to avoid cluttering up your thread! If this was a car flipper show, the plot twist would be it was welded to the wrong chassis, and then it would turn out that the original owner of that chassis was your lost brother/mother. Oh and there needs to be some sort of fake jeopardy: if this car doesn't get painted by the end of this week, "we're gunna lose the shop!!"
Last Edit: Feb 23, 2021 13:41:57 GMT by Chris™
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
Feb 24, 2021 16:46:09 GMT
If you let me know what you want to build and why sort of budget you have I can keep an eye out, I goer offered stuff all the time. Very kind of you, thanks Dez - I've sent you a PM to avoid cluttering up your thread! If this was a car flipper show, the plot twist would be it was welded to the wrong chassis, and then it would turn out that the original owner of that chassis was your lost brother/mother. Oh and there needs to be some sort of fake jeopardy: if this car doesn't get painted by the end of this week, "we're gunna lose the shop!!" Dwaine! Need I say more?
@dez
For the next bit of this thread I’ll carry on with the running gear and the issues I’ve had, even though it’s not the actual order i did things in. Now I’ve got the centre X in (unbeknownst to me in the wrong place) I can attach the engine and box together and put them in the chassis to determine the position of the front engine mounts. This had been previously calculated theoretically, and it all added up at first glance because of a maths fail, hence me not noticing til I’d assembled a lot more stuff together. The front engine mounts on flatheads change a few times, and are never actually on the engine block. On early ones (up to ‘35) they have some brackets that bolt on the front of the block either side of the crank pulley that run across to the middle-ish of the front crossmember. Like this- 35-up mounts are actually part of the water pumps, out on the left here. They are further apart so more stable, but in a totally different place in relation to the crossmember, cos that’s in a different place in relation to the axle. Usually... That big hole you can see on the crossmember is where they usually go. And it’s that measurement that caught me out. Basically when planning the mounts I failed to take into account the distance from the front of the block to the engine mount hole is further on pre-‘35 brackets to post-35 water pumps. Even though I knew this and had written it down! I didnt realise my mistake until it was too late. So the entire motor, box, centre X and engine mounts are 2.5” too far forward. But, I’d already made and fitted front mounts- So the next time I work on this, they will have to come back off and go in the bin, as tube type mounts won’t work in their new location. I’d also shortened the torque tube to the wrong length. If you don’t know what a torque tube is, they’re sort of an enclosed driveshaft between gearbox and axle, that spins inside a big fat stiff outer tube that locates the rear axle, and it has a pivot on the gearbox end. They’re instead of an open propshaft. Luckily I’d only sortened the outer tube and not made the driveshaft yet, so it’s easy to cut a bit more out and reweld. Torque tube shortening- The domed thing bolted to the back of the gearbox is the pivot ‘clamshell’. The torque tube locates the axle fore and aft, so The rear axle is partially located by the engine and gearbox mounts. and as the ‘torque tube’ name suggests controls the ‘wrap’ the axle wants to do from the power input from the motor. The rear spring locates the axle side-to-side. It’s a simple-ish setup but very effective, especially on uneven, unpaved roads of the ‘30s and ‘40s. When you do this you also have to shorten the rear radius rods, that are part of the suspension. They’re now too long and at the wrong angle, so you cut them down and bend them in to still fit the original mount on the torque tube. I’m using ‘35-‘36 rear axle, torque tube and radius rods, as they’re the best looking/most desirable ones, and that’s what I had. Just got to reshorten them all again now... it in the scheme of things that’s not too difficult, and it why you mock build stuff like this. at least I didn’t cut it all too short I guess!
