Davey
Resident Tyre Nerd.
Cat cleaner really isn't necessary and honestly does a whole lot of nothing if the cars running properly and used frequently.
Just get it screaming hot before the MOT and it should sail through.
Aug 31, 2022 10:54:51 GMT
^ Definitely this. I had a high flow cat on my cedric and I used to book the mot for a day I knew I could wait with it and give it a good blast to get it red hot as I arrived for the test and never had a problem.
MoT day. I had nothing to worry about, the exhaust emissions were clean as a whistle. The tester commented how clean the BMW is and gave it a clean bill of health, MoT passed, no advisories. Whilst the BMW was up in the air I had a look at the rear subframe and where it bolts onto the floorpan. I couldn't see a great deal but certainly no evidence of any cracking. Is this the valve that I should remove from the clutch hydraulics? Next is an engine oil and filter change and I need to upgrade the rear speakers. Watch this space.
Davey
Resident Tyre Nerd.
Sept 2, 2022 10:05:49 GMT
MoT day. I had nothing to worry about, the exhaust emissions were clean as a whistle. The tester commented how clean the BMW is and gave it a clean bill of health, MoT passed, no advisories. Whilst the BMW was up in the air I had a look at the rear subframe and where it bolts onto the floorpan. I couldn't see a great deal but certainly no evidence of any cracking. Is this the valve that I should remove from the clutch hydraulics? Next is an engine oil and filter change and I need to upgrade the rear speakers. Watch this space. Great news on the pass, with how clean it is I'm not surprised. That is exactly the valve, it should just be a case of unbolt, remove and thread brake line back into the connector. No additions required.
Sept 2, 2022 10:59:08 GMT
For folks who don't speak BMW ( )... why remove that valve ?
Sept 2, 2022 11:32:32 GMT
For folks who don't speak BMW ( )... why remove that valve ? Removal of the valve alters the hydraulic pressure imposed on the slave cylinder and improves the clutch pedal feel and operation of the clutch.
Sept 2, 2022 11:39:01 GMT
For folks who don't speak BMW ( )... why remove that valve ? Removal of the valve alters the hydraulic pressure imposed on the slave cylinder and improves the clutch pedal feel and operation of the clutch. Thank you !
Davey
Resident Tyre Nerd.
Sept 2, 2022 13:14:48 GMT
Removal of the valve alters the hydraulic pressure imposed on the slave cylinder and improves the clutch pedal feel and operation of the clutch. Thank you ! For a little more insight, it is a clutch delay valve, designed to slow down the release of the clutch and "Improve" shifts much like a DMF does by reducing shock. However, in reality when you are pressing on a bit. It makes the pedal feel like the clutch is on its last legs and cause premature wear as if you are slipping the clutch to smooth things out.
Sept 6, 2022 16:27:35 GMT
I've done some easy oil changes in the past (my Mercedes Benz W123 is one) and some fiddly ones (a Mk1 Audi TT 1.8T that I had a couple of years ago is another). Today was the turn of the BMW. I started off by jacking up the offside of the BMW and supporting the car with an axle stand. Placing a small dog under the car also helps. The underside of the engine is mostly concealed with plastic covers but BMW very kindly left an access hatch to enable the engine oil to be drained with minimal fuss. During the process I was being constantly assisted by my dog. I have renamed Daisy and she's now called Melchett, as in General Melchett of Blackadder IV fame. I expect that most readers are far too young to understand. Working with the standard jack (remember a hydraulic jack won't fit under the low sill) in my garage makes the process a bit tricky as there isn't that much room under the car. I got the oil to drain out. I lowered the jack as much as possible, without squashing the oil container, to get all the old oil out. Draining the oil and re-fitting the sump plug was all nice and easy. BMW put the oil filter housing in the most accessible position possible, up front, along the top of the engine. Thank you BMW. Unscrewing the top of the housing and removing the old oil filter took just a few seconds. I wiped all the old oil off the inside of the oil filter housing, ready to receive a replacement Bosch oil filter. Finally, with the new oil filter fitted and housing reinstated, my 12 year old helped out whilst I put in 6.5 litres of fresh 5W40 engine oil. All nice and easy, took about 30 minutes, which allowed time for all the old engine oil to drain out.
Last Edit: Sept 6, 2022 16:39:19 GMT by Peter C
Davey
Resident Tyre Nerd.
