Jul 18, 2019 12:40:15 GMT
Took diff over to Paul at Southern Axles who I can highly recommend. He confirmed the diff is in perfect order, so the clunk in reverse is just my paranoia Took it over in a bucket as it weights more than a small country - carrying it in and the bucket gave up, left the rim in my hands and the diff on the floor! luckily no harm done. Still, at least I got to give it a fresh coat of paint last night.
Jul 18, 2019 22:30:59 GMT
mmm....shiny New end shaft oil seals now fitted; Diff is now back in and half shafts fitted. Brakes done one side. How come I stripped in in an hour yet it has taken 3 hours to get it 2/3rds rebuilt??? Typically I had 5 litres of EP90 oil, wich was too much originally, now I have used it all and I'm about 1/2 a litre short Have to buy a load more tomorrow. PS, did I mention that diff is barstard heavy??
bstardchild
Club RR Member Number: 71
Jul 18, 2019 22:47:50 GMT
PS, did I mention that diff is barstard heavy?? 75 Kgs - that's bloody heavy...........
Jul 18, 2019 22:54:58 GMT
Not quite! - think it's 25Kgs, still difficult to lift into position though - even using a jack.
bstardchild
Jul 18, 2019 23:41:01 GMT
Not quite! - think it's 25Kgs, still difficult to lift into position though - even using a jack. 1st clue - How heavy do you think I am.............. 2nd clue - What's my username 3rd clue - nah really you don't need it
Jul 19, 2019 12:12:34 GMT
You lightweight you're all skin & bone
and attitude !
bstardchild
mmm....shiny Hold on - I expect to see perfect reflections on all your painted stuff - that looks a bit (how can I say this.....) Orange Peely??
Jul 20, 2019 13:35:31 GMT
see !^^^^^
Jul 20, 2019 13:41:12 GMT
mmm....shiny Hold on - I expect to see perfect reflections on all your painted stuff - that looks a bit (how can I say this.....) Orange Peely?? Personally I don’t think that’s up to Marks normal standard. I can see that failing scrutineering, can’t you Ian? 😉😂
bstardchild
Jul 20, 2019 13:51:11 GMT
Good point well made
Jul 20, 2019 19:04:36 GMT
Hold on - I expect to see perfect reflections on all your painted stuff - that looks a bit (how can I say this.....) Orange Peely?? Personally I don’t think that’s up to Marks normal standard. I can see that failing scrutineering, can’t you Ian? 😉😂 Why cant you let a good man finish the job first before commenting negatively - He has yet got to flat & four stage polish the paint once he has the diff fitted
Last Edit: Jul 20, 2019 19:05:09 GMT by Deleted
Jul 21, 2019 18:52:30 GMT
Yes, I have been quiet as I smoothed all the metal down since the photos and have laid on 4 coats - flatting in between and now polished up properly. It now is as smooth as the rest of the car.
bstardchild
Jul 21, 2019 19:23:01 GMT
Yes, I have been quiet as I smoothed all the metal down since the photos and have laid on 4 coats - flatting in between and now polished up properly. It now is as smooth as the rest of the car. I'm so sorry - I'm so used to you showing the finished result - I never expected you to show a picture which is work in progress - I knew deep down that it wasn't a finish you would normally accept
Powder coating.....just don't!! It's quick & easy but it's also a bit fox picture. Powder coated the little tube/brackets for front indicators under headlamps. Doing a little improvement on the headlamp rivets/mounts showed the brackets with nice rust creep all across the front under the coating. Great! Linished the coating off and now painted with epoxy primer & black gloss paint. It will need a couple of coats but at least it wont rust under the paint anymore.
bstardchild
Powder coating.....just don't!! It's quick & easy but it's also a bit fox picture. Powder coated the little tube/brackets for front indicators under headlamps. Doing a little improvement on the headlamp rivets/mounts showed the brackets with nice rust creep all across the front under the coating. Great! Linished the coating off and now painted with epoxy primer & black gloss paint. It will need a couple of coats but at least it wont rust under the paint anymore. I only powder coat suspension parts and the critical bit from my perspective is the blasting and the prep What I normally do is get the parts blasted then hot zinc galvanised - then powder coat over the top of that The result then is even if the component gets chipped it still doesn't rust
Jul 24, 2019 12:07:09 GMT
That would work.
I have only a few parts powder coated on the car - mostly fiddly bits that would be a bar steward to paint whereas the powder coating being electrostatic coats all surfaces.
There must have bee some pinholes in the edge of the weld or something that the coating did not get into.
Jul 25, 2019 22:09:30 GMT
Aarrggghhh!!!! someone took my eyes out!!! Doing some maintainance, fitting sealant under the chrome lamp upstands as they always trickle water after washing. Also bonding the indicator LED's into the steel tubes as they are not a tight fit and walk out of them a bit during driving. Now fully bonded in with black Tiger seal.
Davey
Resident Tyre Nerd.
Jul 27, 2019 10:43:44 GMT
Lovely to see this still getting worked on even after all the IVA rubbish.
I met a man named Glen recently who seems think he knows you.
Bright yellow Consul Capri with a honking great big block and supercharger hanging out of bonnet, sound familiar?
Jul 27, 2019 17:24:38 GMT
I'm not sure I know Glen, but yes I know his car.
