Post by macabre on Mar 25, 2008 8:14:32 GMT
bazzateer
Imping along en Vogue
Post by bazzateer on Mar 25, 2008 11:20:51 GMT
I learnt to drive in one of those!
aux
Post by aux on Mar 25, 2008 14:26:49 GMT
That is sweet, more lowerage though
Post by RobMorris on Mar 25, 2008 16:51:32 GMT
I love these cars
Post by captainwow on Mar 25, 2008 17:13:31 GMT
Wow!!!
Thats ace!
cheema
Post by cheema on Mar 27, 2008 22:51:57 GMT
Post by macabre on Mar 27, 2008 23:23:24 GMT
I'm using a sigma 2l narrow block gearbox, evo engines are harder to mount because they don't have castings for rwd mounts, thats why I used a vr4 engine so I wouldnt have to drill into the block and weaken it.
Post by BenzBoy on Mar 27, 2008 23:24:31 GMT
Agh! Coolness! Love the banded steels, and the gold colour. Awesome!
cheema
Post by cheema on Mar 29, 2008 19:28:25 GMT
Hi mate - any chance of a picture of the Sigma you got the gearbox from? Reason I ask is that the Sigma's here in the UK are all 4WD so wouldn't fit the Lancer. Am I right in thinking the VR4 engine is the same as an Evo III engine? Any photos of your gearbox and engine would be great - I've been trying to get this project going for ages and this would be a great help. Cheema.
fuel
Turbo-Jet
Post by fuel on Mar 30, 2008 0:06:09 GMT
This shape Sigma:  While the Evo III and E39A VR-4 engines are both 4G63s, the VR-4 engine has castings for RWD mounts while the Evo engines don't - also Evo engines have 7 bolt cranks as opposed to 6 bolt of the VR-4, seperate thrust washers from the centre main bearing, smaller bearing journals, thinner rods, higher compression pistons, smaller ports in the head etc. Evo III is 270hp vs 220hp of the VR-4 - but that's mainly due to the larger turbo, larger injectors etc.
Post by macabre on Mar 30, 2008 5:40:18 GMT
Fuel is our local guru when it comes to mitsubishi the differances are as hes said above. don't know if I have any pics of box and engine out of the car but ill have a look for you.
Post by macabre on May 9, 2008 8:48:19 GMT
Well heres a bit of pictorial update for you guys.  when this happened I got a bigger diameter tube dshaft made up and tested it by doin this at a oldschool party   it held up great so then I went to the oldschool trackday and noticed my handling was pitiful   But I had an extremely short exhaust for the day so I was pleased when photos like this were taken  Also my buddy kelvin made me a nice new turbo manifold  Now the lancer is on the backburner for a while while I concentrate on the commer project which hopefully is getting primed tomoro! Click this link for more pics of our oldschool trackday s15.photobucket.com/albums/a376/racheal77/carprogress/?start=0
Post by HoTWire on May 9, 2008 9:25:43 GMT
Awesome!!!  and Is that Zep's Gemini??
Post by macabre on May 9, 2008 10:00:32 GMT
sure is
Post by penski on May 9, 2008 10:16:05 GMT
Close your bonnet :p Love your car  *n
Rico.
Post by Rico. on May 9, 2008 10:22:48 GMT
What are the plastic bottles for in this pic?
Post by macabre on May 9, 2008 10:36:38 GMT
thats my lightweight crankcase breather system ;D I got some big pipes welded to the rocker cover to reduce blowby when its on high boost and I havent got around to mounting a proper catchcan........... as you can see I am lacking room in the bay somewhat.
Rico.
Post by Rico. on May 9, 2008 10:38:35 GMT
Well 10 out of 10 for a simple but effective mod! ;D
DutyFreeSaviour
I have 10 cars to increase the percentage chance that one actually works!
Post by DutyFreeSaviour on May 9, 2008 11:57:59 GMT
That is one lovely ride.......... good to see it being used in anger too - the flame pic tells anyone all they need to know ;D
Any project thread on the commer?
EDIT - Welcome by the way!
Post by macabre on Mar 19, 2011 1:45:11 GMT
Heres a copy pasted update for you guys After an early 08 trackday at taupo I could hear a rattle in my engine so after a year of it sitting around taking up space I finally had some money and motivation and stripped the engine down to inspect it and found several bearings had run. Combine that with the fact it handled like a sack of curse word I decided to totally rework the whole car. I'm basically changing every aspect of the car to make it faster more reliable and a whole lot tougher. Engine is partly completed just waiting on the final assembly at the shop, specs are 272 cams 3 angle valve cut forged and stroked to 2.3l bottom end and all balanced up. Also going to run a garrett 35/40 of some description, hopefully will get around 400kwatw. Any suggestions from some of the experts here to acheive this will be gratefully recieved. I have a nitrous kit to install if needed too but not sure whether I will or not. Putting a lsd diff out of a L200 in the rear axles are much beefier than the turbo sigma diff it had in it it, also in the process of making it coilover rear end seperate shock and spring. up front are some starion struts and brakes which have had the coilover treatment. Complete engine bay rewire with the focus being on keeping it as tidy as I can, some custom alloy bits including inlet plenum cold air box and intercooler piping, I'm also moved the fuel pumps and surge tank to the boot and will be getting an electronic boost controller.       My mate who welded up the turrets kindly painted them a nice shade of pink   Garrett GT3582 with T04Z Comp wheel, and 1200 cc injectors, thats a ciggie case beside turbo which holds 20, just to give you indication of size Also got my J D M yo timing cover plates from the land of the rising sun  har har    Woot got my motor finally, also got some 15 inch steels to widen for it and a new personalised plate which you can see in bottom of photo NANNER ;D  Have also recently purchased a GReedy electronic boost controller