@dez
Converting the front end to 32-34 spec was comparatively simple. Well I managed not to get it wrong anyway 😬 35-up wishbones have the spring mounts extended off the front like this. They take a bigger wider spring, and the crossmember is moved forward in the chassis compared to earlier cars as the spring is no longer at (about) axle centreline. These get cut off and smoothed out. I won’t be splitting the wishbone at this point as i need it in one piece for registration purposes. If you don’t know what the means I’ll explain later. The actual I-beam is the same part from 1932 to 1936. The perch pin holes (the f-k off bolts that attach the beam to the wishbones) are the same spacing, so you can take a 35-36 beam and wishbones and backdate it to 32-34 style spring-over setup easily. The wishbone isn’t the same length but for a build like this it doesn’t really matter. Later perch pins don’t have spring perches on them (confusing I know) so you have to remove them and swap for earlier ones. They’re always seized so this usually involves some hot spanner action. After I’d done that I assembled The cut down wishbone and beam back up with some 28-34 style perch pins (that actually have spring perches!), some aftermarket repro shackles, and a 28-34 front spring. The spring is just a stock one for now, it’ll get a reverse eye one at a later date for more lowering. Then I used a ratchet strap to compress the spring as much as possible so I could get it under the chassis and fitted to the crossmember, as the chassis table was in the way a bit. It was tight but it went in. This bit has all gone ok and I’m pretty happy with how it fits and works.
@dez
Mar 12, 2021 23:03:23 GMT
Next I will start cataloging some of the stuff bought to build this, and why I’ve chosen those bits. First up we have a MYSTERY PACKAGE from the land of burgers, Elvis and institutionalised racism. Ooooh, that looks interesting. But what is it? If you can’t quite read that, it says ‘breathing oxygen’. They’re ww2 issue and we’re used on b17s, b24s, p51 mustangs, kittihawks, and most other similar period American aircraft capable of high altitude flight. They’re stainless steel and carried pressurised oxygen for the crew. They’re not that large though, about 4 (proper) gallons, so after biding my time a Bit, another also turned up. They’re not massively rare or expensive, but I didn’t want to pay too much cos I’m northern. You can pick them up for about £100-150 each shipped. If you consider how many must have been in circulation it’s unsurprising they’re not hard to get. They were also useful postwar with a lot being repurposed. I actually know a local old boy who’s got half a dozen daisy chained together as a makeshift compressor tank, but he won’t sell me em despite by best bribery efforts. It’s much easier to buy things of people who want to sell them, hence me trawling US eBay. I’m obviously going to use them as fuel tanks. This means I need some appropriately old-timey filler necks and caps. I found these totally by accident whilst looking for something else. They’re cast aluminium, have the handy chains to stop me losing them, and are generic thread. It was something like 2” BSP. They were for something weird like irrigation or silage systems, I can’t remember exactly. The ‘neck’ is just a stainless 2” bsp male-male jointer cut in half. They’ll sit something like this. I might add a bolt flange to dress em up further. I can’t quite decide if the tanks will run sideways or lengthways yet. This way looks cool but i think the other way would too. I need the bed on there to decide. How they end up mounting will also be a major consideration of direction.
Can you TIG aluminium to stainless? Or will you end up brazing it?
That will certainly look pretty cool.
Will you link them together at tank level or just join them before the pump?
It'll be interesting to see how you deal with fuel levels without treating it like a secondary tank.
@dez
Mar 14, 2021 13:25:40 GMT
There no ally to join to stainless. The tanks are stainless and so are the pipe stubs. Only the caps are ally.
@dez
Mar 14, 2021 13:58:32 GMT
More tings I have bought. This is between 2 and 3 years of parts collecting. A lot of people don’t believe i take so long preparing for building a car, but I really do. I generally start off buying things that will physically fit the build and the aesthetic I’m going for, and then once I’ve got so far, typically more than half of what I need, I’ll write a specific list of what I have and what parts I then need to fill the gaps and make everything work together. So first, a steering wheel. 