speedy88
"Nice Cortina mate"
Club RR Member Number: 118
(Mostly) abandoned rail infrastructure anyone? They say it's a small world, I have seen pictures of this bridge taken by my work colleague when he vistited his son who moved to Canda. Up to recently it was very popular, it's close to the highway and only a 15 minute walk to the top. It's still illegal to be there though and it's been removed from Google so it's less popular these days.
Last Edit: Dec 4, 2023 4:12:21 GMT by speedy88
speedy88
"Nice Cortina mate"
This car is nasty. The rats made themselves a nice little den. You're not meant to vacuum rat turds but I did it anyway. Just need to cut into the solids before I can get inside this thing. I let it all air out for a few days but the rat urine smell persisted. So time to get it all outside. The interior is ok-ish and I'd like to keep it if I can. 10 parts bleach, 1 part water right? I soaked it all and left it outside for a few hours before hosing off. For the metal, I soaked it down with bleach and soaked it all up with paper towel and threw it all away. Check out that floor! I love rust free PNW cars. Returned outside to drag all the interior back inside. First time I've ever seen maggots in an interior, this was the area under the rats nest. I will try my hardest not to set it on fire, but this part of the carpet might be too grim to save.
speedy88
"Nice Cortina mate"
I was told the engine in this is seized, turns out it's not. It comes with the standard 20R truck engine, not very refined but it'll be handy to have the car driving around before I start doing custom work. Otherwise it'll become a jackstand ornament. I also have a spare 22R to go in worst case. Speaking of rats nests: There is a bunch of wiring straight up missing along with some "custom" wiring for janky starter buttons and the like. I felt a little disheartened at first but with some encouragement from friends I worked it out. It only took me about half an hour to trace out the important things. Some mysteries remain but it'll go. Next, compression test and bolt on some manifolds and accessories to see if it'll run.
speedy88
"Nice Cortina mate"
Compression test was 90, 90, 90, 90 which is at least consistent. I'll need to source or cobble some manifold bits to make this engine run assuming the distributor is going to fit from the 22R. Will update once I've run around the island collecting some parts.
speedy88
"Nice Cortina mate"
Feb 28, 2024 18:29:52 GMT
I picked up a couple of ex-rental scooters last year as a side project while I was working out logistics of the Celica. The idea was to make a light Gentsuki build to pootle around in the summer Interesting point is that the Razz was super budget and didn't even come with CVT. It just has a fixed gear and slips the clutch always. I decided to do the old favourite of RR - Montana Black. It's not something that people really consider here but the paint was half the price of automotive. I find the light blue is a nice finish but the yellow is very chalky and picks up dirty fingerprints too easily and is challenging to clean Yamaha Razz's are notoriously slow, but this example is particularly tired and needs an engine swap ideally. In my search of a vertical jog engine (direct swap) I found a later horizontal jog which won't be a direct swap but it was cheap and a better bike overall. The guy selling the black Jog was super sketchy. There's a chance the bike may be stolen from a long time ago, I guess I'll find out when I try and register it. One thing he kept saying over and over is that the bike is STOCK and NOT MODIFIED. Spoiler: It's very modified. It's fast. It feels faster than some 150cc scooters I've ridden. Seems like a weird thing to lie about, but the ride home was uneventful other than the wheelies. I ordered a JDM taillight from yahoo auctions and removed the suspension and it looks a lot cooler now. Graphics and paint coming in spring but it's ready for the first ride!
