Jun 23, 2015 22:38:25 GMT
Maintenance time! Radiator is out to be re-cored, the only part on the car I have not had done properly yet. It worked ok but had a couple of tiny leaks so I'll get it re done with a more efficient core at the same time. Some new parts arrived today - hi spec Ferodo pads that have amazing stopping power if the posts from users on other forums are correct - lets hope they are cos they sure aint cheap! While brake pedal was out to replace the urethanes I took the opportunity to re-shape it to be a bit nearer the throttle pedal, didn't think I would be getting the spray gun out again quite this quickly! First primer coat on tonight.
Jul 15, 2015 23:13:36 GMT
New flat green LED's arrived with correct holder fitting, fitted these to the rev counter & speedo and they work really well. Not as bright in real life as in the photos so they wont dazzle me. Also got the aluminium (replacement for the urethanes) bushes turned up today and fitted to brake pedal - fitted to car now with the proper grease so that's never going to be an issue again. Also got some 60/75w Osram ultrabrights bulbs for better night vision headlamps - these are highly recommended as they last as long as OEM but are around 25-30% better for distance.
Jul 19, 2015 20:50:04 GMT
Got my radiator back from being re-cored so shot a couple of coats of Epoxy satin black over it. Fitted it back today and took it out for a run to the Uxbridge show and met up with the Head Gasgits, it now runs 5-10 degrees cooler with plain water in it, should run even better with antifreeze after I've flushed it again and checked for any leaks. Also met up with someone off here - had to rush off to see a mates car so sorry dude for cutting you short. When I fitted the brake pedal back I re-read the setup of the balance bar again and set it up a little better than before - what an improvement! front brakes lock up now and it really pulls up well. I probably need to put a little more balance back to the rears but its now how I want it in terms of effiency. Still got to do the last few bulbs in the roof dash, this is the conversion I'm doing which works out neatly.
Jul 19, 2015 21:10:27 GMT
Also met up with someone off here - had to rush off to see a mates car so sorry dude for cutting you short. No problem, great to see the car in the flesh. Really enjoyed the show, lots to see and a varied collection of cars, we were right down the bottom of the field, had 9 Coupes which was a good turnout for us.
1993 Rover 220 Coupe 1972 MG Midget
Jul 19, 2015 21:12:48 GMT
I was keeping an eye out for this to have a proper look while wandering around the fields, only to pass you on our (early) way out!
Jul 19, 2015 21:32:25 GMT
Hi Seth, though that was you on my way in.
Jul 22, 2015 23:13:01 GMT
Wooo, got the last gauges converted to LED's, different bulbs in these - grrrrr!! so some real micro surgery on the bulbs required - especially the vacuum gauge as it needed 2 LED's in that one to get it bright enough.
vulgalour
Club RR Member Number: 146
Jul 23, 2015 10:39:33 GMT
You wouldn't know you've done it now it's done, sign of a good job that.
Jul 23, 2015 21:01:59 GMT
Thanks Angyl, Got some spacers machined for the rear shocks to limit the travel a bit as they have more travel than I have tyre clearance- eek! Yellow things are progressive bump stops that also go over the shaft of the shock.
Jul 24, 2015 21:42:21 GMT
Some more pretty bits made, steering wheel centre machined up to replace the plastic one - I need to machine the centre logo - it's just a printed autoCAD logo at present. The shifter I bought s/hand and it never had a finisher for the centre so this was also machined up (with a quick printed centre again) Which fits in here like this; Another couple of little jobs completed.
Aug 31, 2015 10:32:44 GMT
Well no updates recently but the pop has now almost done its first 1000 miles already! No dramas, its getting better with use and the seats are surprisingly comfortable for racing seats. 2 hours straight driving home from Ipswitch yesterday and no numb bum or anything. Custom car has done a shoot on it for an upcoming issue which is nice. Only big issue is I have broken my allegedly bulletproof 9 inch diff
Aug 31, 2015 19:41:43 GMT
fer4l
Testing
Club RR Member Number: 73
Aug 31, 2015 20:19:52 GMT
Biscotem posterius maximus - not nice to see - too much welly, or spontaneous failure?
Good luck getting it sorted either way
Cheers
Matt
vulgalour
Aug 31, 2015 21:10:38 GMT
That's an unpleasant thing to see after all that work.
Aug 31, 2015 21:37:16 GMT
I thought 9" was indestructible?!
Aug 31, 2015 23:03:03 GMT
Me too Paul, aparrently not! This was a Curries LSD so I expected far more. Abuse which led to later spontanious failure. I did drive it for 250 miles like it though!!! At least it got me home. Will need to look at upgrading it to higher spec I think. Oh well, its only money
Rob
You know, for kids!
No warranty on that? Not like you've raced it or anything... right!?
Had an interesting chat with Andy Robinson from Robinson Race Cars last night, put my mind at rest on a couple of points. Pozi diff is only good for around 300 hp so my current one was not strong enough. The other point was its completely normal for car to spin or donut the way I was trying to burn out, I've now been told how to do it properly, lol so at least I know nothing is set up incorrectly.
He thinks the the bearings & CROWN/pinion should be re-usable (hopefully) but agrees that the stronger Daytona housing pinion is a very good idea. (annoyingly the original pumpkin I sold had a Daytona housing but I did not realise).
He said 31 spline would be ideal but understood that I already had the 28 spline Strange shafts so it's a bit of a compromise - hindsight is a wonderful thing with the knowledge I have now I would have ordered the correct parts but at the time I did not know so just assumed a "Curries" diff was a top notch item.
Well curse word I can no longer drive on the queens highway DVLA have rescinded my logbook so it's BIVA test time *sigh*
eh? How? Why?
