qwerty
Club RR Member Number: 52
Sept 6, 2022 15:24:21 GMT
Some advice needed regarding front hub to strut bolts.
When I took it all apart one of the original bolt heads was completely rounded and one had been replaced with a bolt that was too short and didn't pass through the nut, which had been filled with black mastic π¬. I've put some high tensile (10.8 I believe) M12x1.5 bolts in with nyloc nuts. Will this be OK? Should I add washers?
Should I just buy some proper bolts? I thought that would be a simple affair, but I've just been to Toyota (I thought Toyota suspension Toyota Bolts) and they wanted Β£65! Extensive googling has only resulted in confusion.
Tom
Davey
Resident Tyre Nerd.
Sept 6, 2022 15:31:53 GMT
Looking at a picture of the coil over, are they a 2 bolt at the bottom type or is that a stock image? If so you should be fine.
If they have a single bolt clamp at the bottom you want a bolt with an unthreaded shank.
qwerty
Sept 6, 2022 17:01:06 GMT
Looking at a picture of the coil over, are they a 2 bolt at the bottom type or is that a stock image? If so you should be fine. If they have a single bolt clamp at the bottom you want a bolt with an unthreaded shank. Two bolts a la Mk1/2/3 Golf etc etc etc. They're 'camber adjustable' I.e the top hole is slotted, if that makes any difference.
Last Edit: Sept 6, 2022 17:02:20 GMT by qwerty
I would use a washer on each side, the bolts will be fine, I usually try and use of ones with a decent length shank on but it's not critical.
Davey
Resident Tyre Nerd.
I would use a washer on each side, the bolts will be fine, I usually try and use of ones with a decent length shank on but it's not critical. This ^^^^ I meant to mention the washer!
qwerty
Sept 7, 2022 11:16:08 GMT
I would use a washer on each side, the bolts will be fine, I usually try and use of ones with a decent length shank on but it's not critical. I'll stick washers on them all when I'm re doing the alignment. The shanked bolts I have the shank is too long, or the threaded section too short depending how you look at it, although with a washer on each side it might be OK.
Last Edit: Sept 7, 2022 11:16:36 GMT by qwerty
Sept 7, 2022 19:52:45 GMT
This looks soooo good! I have a massive soft spot for all of the suzuki's and making practical reliable dailies less practical and reliable is so much fun!
qwerty
Sept 8, 2022 14:43:04 GMT
It's mocking me sitting on the drive so well! Hopefully have it roadworthy again on Saturday!
Davey
Resident Tyre Nerd.
Sept 8, 2022 15:52:05 GMT
It almost looks like it has a body kit from that angle.
qwerty
Sept 11, 2022 12:54:33 GMT
Sorted the alignment as best I could this morning. Then fitted the black boot plinth. Then maiden voyage to Lidl for shopping: Was a stressful drive, but fairly uneventful. Sounds like the front passenger spring is binding on the top mount. So I'll have a look at that this afternoon. Then this week I'm going full alignment and some 45 profile tyres for the front. If I get time I'll try and sort the droplinks as well.
lord13
Sept 12, 2022 5:34:55 GMT
Good to see it out and about, I think the black rear panel looks great and those wheels suit it really well... The rear lights actually work quite well with the colour, they stuck out like a sore thumb on mine but with a silver car they kinda blend in.
qwerty
Sept 12, 2022 6:10:08 GMT
Good to see it out and about, I think the black rear panel looks great and those wheels suit it really well... The rear lights actually work quite well with the colour, they stuck out like a sore thumb on mine but with a silver car they kinda blend in. Cheers, I'll try and get some better pictures this week. For the rear lights I've ordered some red tinting film. I'll give it a go and see how it looks.
Davey
Resident Tyre Nerd.
Sept 13, 2022 11:37:08 GMT
Good to see it out and about, I think the black rear panel looks great and those wheels suit it really well... The rear lights actually work quite well with the colour, they stuck out like a sore thumb on mine but with a silver car they kinda blend in. Cheers, I'll try and get some better pictures this week. For the rear lights I've ordered some red tinting film. I'll give it a go and see how it looks. I like this idea, they look very 90's halfords standard.
qwerty
Sept 18, 2022 15:13:47 GMT
Sept 18, 2022 15:43:52 GMT
Pap'd it today, looks brilliant in the flesh!
zeberdee
Club RR Member Number: 2
Sept 18, 2022 17:34:19 GMT
Saw this today , looks really smart .
Everyone in the group i was with said the same thing , looks amazing & theyβd never have thought one had that potential .
π
qwerty
Sept 19, 2022 6:49:53 GMT
Pap'd it today, looks brilliant in the flesh! Saw this today , looks really smart . Everyone in the group i was with said the same thing , looks amazing & theyβd never have thought one had that potential . π Cheers chaps! I had planned to wind the coilovers down when I arrived to make it look cooler. Really wish I had because maybe I would have noticed the rubbing brake line and would be home now and not in Donnington Services travelodge waiting for my legend of a mate to come collect me with his trailer!
qwerty
Sept 19, 2022 15:49:19 GMT
Well after setting off from RRG at about 4.30 yesterday I got home at 1ish today! Massive shout to my mate Mark who set off at 5.30am today to come get me. Since getting home I have replaced the brake hardline and flexi, so it's all sorted once more.
Last Edit: Sept 19, 2022 15:50:02 GMT by qwerty
lord13
Sept 20, 2022 13:04:28 GMT
Pap'd it today, looks brilliant in the flesh!Β Who would've thought that the humble Liana would get this much love π I should've popped down in mine I'm only up the road π
qwerty
Sept 20, 2022 13:55:09 GMT
Pap'd it today, looks brilliant in the flesh!Β Who would've thought that the humble Liana would get this much love π I should've popped down in mine I'm only up the road π Gotta say I'm growing fairly attached to the daft thing. All the issues have been of my own making really and fundamentally it's a great car. Practical size, comfortable to drive, decent MPG and now it even looks OK π
