Dec 17, 2021 23:16:11 GMT
Firstly, this is awesome so well done for thinking it up I'm intrigued to see what the plan is for hiding the chassis forward of the A-posts/firewall because the Kia was obviously much wider than the Ford body. Same goes for the front suspension. The original beam-type front axle ahead of the grille allows the bicycle fenders/headlamps to work but how is the wishbone setup going to be hidden to get the same effect? Anyway, keep up the good work. We have a partial plan to hide some of it but embrace other elements, but that will be a bit of making up as we go along. I want to make a strut bar that doubles as a headlight mount similar to the model A headlamp bars they had back in the day but with a twist if you catch my drift?
Just because there's a rulebook doesn't mean you have to read it.
cpt.braithwaite on the Instagrams
Club RR Member Number: 160
This is an interesting project. Curious to see how it turn out, moving the engine back was definitely a good move. Suggestion OP, don’t change your font size over the forum standard. Makes the thread awkward to read on mobile IMO and a lot of people use phones to browse. Otherwise keep up the posting, interesting stuff!
This is an interesting project. Curious to see how it turn out, moving the engine back was definitely a good move. Suggestion OP, don’t change your font size over the forum standard. Makes the thread awkward to read on mobile IMO and a lot of people use phones to browse. Otherwise keep up the posting, interesting stuff! Thanks for the heads up, I'm not sure why I changed it in the first place.
I am known for loving stuff that does not fit moulds.
And this build really is creating its own mould.
I hope it all comes together really easy, and that the legal side is a cake walk.
Dec 18, 2021 18:30:04 GMT
Firstly, this is awesome so well done for thinking it up I'm intrigued to see what the plan is for hiding the chassis forward of the A-posts/firewall because the Kia was obviously much wider than the Ford body. Same goes for the front suspension. The original beam-type front axle ahead of the grille allows the bicycle fenders/headlamps to work but how is the wishbone setup going to be hidden to get the same effect? Anyway, keep up the good work. We have a partial plan to hide some of it but embrace other elements, but that will be a bit of making up as we go along. I want to make a strut bar that doubles as a headlight mount similar to the model A headlamp bars they had back in the day but with a twist if you catch my drift? Maybe something like this: [Edit: couldn't embed the image, so here's a link to the thread with it in] And perhaps if you widened the fenders inward towards the bonnet it could hide the strut towers?
Last Edit: Dec 18, 2021 18:33:56 GMT by daklone
Dec 18, 2021 20:36:56 GMT
We have a partial plan to hide some of it but embrace other elements, but that will be a bit of making up as we go along. I want to make a strut bar that doubles as a headlight mount similar to the model A headlamp bars they had back in the day but with a twist if you catch my drift? Maybe something like this: [Edit: couldn't embed the image, so here's a link to the thread with it in] And perhaps if you widened the fenders inward towards the bonnet it could hide the strut towers? Yeah that's the sort of thing I mean, I'll figure that all out when I get to it, little way off the shiny stuff haha!
Dec 19, 2021 20:54:38 GMT
I am known for loving stuff that does not fit moulds. And this build really is creating its own mould. I hope it all comes together really easy, and that the legal side is a cake walk. Cheers dude! Hopefully if I follow the book it should be okay!
Dec 19, 2021 22:51:04 GMT
Am I right in thinking that the motor in the KIA is a Mercedes derived lump. In which case could you use a RWD 2 wheel drive gear box fro a Merc. It would be a lot more compact than the Kia 4WD box, and free up some room in the cab.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
75swb
Beta Tester
Club RR Member Number: 181
Am I right in thinking that the motor in the KIA is a Mercedes derived lump. In which case could you use a RWD 2 wheel drive gear box fro a Merc. It would be a lot more compact than the Kia 4WD box, and free up some room in the cab. en.wikipedia.org/wiki/Hyundai_A_engine#D4CBLooks like this one is Kia's own unit (although someone smarter than me may know its derivation). Ssangyong ran the merc 2.9 for a while.
Am I right in thinking that the motor in the KIA is a Mercedes derived lump. In which case could you use a RWD 2 wheel drive gear box fro a Merc. It would be a lot more compact than the Kia 4WD box, and free up some room in the cab. Close but not quite, there's a lot of Hyundai parts on this, almost like Skoda and VW, one of their van boxes will probably fit but right now we're using what we have, the running gear is mounted so low that the transfer case part is barely noticeable in the cab floor cut outs. I think a gearbox change would be a future job, currently want this done and on the road hahahaha.
75swb
Beta Tester
currently want this done and on the road hahahaha. With the fuel pump turned up for big smokey burnouts!
Last Edit: Dec 20, 2021 9:05:40 GMT by 75swb
Dec 20, 2021 20:25:01 GMT
currently want this done and on the road hahahaha. With the fuel pump turned up for big smokey burnouts! It probably won't need turning up, if it weighs half that makes it twice as powerful doesn't it? hahaha
Dec 20, 2021 20:34:15 GMT
Another job ticked off was cutting down the propshaft... which went well... weird how it didn't fit though, it was like someone moved the engine or something... The plan is just to use this for reference and get it either scratch built or have the tube done properly by an actual professional and not a yoof with a chop-saw. I think I cut about 600-700mm out of it to make it fit, I just had a slight slip yoke miscalculation resulting in needing to add a bit in, even after measuring three times! A short and sweet post tonight, been a bit lax lately! Braithwaite
Dec 21, 2021 12:26:06 GMT
Some excellent progress! It's starting to look dead smart.
Burnouts by new year's day right?
Dec 21, 2021 19:00:38 GMT
Some excellent progress! It's starting to look dead smart. Burnouts by new year's day right? She's not quite that ready yet hahahaha, besides THIS isn't the skid car
What was the issue with the Kia handbrake? It looks like a decent position to me!
It's a good idea to try and keep your tunnel to simple shapes that can be easily formed & joined together, especially around the seat area. Having fiddly parts that require you to take the seats out to access the tunnel, or tunnel out to access the seats, is going to be a massive pain in the bum down the line. Not saying yours is going to be like that, but some advice all the same!
Dec 22, 2021 17:37:08 GMT
What was the issue with the Kia handbrake? It looks like a decent position to me! It's a good idea to try and keep your tunnel to simple shapes that can be easily formed & joined together, especially around the seat area. Having fiddly parts that require you to take the seats out to access the tunnel, or tunnel out to access the seats, is going to be a massive pain in the bum down the line. Not saying yours is going to be like that, but some advice all the same! The position was good but there wasn't enough space between two seats to comfortably get your hand down to operate it. Yeah I know what you're saying and like you say we plan to keep the shape simple and fit it in a way that the seats don't have to come out to remove parts of it etc. Advice is always greatly appreciated!
93fxdl
Enter your message here...
Dec 22, 2021 19:34:13 GMT
Couple of ideas for the handbrake, under dash umbrella style, American style pedal and release button or an electric one, no need for anything between the seats then Ttfn Glenn
Dec 22, 2021 19:52:29 GMT
Or an xjs one outboard of the seat.
Dec 22, 2021 20:20:38 GMT
In the USA the Empi Hydraulic Park lock is legal for the street. ( popular on sandrails, etc) May not be legal in your neck of the woods, though.