42-48 ford passenger car. I wanted to run some sort of stock steering wheel, but nothing too gaudy. Most hotrods end up with ‘40 ford ones, mostly because they repro them. I wanted something with a very plain spoke design but some restrained bling to the centre. I like these ones with the prizimatic back painted gold detail. So when a pretty nice one popped up I had it. Pedal assembly. This is 42-48, they use the same mount as 39-41. (hydraulic brakes only came out in ‘39 on fords so prior to that the pedal assembly didn’t have a master cylinder mount). The actual pedals are a different shape to easlier cars, but if they have to be modded in any way there’s no point using the much more expensive 39/40 ones. As my car is channelled they will have to be messed with a bit. I already had most of the brakes setup from stuff I’d bought for the ‘38s, like backplates and most of the internals, so I know I’d be wanting to run a stock-ish pedal setup. I’m also running the late type clutch isolation linkage, which has a floating bar and an extra bracket on the frame rail rather than the pedal acting directly on the clutch arm. That’s what the other piece in the middle is. It’ll make more sense once fitted. I’ve been collecting lights too. I’ve got a mint pair of guide 682J headlamps for starters. These are THE hot rod headlamp. They were an accessory part from the 40s/50s, and use 7” sealed beam units, so are easy to convert to H4 or whatever with cheap modern units. These lights command quite premium nowadays but to me they’re an essential ingredient of the look. I’ve also got a couple of different pairs of funky rear lights as you can see. I might use them or I might use something else, I’m not sure yet. The metal number plate backer was leftover from another build but is a nice thing for a truck so I put it in the pile. In the ‘smalls’ cupboard I’ve got some new trackrod ends, the right throttle pedal and linkage, a good usable drag link, refurbed front hubs, a box of brake internals and various other bits and bobs to make things work together. It would be a chunk of cash to buy it all in one hit, but one bit as a time as they come up and it’s hardly noticed. I’ve also picked up some front tube shock mounts for the beam, some shorty shocks and some repro F1 style shock mounts. The latter have to be modified to fit once the rest is assembled. I’ve also got some rear 48 deluxe tube shock brackets but I don’t have a picture to hand. A new old stock alloy timing gear came up cheap so I bought that too. Flatheads have a fibre one that can strip so you replace them if you’ve got it in bits. A guy on one of the forums also did a batch of lazercut header flanges for flatheads, so I snagged some of those too. So I then flogged my stock cast manifolds as I knew I wouldn’t be using them, to put some pennies back into the pot. Then I’m back onto bigger purchases, both physically and financially....
Last Edit: Mar 14, 2021 14:00:00 GMT by Dez
@dez
Mar 14, 2021 16:12:45 GMT
I ended up buying wheels. Lots and lots of wheels. I had 10 at one point! At first I was going to go with ‘39 “wide 5” wheels and brakes, as I had some. But the more I did the more I knew they weren’t really what I wanted, as the 1940 ford steel wheel is such a defining part of the look of any early hot rod that runs them. I decided to sell these as a complete package with the brakes, and a pair of good ‘40 rear drums popping up pushed that decision. So With the drums in hand I started buying whatever wheels came up at a reasonable price and making up pairs. Full sets are very expensive to buy complete. I bought a really nice matched pair with dead roller tyres at a good price. They’re 4.5” wide so I was going to run them as rears. 40s ford wheels come in 2 basic widths, 4” and 4.5”, and are all 16”. The usual setup is 4s up front and 4.5s out back, or just 4.5s all round. But, there is also another 16” 40-ford looking wheel option. You can get 5” wide ones, which are very rare as they were only available as an optional extra on 48-52 f1 trucks, the ‘high clearance’ option. They’re the same centres in a slightly wider rim. This so good for running big back tyres like 7.50-16 as they don’t roll as much. And to cut a long story short I just happened to luck out on a set of them. I bought these as ‘f100 wheels’ quite cheaply, as the seller hadn’t listed if they were 16”, or 15” as a f100 should have. I thought they looked like 16s, so I asked him and it turned out they were. I sent a pallet to pick them up and I ripped the tyres off the second they landed, to find a full set of 5” wide rims! One pair where sold immediately, the other pair are now my rears and the 4.5s will go on the front. The money I made on my wheeling (hoho!) and dealing helped to finance something I was really putting off buying. The one thing missing from my cab that is totally unique to 32-34 pickups are the door latch mechanisms. They are available knew as united pacific now make reproduction ones for the reproduction cabs they make, but they’re quite expensive. As the cab was good value I was kinda resigned to having to spend out on these, sometimes I t’s just easier to buy the thing and move on rather than mess about for ages trying to make something else fit. But being a Yorkshireman it took me a long time to psyche myself up to pay £400 for two door catches. Yes, you read that right, this is £400 (well, £397 with shipping and duties paid) of door latches. But they’re brand new, fit perfectly, work perfectly, don’t have 85 years of wear that needs sorting, and just fit and forget and allow me to get on with far more interesting things. Conversely the window winder mechs are £30 each brand new as they’re shared with model As 🙄😁
75swb
Beta Tester
Club RR Member Number: 181
1934 ford hot rod truck. 75swb
@75swb
Club Retro Rides Member 181
Mar 14, 2021 20:06:58 GMT
Wow, a long time in the planning, and some very specific parts to hunt for. Amazing luck on the wheels, but I guess a lifetime of knowledge let's you make the most of those situations. Rods more than anything else I think do require the 'right' parts to work, not an easy task for sure.