speedy88
"Nice Cortina mate"
Feb 28, 2024 18:50:11 GMT
I love the 1970s puddle jumpers here. They're a wild ride but you'll save a lot of time
speedy88
"Nice Cortina mate"
Feb 28, 2024 19:29:54 GMT
Compression test was 90, 90, 90, 90 which is at least consistent. I'll need to source or cobble some manifold bits to make this engine run assuming the distributor is going to fit from the 22R. Will update once I've run around the island collecting some parts. Head or block is cracked, so I ripped it out 22R is in. The heads don't flow as well as the 20R so a favourite mod is to put the 20R head on the 22R block which unlocks 20 or 30HP. Once I determine the status of the 20R head I'll consider it. There's two parts to this. I'm also swapping subframes so I can have a steering rack. Steering boxes are no good for drifting. Top one is new, bottom one is old: The new one is from a RA64 Celica and mine is a RA42. With this installed it should in theory turn my Celica into an AE86 with a longer wheelbase. You'll notice there are some differences, especially where the engine and chassis mounts line up Old New The 22R clearly sits 2 inches further back in the RA64. I didn't get a picture of it installed yet, but I've lined up the subframe with the hole for the front chassis rail hole. Here is the experiment: In comparison, this will give me around 1 inch of extra caster. GR9 for drifting and I have room to adjust it back if it ends up being too much/too snappy. The RA64 subframe is slightly wider too and I should have a 2 inch wider track which is good for angle mods and drifting stability. I'm also happy that Toyotas of this era have adjustable caster arms and the LCAs are made of pressed steel, so super easy to modify. I didn't measure any of this because I'm lazy but it all worked out fine by accident. To accept the new subframe I had to install a forward oriented sump. Also, a friend messaged me and said he'd found a louvre in a liquidation sale for my car: Pwoar, etc.
Club RR Member Number: 160
Loving the colour combo on the scoot. Looks actual rad. Meant to post the other day and have a proper read of the updates but forgot until today. Louvre is super cool. What a find! Keep the updates coming as they come man.
Awesome stuff dude. The scoot looks wicked.
speedy88
"Nice Cortina mate"
Tercel. I Need to move some motorcycles/scooters this summer so need a tow hitch. Most people here would see the need to buy a truck but the European in me makes me want to see what I can do with the smallest car. Due to my remoteness the options are build you own or buy $400 worth of hitch. And even then they all seem to be 1-1/4″ which limits options for silliness. Sure you can get converters but it adds leverage. I sent a cartoon drawing on a cereal box to a friend from the racetrack and a few months later this turned up. It ended up fitting perfectly! Now I have further evil ideas about getting a tow dolly for short haul trips
Last Edit: Mar 17, 2024 4:30:55 GMT by speedy88
speedy88
"Nice Cortina mate"
Subframe is in with the new engine. I don't really have any pictures yet so take this one from half way: Subframe is much wider and I've mounted it further forward for ease of install. I didn't plan any of this because I'm lazy, but it accidently turned out fine. So more camber and caster. I could have ordered some custom coilovers I guess? It would have been at least $1200. And I'd STILL have to weld them. Or I could make my own. I did a bunch of research about what I could do. Some local friends used E46 coilovers which fit inside their KE70 wagon front hubs. I knew Celica would be different and I knew I wouldn't know until I had it in my hands so I went ahead and bought some ebay specials: I got brave and went past the point of no return. It turns out that the bottom of the coilovers is exactly the same diameter as the factory damper housing. However, some test fitting showed that I NEEDED to have at least 1 inch protrusion above the knuckle to be the correct height. Meaning if I did as per the KE70 mentioned earlier, it would be too short. I wanted to be as safe as I could be with the tools and materials I have. I figured that the car is sketchy anyway and isn't going to spend much time on the road so I'll try not to feel too guilty. I butt the coilover against the damper housing tube and then found a pipe to sleave the two. First time welding to forged steel and I had no idea what was going to happen. So I did a bunch of pre-heating and I was surprised - it welded really nicely! It's all in the prep I guess. It was nice watching a weld pool chase the torch in one continuous line rather than the spot weld overlay that I normally do for bodywork. It's hard to describe this so here's a diagram: Being that this is the internet and I uploaded a picture of welding that isn't stacking dimes: remember the context. Drift car. Not a daily. I live on an island where the speed limit is 30mph. Did I mention it's a drift car? To answer the question - what coilovers do I use on my 1980 Celica? E46. Infact, I'm willing to say that's the cost effective answer for all 70s/80s Toyotas these days.