The Moustache suits the new name.
BMW Still leave this access hatch now. However the better halves 1 series has a flap with a rotating latch.
The jag requires a rather extensive plasticectomy to get to anything engine related.
Good job!
Sept 17, 2022 11:06:58 GMT
Biggest news is that I've actually driven the BMW this week. I did about 100 miles, all to and from work appointments. It's been a joy to drive, however I've noticed that the low tyre pressure warning lamp comes on sometimes (on two occasions) when the tyres are all ok. The light can be reset by pressing a button on the dash, so not the end of the world. Here is the BMW parked outside a lovely parade of shops that I had to visit in Maidenhead. Another thing I noticed was that the rear speakers were distorting quite badly, even with the bass turned down and at low volumes. I bought a pair of replacement 13cm Kenwood two-ways. And the correct fitment adaptors. Which all fitted together quite nicely. Getting to the rear speakers involves removal of the rear head rests. And cover grilles. I tried to fit the first speaker but it turned out that these lugs on the adaptors are too thick and prevent the original fixings from reaching the base panel. Out came the hacksaw. Then both speakers fitted a treat. They sound a lot better, clearer and with the frequency adjusted on the head unit, which prevents the lowest tones from reaching the speakers, there is no distortion. Win, but now I need to do the same with the front speakers. The original speakers are of poor quality, which is surprising, as the original speakers fitted to my 2003 MINI Cooper S sound a million dollars. The cheaper car got the better speakers? Odd.
Last Edit: Sept 17, 2022 13:00:33 GMT by Peter C
I was proposing on buying and installing 2 x 12" Pioneer sub woofers, which come in an amplified box, which cost £400 and would sound absolutely awesome. However, someone offered me a single 12" Edge sub and amp bombo for peanuts, which will do me for now. I fitted it today. I started by extending the RCA and remote cables from the back of the head unit. Not difficult but very fiddly. Then I removed the sill cover to allow the cables to pass towards the rear seats and eventually into the boot. I tested the sub when I first got it and noted that the boot panels were vibrating and causing a lot of buzzing. Nothing says class more than a fat bass line mixed in with an assortment of rattles. I removed the nearside boot trim. And lined whatever I could with stick on sound proofing material. I did the same on the other side... Being very careful not to disturb any of the electrics. I also lined the inside of the boot lid and the underside of the rear shelf. Apart from adding sound insulation, installation of the insulation material has made the fit of the boot linings a lot tighter, which reduces vibration and thus annoying buzzing. I was planning on using some high spec power cable that I had leftover from a previous installation, however the connector would not fit on the amp terminal and the cable wouldn't fit inside the recess on the side of the box. Shame, it's decent cable. I extended temporary cables from the battery, which is conveniently located in the boot and wired up the sub. I haven't finalised all the gain / frequency / boost adjustments but first impressions are that it sounds ok. It's nowhere near as loud or punchy as the JBL sub that I have in my Mini Cooper but it will do for now. All the hard work is done so fitting a replacement sub / amp in the future is not going to be a problem. The other good news is that the sound proofing material has done its job and there are no more annoying rattles coming from the boot. I still need to upgrade the front speakers and tweeters.
