diff
Jan 30, 2022 15:00:49 GMT
I’ve not seen this before so just read the whole thing. I wish mine had the power this has. Mine just has a rattling old crossflow that’s on its last legs. Shame it’s got a bit rusty. Stuart Bird on FB makes the boot lip sections if you need any. He does a good few other repair sections too if needed Cheers for that I will look for him later. The reason I stopped using it on the road was a bit of rust on an outrigger , dug into it today .
diff
Jan 30, 2022 15:02:28 GMT
diff
Jan 30, 2022 15:06:39 GMT
Jan 30, 2022 15:56:12 GMT
I’ve not seen this before so just read the whole thing. I wish mine had the power this has. Mine just has a rattling old crossflow that’s on its last legs. Shame it’s got a bit rusty. Stuart Bird on FB makes the boot lip sections if you need any. He does a good few other repair sections too if needed Cheers for that I will look for him later. The reason I stopped using it on the road was a bit of rust on an outrigger , dug into it today . He does the outriggers too👍. When I did mine, one of the outriggers had been plated over 4 times. It was easier to cut the floor out and start again.
diff
Jan 30, 2022 16:08:02 GMT
I think I have replaced that outrigger twice already in the time I’ve owned it .
Jan 30, 2022 17:23:37 GMT
I made them out of 1.6mm steel. Should last a bit longer.
diff
Jan 30, 2022 17:39:11 GMT
I made them out of 1.6mm steel. Should last a bit longer. I did that with the inner sill panels last time , will have to follow your lead and do the with the outriggers .
Jan 30, 2022 17:54:54 GMT
When I did mine I couldn’t afford to buy panels so I made all the chassis rails from 1.6mm and painted them all inside before welding them on. I’ve cavity waxed it too so hopefully it should last a bit.
diff
Jan 30, 2022 18:01:14 GMT
