Mar 25, 2008 15:21:57 GMT
Interesting... what sort of minx had 15's on it? All the 60's ones that have passed my way have had 13s or 14s on them & I thought the old bubble shape 50's minxes were some sort of weird 3-stud pattern? Mid/late fifties to early sixties Minx (and associated cars) had fifteens. The later series cars had 13's. This was my '61 Rapier on its 15's I had thought about finding some newer steels to play with but I've got wheels now.....
Mar 25, 2008 15:47:33 GMT
16s on the back and 15s on the front ftw hehe. Aren't they super skinny 15x3.5 or something daft?
Matt
MartinC
Don't like stretched tyres, very low profile tyres & I think a car CAN be too low. Perhaps I'm odd.
Mar 25, 2008 16:23:17 GMT
the 15" are still same PCD as Ford. IIRC there were some 16" off something that also shared that PCD, but I forget what...
1937 Standard Flying Twelve
1943 Bedford OYD
1947 Cadillac Fleetwood Sixty-Special
1954 Hillman Minx MkVIII
1956 Austin A30
1957 Vauxhall Victor Super
2001 Chrysler 300M
2002 Rover 75 Connoisseur SE Tourer
Mar 25, 2008 20:18:44 GMT
i ran a hunter gl estate as everyday for five years with no troubles whatsoever, best motor i ever had for practicality... miss it like i lost a thumb when she went to scrapyard heaven to this day never did find out what bent it up outside my brothers house but it must have been bloody big
Mar 25, 2008 20:21:01 GMT
I'm running 405 pug steels on the sceptre so they are right pcd.. i ran my hunter on the wheels which came off my mk2 sceptre cause it had all new tyres on !! improved handling no end
Mar 25, 2008 21:21:54 GMT
Cool wagon Seth Take a look at Rally design and their coilover conversion kits, should be dead easy on that strut
Mar 25, 2008 21:26:48 GMT
Cool wagon Seth Take a look at Rally design and their coilover conversion kits, should be dead easy on that strut All in hand ;D
Mar 25, 2008 22:18:07 GMT
I've got a pair of 15" rims of an earlier series Minx in my mum's shed. Being very tempted to go down that route for a giggle! ;D oh please please do it, itd look fantastic
Mar 27, 2008 20:03:52 GMT
The weather over last weekend meant I wasn't able to make a start on the bits of bodywork I wanted to do but I have found time for a few little bits and bobs. Oh and the credit card has done some work I continued stripping down one strut - I'm leaving the other in one piece so I've got it for reference. The shock insert is held in place by a threaded bung at the top which is peened by one of the notches to prevent it working loose. So some attention with various hitting/poking devices and I could undo the bung using a hammer and punch to rotate it. Once that is out all the innards can be removed and dismantled. The glass jar contains the old shock oil. Well to be precise it contains most of the shock oil as it kept coming out of new orifices so went all over the bench and the floor as well When I put it all back together I'll use some thicker than factory oil to increase the damping. (Slater, this lot seem familiar? ) I'm now waiting for a box of goodies to arrive before I can work out exactly what I'm going to do. In the mean time I've checked the car over some more by jacking the back up and removing the drums. Rear brakes all seem in good nick but there is a possible weep from an axle seal on one side. I decided to get the hubcaps shiny and then dug out the old trim rings we had on the Herald estate. They're not in great condition but "polishing" with wire wool and WD40 has got them as presentable as the rest of the car. Also picked up a peep mirror cheap on t'bay which I've mounted on the front of the door as there's no suitable top door gutter and I don't want to drill anything. I would probably have done without but I'm not the only person who's going to be driving this. Small compromises are worth it. And finally (actually did this first!) a friend from the Sun-tor can now wobble on the dash.
Last Edit: Mar 27, 2008 20:05:03 GMT by Seth
luckygti
I need to try harder!
Mar 27, 2008 20:11:58 GMT
Nice looking car you have there and looks to be really clean! Will look the biz a touch lower to the ground!!
kevfromwales
Mar 27, 2008 22:11:56 GMT
the 15" are still same PCD as Ford. IIRC there were some 16" off something that also shared that PCD, but I forget what... big 50's austin nice work seth - my towbar's going to spoil all your hard work to improve the looks though!! - kev
les509
Compulsive collector
looks brilliant, id love to see it on some cream space saver wheels, slat flat racer wagon!!! I've got a pair of 15" rims of an earlier series Minx in my mum's shed. Being very tempted to go down that route for a giggle! ;D Interesting... what sort of minx had 15's on it? All the 60's ones that have passed my way have had 13s or 14s on them & I thought the old bubble shape 50's minxes were some sort of weird 3-stud pattern? Dunno if it helps but some modern Peugeot steel rims (same PCD as Rootes) are pretty much just pressed steel with very little in the way of cut-outs, and look quite old-skool if you squint?!?! Les, I am quite suprised to find you have a secret passion for these cars! [/quote] Don't get carried away Wilko, I just like round headlights more than square ones!
61 Jaguar Mk 10 67 Austin A60 Countryman 69 Morris 1300GT 77 Triumph 2500S 84 Mk2 Granada Ghia Est 86 BMW 635 CSi 87 BMW 635 CSi
Tim
Cool, i've got one of them too :-)
Last Edit: Mar 28, 2008 9:24:01 GMT by Tim
Will look the biz a touch lower to the ground!! More than a touch I hope! A great big thwack if plan A works!
misteralz
Lovely.
Mar 28, 2008 10:48:37 GMT
A parcel just arrived containing shiny things ;D Now the fun really can begin
Mar 28, 2008 17:32:43 GMT
"And they're off"
Mar 28, 2008 17:46:41 GMT
Go for it Seth, oh and don´t forget the pics
sav
Mar 28, 2008 21:07:52 GMT
Liking the new wagon seth, looking forward to seeing how things develop.
Mar 28, 2008 21:43:32 GMT
shiny stuff wins
2001 HONDA CT110 (NOT RCV)
