These have just arrived. Another ebay special. If I have enough time I want to get these fitted before Sunday as I just found out there is an autotest on and its a pretty local one at a new venue (well new to me anyway), but got to paint the wing on my Trooper so I can get it ready for sale this weekend, fit new discs, pads and shoes to my dads ZX and get as many tyres swapped over onto different rims as possible before I even think of that.
Jun 10, 2006 21:33:47 GMT
Just got finished. New electric fan fitted as it was getting a bit hot at the last autotest. Got all my tyres swapped on rims swapped over. Its been idling very low and even cutting out recently so quick investigation found an air leak from the air flow meter to plenum pipe(pipe has split). Taped up for now but I will have to replace asap. Fitted new plugs, plug leads and alternator belt. And fitted a new rear exhaut mount. See how I get on with it tomorrow.
bstardchild
Club RR Member Number: 71
1985 Opel Monza 3.0 GSEbstardchild
@bstardchild
Club Retro Rides Member 71
Jun 10, 2006 23:06:07 GMT
Just got finished. New electric fan fitted as it was getting a bit hot at the last autotest. Got all my tyres swapped on rims swapped over. Its been idling very low and even cutting out recently so quick investigation found an air leak from the air flow meter to plenum pipe(pipe has split). Taped up for now but I will have to replace asap. Pm me and I'll stick my spare in the post - no need of it anymore
Jun 11, 2006 20:11:20 GMT
Been autotesting again today. Noticed the Monza seemed to be developing a bit too much negative camber on the passenger side front so jacked it up and inspected and found a bit of play on the wheel bearing so I put it down to that. When I got it home decided to investigate a bit further and found this... Neggy camber Bad fitting bonnet (touch of foreboding as I know what to expect next) Strut top has started to break away from the inner wing Common ailment for Monzas mine and alot of them get scrapped because of it. It seemed pretty solid and it had been welded up before I got it, obviously the welding wasnt great and the abuse I have given it didnt help matters. Passenger side starting to go as well Need to get it in the garage, get it stripped down and repaired. Welding and reinforcing isnt the problem but getting it all lined up again is gonna be a b*gg*r. Biscuits Need to hurry to get it down to a decent standard before C.A.R.S. as I don't want to bodge it. One vid from the autotest here video.google.com/videoplay?docid=8897224451154045547
Jun 12, 2006 17:33:13 GMT
sheeet, bad luck there bud, I'm sure youll manage with your superhuman weldathon skillz ;D
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Jun 13, 2006 20:59:12 GMT
Right well I got it moved into the garage tonight after a right on moving other vehicles. As its probably going to be in the garage for a couple of weeks I decided to bring my frontera in to do some work on (none runner due to factory fit immobiliser ECU located somewhere behind the dashboard). The other problem being the back brakes were locked on solid. I had to use my trooper in the low box to drag the frontera and the back wheels were totally locked and just scrubbing the tyres. Dragged it up the drive then put a trolley jack under the diff to use as a dolly so I could push it were I needed it then wheels off, discs off and got the shoes freed off again (drum in disk). Then rolled it back down the drive moved the MX-5 out of the garage. Got the Monza towed the frontera back in then pulled monza in the garage. Then had to do some work on the suspension on my dads Xantia. So with all jobs done I am ready to crack on tomorrow night. Thanks once again to Bstardchild for a very good set of pictures showing some other inner wing and strut top repairs.
bstardchild
@bstardchild
Jun 13, 2006 22:34:25 GMT
Thanks once again to Bstardchild for a very good set of pictures showing some other inner wing and strut top repairs. 1. Glad to help 2. I hope you get on OK 3. Hope it gets to CARS I am sure that if you adopt the make it better "Hangmans Gallows" rather than repair what's there with more of the same you will be very pleased with the result
skudders
Keep it rear! and water cooled!
Jun 16, 2006 11:09:10 GMT
Very NIce don't seem to see many around these days.
4 Pages down . Took some finding after only a fortnight. As most people will have seen from the thread in the main category I managed to get it sorted and ready for cars. A few choice pics Braced up and ready for the off ;D Had to push the passenger side strut top out by around 15mm. Passenger side before cutting commenced All cut out and ready to go Passenger side finished Drivers side looking good Job done Got it all back together and first test ride around 3pm on the Friday before CARS. Panel gaps were better than any time when I have owned the car. but actually had a few other jobs to do and didnt finish working on it until 10 minutes before I set off Car performed faultlessly all weekend and averaged 32mpg on the 500mile round trip. Even had a nice play on the autotest @ the Pod A few vids of which are here Monza Vid 4Monza Vid 5Monza Vid 6Full gallery of repair pics are here. All inner wing repair pics
Got my alternator belt tightened up correctly last night and started making a front strut brace needs a number of bends to clear plenum and brake servo so I am not sure how effective it is gonna be when complete. Decided to put my Koni dampers on the back as my standard ones are basically shot and the cars is driving in a Hawai 5-0 style. Old New Adjustable for rebound only and compression is about the same as standard but as my old ones are no where near standard now it should be quite a bit more controlled. Running it at around 3/4 maximum. Havent tried it on the road yet but there is a gymkhana type autotest tomorrow night so it will get its chance then.
Jan 17, 2007 18:26:45 GMT
Jan 17, 2007 19:25:02 GMT
Oh I needed that! Three days of driving a Leyland Daf 400 sort of leaves you yearning for a fiesty six pot petrol engine rather than diesel clatter!
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
bstardchild
@bstardchild
Jan 17, 2007 22:33:00 GMT
There should be more Monza related developments next week but not this one Go on post up a picture pleaaaaaase ;D
Jan 17, 2007 23:17:43 GMT
looking forward to seeing it on sunday
Jan 18, 2007 22:06:31 GMT
There should be more Monza related developments next week but not this one Go on post up a picture pleaaaaaase ;D I will do that when I start it looking forward to seeing it on sunday I need to get to a post office and get it taxed yet
Jan 19, 2007 22:23:59 GMT
I like that car!!!
Jan 19, 2007 22:28:02 GMT
Cheers Iain, and welcome
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Lovely Car Dude. Read from the start. Strut tops must have been a curse word!
Very nice, obligitory to see a Monza sideways at a rally over here!
keep it up
craig1010cc
Club RR Member Number: 35
1985 Opel Monza 3.0 GSEcraig1010cc
@craig1010cc
Club Retro Rides Member 35
I used to have a 78 monza 3.0E (and my dad had 2 GSE's), it was ace. used to be like driving a sofa with the V soft susension and the velor armchairs. But as it had an open diff I could never get it to slide very much, just used to roll ;D you certinaly can slide your's though,makes me want another
Jan 20, 2007 21:44:25 GMT