There no ally to join to stainless. The tanks are stainless and so are the pipe stubs. Only the caps are ally. Huh, I totally missed the stainless neck, even though you quite clearly said it was. Carry on!
@dez
Mar 15, 2021 19:33:53 GMT
Wow, a long time in the planning, and some very specific parts to hunt for. Amazing luck on the wheels, but I guess a lifetime of knowledge let's you make the most of those situations. Rods more than anything else I think do require the 'right' parts to work, not an easy task for sure. That’s very much my thinking now. I’ve built cars out of ‘all the wrong bits’ in the past and made em look half decent, but it really is much easier to work with the ‘right’ stuff, if a bit more expensive. But then what does all that time you spend making stuff ‘right’ cost?
@dez
Mar 15, 2021 20:07:02 GMT
More purchases. This is a very specific thing, crucial to the whole project being ‘right’, and another example of my jammy luck... ‘34 truck grilles are a 1 year only, 1 model only part. Car grilles are a totally different, and 32 truck and 33 truck grilles although at first glance are similar, have differences in depth, trim and radiator cap. Truck grilles do not have a removable grille ‘insert’ so finding a good one is much harder. 34 ones are also a bit deeper on the sides, and the top ‘spoon’ trim is different to 32. And only 34s have a removable stainless trim around the outside of the grille opening. I knew a friend had a ‘34 truck grille hung on his wall that had been sectioned to go on a T-modified back in the day. It was solid and in pretty good condition, but had 6” or so missing out the middle. Still, it was the only one I knew of so I made it known every time I went round that if/when it was for sale I wanted it. He is the typical hoarder type that only sells stuff if he wants to fund something else. Well he’s on with a super original ‘32 coupe he’s doing and had some stuff to buy, so after two years or so of gentle reminders I got a message that it’s for sale. A couple hours later I’m down at his and it takes a ride back with me. It’s clean, straight, rot free, has the ‘spoon’ trim, it’s just a bit short for my needs. I was over the moon with this, and given the scarcity of it, I was perfectly happy to add a bit of metal back in to make it stock length again, or close to. So I’m back at the workshop and I sit down with a brew and have a quick look on Facebook. Someone has listed a MINT ‘34 truck grille shell 20 minutes previously! Without really thinking I just message him and say I’ll have it. It’s a good chunk of cash, but cheap for what it is (they fetch $1500+ in the states). It’s also 150 miles away. But close to my other house, which I’ve got to go up to in about a week. An agonising wait then ensues as it takes the guy ages to reply. Two hours later I get a message saying I’m first in line... So a few days later I am in the north, and after unloading the van i take a short trip out to Chesterfield and come back with this- It’s amazing condition for a 87 year old bit of front end sheetmetal. Its been over painted but it has the stainless trim, it’s got a spoon on it, the lower baffle panel is still there, and it’s straight and almost rust free (the baffle panel has a tiny bit in the corner). Tbh it’s far too good to chop up for my car 😂 I may use it as a template to return the other one to stock, or I may chop it. I haven’t decided yet. But that’s the story of how i bought two 34 truck grilles in a day after spending literally years looking for one.
Last Edit: Mar 15, 2021 20:13:47 GMT by Dez
Stiff
'kin 'ell
Mar 15, 2021 21:53:47 GMT
More jam than Hartleys This thread just gets better and better.
1934 ford hot rod truck. stealthstylz
@stealthstylz
Club Retro Rides Member 174
Mar 15, 2021 23:57:56 GMT
Gerrit chopped man. It's always more fun hacking good condition vintage stuff and it's not suddenly like you're gonna get the heebie jeebies and fit a car grille or whatever.
That is a tough one... There is something to be said for using the best part for the truck, even if it has to be modified to fit. But there is also massive satisfaction in saving a rare part that has been really messed with... Can you still get the stainless trim, or would you have to use the trim of the better grille? Either way, congrats on the finds, man.