Oct 15, 2022 15:58:31 GMT
I left you last week saying that I need to make some adjustments to the subwoofer's amp controls to get more out of it. This was partially true. The amp has three knobs to fiddle with. Regardless of how I set up the amp, the bass wasn't anywhere near as good as it should be. I went back to check the settings on the head unit. The Kenwood head unit has a built in crossover, which provides control of bass frequencies that are delivered to the front and rear speakers. Clever but not clever enough. It turns out that the setting for the rear speakers also applies to the signal that is delivered to the subwoofer (via RCA cables). Last week I set the crossover to prevent the rear 13cm speakers from playing low frequencies, however in the process, unknowingly, this arrangement also prevented the bass frequencies from reaching the subwoofer. By switching off the crossover, the subwoofer started to subwoof but the rear speakers were also sounding strained. I had a plan. Before sorting out the subwoofer signal issue, I first fitted replacement front speakers and tweeters. I bought a pair of the same Kenwood two-way 13cm speakers that I fitted in the rear, as well as the same fitting adaptors. I had a pair of tweeters, which I bought for my W124 a few years ago. Removing the driver's side door panel was fairly easy. The original speakers aren't great. Not wanting to fix the speaker to the adaptor twice, I cut off the plastic lugs from the adaptor first, as was needed when fitting the rear speakers. Turns out that the three holes in the adaptor only lined up with two screw holes in the door panel. I separated the speaker (argh!) from the adaptor and cut a section of the adaptor to make it fit. I removed the original tweeters. They were hopeless or blown. Or both. These are the tweeters that I had, they sounded ok in the W124. I didn't want to damage the door panel so I had to be creative when installing the tweeter. I ended up securing it with one cable tie and two original screw fixings. It doesn't look pretty but it's solidly mounted. I refitted the foam padding that covered the back of the original speaker. I wired up the speaker and tweeter and tested the installation before refitting the door panel, which was relatively easy to put back. Then I did it all again on the other side. With the front speakers and tweeters installed, I removed the head unit and re-wired the speakers cables. I have connected the front and rear left side speakers to the front left output cables and the front and rear right side speakers to the front right output cables. I have taped up the redundant left and right side rear output cables. The benefit of this arrangement is that I can now set the crossover for all four speakers (and the tweeters) so that they do not receive any bass frequencies, whilst concurrently the subwoofer amp is fed a full bass signal. The disadvantage is that I cannot control the fader between the front and rear speakers, although that is a function that I never use anyway. I am no expert when it comes to Ohms and watts but I suspect that the 4 x 60 watts internal amplifier will be happy sending high and mid signals to four speakers and two tweeters from two front outputs. Also, I will never crank the volume up high enough to stretch the amp's abilities. The sound quality is now superb. The speakers and tweeters all sound clear and the bass coming from the boot is solid and loud. Win? Not quite. I tidied up the garage, had a cuppa, went to start the engine and... Click click click from the starter motor but no go. The battery died. Not surprising really as the BMW has been parked in the garage untouched for a week and I spent half a day sitting in the car with the interior lights and music on. I've hooked up my battery charger and need to finish this update now as it's time to go back to the garage and see if the old Bimmer will start. Wish me luck.
Oct 15, 2022 16:29:42 GMT
Woo hoo! The battery charger did its trick, the engine started first time. I’m off to see my parents in London tomorrow and I’ll take the BMW, it will benefit from a 50 mile round trip. Good bye for now.
Oct 16, 2022 15:15:09 GMT
The planned trip to visit my parents in London was cancelled so I took advantage of a free afternoon and took the BMW to Aldbury, then to Buckingham via the A413. Looking pretty in my favourite spot just outside Aldbury. On route home there was time for a McCafe and another photo. Great day, great drive, great car with a great sound system.
Oct 16, 2022 15:28:54 GMT
Looking super sharp 😎
Oct 16, 2022 15:36:08 GMT
I wasn’t looking for a modified car when I was searching for an E46 coupe but I must admit that the stainless steel exhaust and lowering springs fitted by the previous owner make the car sound and look much better than standard.
Oct 29, 2022 11:32:02 GMT
On a couple of rare occasions, when my wife or son sat in the passenger seat, the airbag light flickered on and off. A bit of research revealed that the sensor mat within the seat squab is defective. This guide is very useful: andybuck330d.blogspot.com/2012/02/e46-passenger-seat-occupancy-sensor-bypass.htmlI bought a by-pass sensor from EBay for a fiver. The seat is easy to tilt back, just undo the front and rear fixings. It is possible to do the job with the seat in the car, however by undoing a multi-plug, the whole seat easily lifts out. With the seat out of the car, unplugging the sensor mat and attaching the by-pass sensor is very easy. With the seat out, I gave the carpet a good hoover. I like a clean car, even those areas that aren't on show. With the seat reinstated, I fired up the engine, sat in the passenger seat and the airbag light has stayed off. Job done. I wouldn't call this repair a bodge. The by-pass sensor tricks the ECU into thinking that there is a passenger in the front seat even if there isn't one, so from a safety point of view there are no compromises.
Oct 29, 2022 14:14:29 GMT
In other news, my auto electrician friend turned up today and fitted the boot release switch that I did such a great job of a couple of months ago. Turns out that the diagnosis and remedy were both spot on but my execution was below par, I wired up the wrong cable to the switch. The master at work. The switch is fitted and works just fine.
Nov 12, 2022 15:23:13 GMT