Last Edit: Mar 17, 2024 5:35:19 GMT by speedy88
speedy88
"Nice Cortina mate"
I wasted 4 hours trying to make seat rails and only after a few attempts did I realise seat + rails + me + helmet aren't going to fit in such a low roofline. I'm not even tall! So instead I opted for something I said I'd never do - found a comfortable happy medium driving position and bolted the seat in directly. Geez the factory seats are such whiplash specials. I've given myself some room to drop the butt of the seat down further if I need to, but I'll need to drill some holes down the line. For now, it's OK to get the car rolling.
Last Edit: Mar 17, 2024 5:18:29 GMT by speedy88
Cut and sleeved and not part of the car after coming off the road at lots of mph,jumping 40ft through the air and landing in a plowed field. Everything broke/bent apart from the welded area.
Mar 18, 2024 22:35:48 GMT
So much automotive excellence! Everything in this thread makes me happy THX!
Mar 24, 2024 17:04:15 GMT
Following with interest. Are you on Vancouver Island? I have had a similar path of; UK, NZ and now in Whistler.
Every time I've been on the Island there seems to be a cool car scene, far less of a rust hot spot as well.
speedy88
"Nice Cortina mate"
Following with interest. Are you on Vancouver Island? I have had a similar path of; UK, NZ and now in Whistler. Every time I've been on the Island there seems to be a cool car scene, far less of a rust hot spot as well. Yessir! They very rarely spread salt here, only 3 or 4 days a year. Car scene is great and weirdly engrained into government (look up Deuce days, it has also bled over into the lowriders and other "downtown Victoria" car scenes). Please tell me more about where you were racing your Volvo and what series it was. I'm thirsty for rally and will consider the ferry trip to do some dirt skids! Also, I've found an event in Washington State that looks very similar to RRG called "The Old School Reunion" which I'm considering checking out this year.
speedy88
"Nice Cortina mate"
Suspension in, all angles look good. I was able to dig out some slightly shorter LCAs which has switched the camber from slightly ridiculous to useful. I tentatively put it on the ground for the first time and I had a nice mojo boost: I'm entering into the actual fun areas now, so I have to start thinking about parts for the intermediate shaft between the column and the steering rack
speedy88
"Nice Cortina mate"
Time to put together a rear suspension setup for the next few months. I'm trying to keep the project in the spirit of using whatever I have lying around. From left to right is: Factory Spring, 350Z factory spring, chopped factory spring, E46 7" lowering spring The 350Z spring is the correct diameter and is much stiffer. To get the ride height I want it's going to be even stiffer so I'll need to think about some Teins or similar in future but for now it's fine. I chopped 2 coils off the 350Z springs. My front coilovers came in a kit with some adjustable rear E46 dampers. Using some drill action they sleeve over the factory mounts so I will use these for now. They're way too long, but maybe I can move the telescopic shaft further inside later. I'm going to bring the fronts down once they've settled. But otherwise I'm quite happy with how it looks:
Last Edit: Mar 27, 2024 4:30:23 GMT by speedy88
Mar 29, 2024 19:28:22 GMT
Almost forgot, this was my first car when I arrived to get the true North American experience. It was great! But 9mpg was killing me and it was too big even for Canada, so I sold it after a few months. But glad I had the experience. Is this a Buick Electra? My dad had one, very rare car in the UK. We managed an impressive 12mpg if I remember right.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
speedy88
"Nice Cortina mate"
Almost forgot, this was my first car when I arrived to get the true North American experience. It was great! But 9mpg was killing me and it was too big even for Canada, so I sold it after a few months. But glad I had the experience. Is this a Buick Electra? My dad had one, very rare car in the UK. We managed an impressive 12mpg if I remember right. Basically yes! These later ones were specifically designated to a model called the "Estate Wagon" but they're all the same junk haha. I did 14mpg once, not sure how. The wind must have been behind me in both directions.
