They changed to a remote gearchange instead of the column shift as well I also believe (if Wikipedia is owt to go by) the A35 was so called 'cause of its massive hike in hp to 34bhp! Forgot that one. A30's weren't column change but had the leaver coming right out of the top of the box up towards the front of the floor. The A35 gear box had an extension to bring the base of the lever further back. Useless fact of the day. All Austin "A" numbers refer vaguely to the quoted bhp of the car. That's why there are similar bodied cars with different A's and thinks like A55 Mk1's and A55 Mk2's
Feb 22, 2008 10:56:26 GMT
Really interesting trivia 2002gimp & Seth Often got muddled up as the Farina is an A35 - I presumed the older bubble shapped cars were A30s & the newer shaped car A35s, didn't realise the number dictated engine output Now its all clear(er) & I can show off my new found knowledge the next time I go to a country fair/classic car show That means that when you fit a bigger more powerfull engine you'd have to change the cars name ....... A120 FTW ;D
horney™
Feb 22, 2008 11:07:08 GMT
If you want to go big budget you can pop the MG Metro Turbo setup on which can run upto 150bhp pretty easily. Same problems, I imagine - FWD to RWD. All possible, natch, but not in any way bolt on. Not true fella. The turbo setup is all in the head, manifolds and carbs, you'd need to lower compression with either a plate or head work to run low boost. If you want to run high boost you'd need to change the pistons and probably the rods to but it'll bolt on any A series no matter where the gearbox attachs. A mate of mine has an MG turbo set up that he's hoping to pop on his Midget at somepoint in the future. Nick
bazzateer
Imping along sans Vogue
Feb 22, 2008 13:31:50 GMT
If staying with the A series go for the Ital A+ 1275 plus a Shorrock supercharger as fitted to Sprites etc. You can fit a Sierra 5 speed using an adapter too. Spridget front suspension and brakes bolt straight on.
LowStandards
Feb 22, 2008 13:43:48 GMT
I'm going to look at her on sun, will keep you informed of the result!
Ether
Feb 22, 2008 15:12:26 GMT
Rumour has it that the Spring issue of Practical Classics has a big buyers guide on the A35 (out March 26)...
Feb 22, 2008 15:39:14 GMT
Am I right in thinking that the 803cc had white metal bearings and so it's a fan of long periods of thrashing? Or did I make the mistake of believing possibly the most boring Moggy owner that I've ever met?
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
Feb 22, 2008 15:50:19 GMT
It has white metal bearings, no cam bearings at all, has the smallest bore of ANY A series, and is hopelessly fragile. White metal bearings are not a good thing.
Feb 22, 2008 16:11:23 GMT
Darn. That means that he was right!
Feb 22, 2008 16:35:01 GMT
It has white metal bearings, no cam bearings at all, has the smallest bore of ANY A series, and is hopelessly fragile. White metal bearings are not a good thing. Indeed - 803 = boat anchor 948s are nice, especially the Sprite Mk2 spec units, as these have proper cam bearings, double valve springs etc already fitted
LowStandards
Feb 23, 2008 18:08:47 GMT
Booo, just got a mail fromt he bloke, he's sold it off ebay! If its one of you lot i'm coming round to have a word That is of course, unless your bigger than me, in that case... fair play!
Jul 14, 2017 18:35:07 GMT
Very late in the day, but I have just read this thread.
I know of only two turbocharged A35,s, one of which is mine.
I have around 140bhp and get up to 40 mpg. It does 15.9/91mph and is totally reliable (after a year or two of development)
The worst aspect is the steering, but converting to rack and pinion is not a process for the amateur -ask me how I know.
Still lots of fun though !
Rob M
Club RR Member Number: 41
Jul 14, 2017 19:15:07 GMT
Very late in the day, but I have just read this thread. I know of only two turbocharged A35,s, one of which is mine. I have around 140bhp and get up to 40 mpg. It does 15.9/91mph and is totally reliable (after a year or two of development) The worst aspect is the steering, but converting to rack and pinion is not a process for the amateur -ask me how I know. Still lots of fun though ! If there is no thread for this we need a thread for this!
v8ian
Very late in the day, but I have just read this thread. I know of only two turbocharged A35,s, one of which is mine. I have around 140bhp and get up to 40 mpg. It does 15.9/91mph and is totally reliable (after a year or two of development) The worst aspect is the steering, but converting to rack and pinion is not a process for the amateur -ask me how I know. Still lots of fun though ! If there is no thread for this we need a thread for this! Yep, I want to see it too,
