Apr 10, 2024 21:04:46 GMT
The cam runs in the block - no idea if it has separate bearings, the Haynes manual doesn't show any.
I did look up at the cams and they looked great though, no signs of wear or scoring on the lobes
Apr 10, 2024 22:14:31 GMT
That oil pump looks well past the newness wearing off stage. Did you check for side to side play of the shafts in the housings?
Apr 10, 2024 22:22:51 GMT
Not checked for side play yet. But yes, it does look quite chewed up. When I swapped sumps and pickups a year ago I wasn't looking that close, but I am sure I would have spotted the wear if was that bad at the time.
Fortunately, I have a spare front housing (which contains the oil pump) along with a spare set of pump gears. Not looked at it for a decade, but I will fish it out of the shed, give it a clean up and hopefully I can swap them over. The pump cap looks fine (a few circular marks but that is quite common).
Apr 17, 2024 19:25:33 GMT
bearings don't look too bad but the oil pump is not great which would suggest the filter is doing a good job, any clue as to where the metal is coming from?
Update time Kevin - I have found a few culprits but no totally smoking gun. Engine is in bits in the shed ready for new bearings and oil pump. I ordered a load of parts from Germany, which arrived earlier in the week, but they sent me the wrong main bearings, so that has set me back a week while I ordered some from the Czech republic. I found some wear to steel parts in the fuel pump, and what looks like a delaminating pump diaphragm. I think I have had two issues going on 1 - fuel leaking into the crank case and messing up the oil causing bearing wipe, and 2 - steel fragments from the fuel pump going through the oil pump. I think the glitter is a combo of bearing material and aluminium from the oil pump. I can't see anything else wrong so that is my current working theory. I have a follow up question regarding bearing clearances. The haynes manual says that the main bearing clearances are 0.016mm + 0.065mm. I am reading that as minimum bearing clearance is 0.016mm, what is not clear is whether the max clearance is 0.065mm OR 0.016mm + 0.065mm giving a total max clearance of 0.081mm? Not sure it matters much as the clearance on the worn bearings was 0.04mm ish so within spec whichever way you look at it. I will re-check with the new bearings and don't expect the clearance to be any larger, but would like to know for sure what max clearance is. Any help decoding the spec? Thanks
Last Edit: May 2, 2024 21:25:27 GMT by lewist123
That spec is oddly written. On older engines I tend to aim for one thou of clearance per inch of journal as a maximum, so you'd be at 2 to 2.5 thou (.050-.065mm roughly) on a 60mm journal. It'd work at just over 3 thou clearance (0.081mm) but it'd be enough to show a noticeable drop in oil pressure when hot in my experience.
Fuel contamination of oil is the number 1 cause of engine failure that I see, so the fuel pump problems seems like a good diagnosis of the root cause of the damage you've experienced.
Yeah it is weird. If it said 0.016 to 0.065mm I would understand!
Based on your numbers there, it would appear that perhaps 0.065mm is the max tolerance, and I will work on that basis.
Thanks
Lewis
