Excellent work! Innovation goes a long way. Id love to know more about how you were able to link up the two gearboxes to shift in tandem using one gear stick. Did you have problems here, or was it ok? Cheers! Graham
1974 Skoda S100 tarmac car 1998 BMW 750 daily 1994 Mitsubishi Evo2
WOWser bet thats gonna shift, top work
once again rocking with 1117cc and 4 gears!
VWDan
VW Jetta MK1, VW Caravelle 1.9TD, Audi A6 Tdi Avant
Good skills - look forward to progress pics.
If only everything in life was as cool as a retro VW racer.
street
6.2 ft/lbs of talk
Dec 20, 2006 10:41:27 GMT
Aah excellent, will be much easier to follow your progress now!
raymondmarble> i think all the details on twin-gearchange controls you need are in the gallery .
after completing front engine's cooling and exhaust systems, we hard-wired an external 405 fuel pump to start the front engine after several months of being out of use... it started without problems, apart from expected noisy hydraulic lifters. 205 Mi32 :: video #001 :: Starting the front Mi16 engine thanks.
Dec 21, 2006 11:26:49 GMT
good lord. I am speachless. Good work that man.
Dec 21, 2006 16:18:57 GMT
raymondmarble> I think all the details on twin-gearchange controls you need are in the gallery . Aha! I didnt realise they were links Many thanks, and GREAT work!
Phase 5: Rear Engine Electricity & Coolingthis is the first part of the Phase 5 story, where we tackle rear engine's wiring: and start plumbing the coolant pipes from the radiator towards the rear engine: you can find the first part of the story (with 25 pics) on THIS PAGE. stay tuned for the second part of the Phase 5 story! thanks.
street
6.2 ft/lbs of talk
Dec 29, 2006 13:58:15 GMT
Really excellent work! So you must be really close to it bieng finished now, can't be much left to do! Can't wait for the next installment! Have you ever looked at www.durocco.com for some inspiration? (bit late now but its well worth looking at!)
Dec 29, 2006 15:19:33 GMT
oooh, there IS A LOT left to do... believe me . ok, maybe not in grand scheme of things, just to get it running, but still... yeah i've been using durocco and boostbeast for inspiration but have gone a different route, as you can see . thanks.
in the second part of the Phase 5 story, we continue work on rear engine's coolant system: and after testing the wiring and all the sensors, we get the engine started: you can find the 2nd part of the story (with another 25 pics) on THIS PAGE. with work being spread over a few months, Phase 5 is finally complete!stay tuned for an exciting video of starting the rear engine! B) i want to wish all the members of this forum a happy and successful new year in health, love, business and ofcourse... cars! thanks.
after completing rear engine's electrics and cooling system, we attempt and manage to start the rear engine for the very first time! it started fine, with the grease on the exhaust manifold burning off a bit. 205 Mi32 :: video #002 :: Starting the rear Mi16 engine thanks.
Bloody awesome, saw your site a few month back but it looks like you've made loads more progress.
Hope you keep the body looking stock as it would be the ultimate sleeper!
wow, good idea to post up thumbnails too, makes looking at the pics much easier
hmm well i think the body will get a makeover too, but we'll see.
thanks.
Phase 6: Fueling System, Instrumentation & Miscthe first part of the Phase 6 story is all about making the fueling system: and doing misc work like an oil change, so we could start both engines together! you can find the first part of the story (with 37 pics) on THIS PAGE. a short video of starting the engines together coming soon! thanks.
street
6.2 ft/lbs of talk
Jan 15, 2007 12:12:12 GMT
Excellent progress as always Cybernck! The fuel tank is ace, i'm impressed that you had it built with a fuel level sender- thats one detail most people leave out but its very useful to have one! You drove it using the front engine only- have you made it so that you can do this all the time or was the rear engine just temporarily disconnected? I suppose you could have it so that the rear engines clutch can be locked on permenantly by using a hydraulic line-lock. I have also seen a golf that uses a gear linkeage that can shift either front only or front and rear simultaniously, but that must have been very complicated! Keep up the great work!
it takes 5 secs to pop off the rear gearbox linkages and leave it in neutral , but we're going to make a system that will allow to disconnect the rear engine from the driver's seat, later. this means that clutch and gears rotate causing a bit of drag, but it doesn't matter as the performance is not in mind when using just the front engine . however, you may have seen that we'd made a lock-off system for the rear clutch as well, just not installed it yet. thanks.
