Davenger
It's only metal
Club RR Member Number: 140
Apr 23, 2020 14:21:51 GMT
I did a thing. Got the bare dashboard flatted down And started shoving some felt on it Anyone for a spot of pegging Came out ok, just need to motivate myself to pull the old one out of the car and put this one in it's place.
Last Edit: Apr 23, 2020 14:23:04 GMT by Davenger
vulgalour
Club RR Member Number: 146
Apr 23, 2020 14:37:56 GMT
It looks flocked in that last picture, gave me early 2000s questionable interior choices flashbacks.
Spent most of yesterday reading this - what an awesome story. Wasn’t prepared at all for what happened on page 32 (I think it was page 32) but had a feeling there’d be a happy ending. Have to say you’re a better man than me Dave - I’d have chucked the towel in very early on, let alone kept on after the “repair” but I totally get why you did and nothing but respect to you for that. Its really inspired me to go and get stuck into one of my projects. I didn’t, but I did wander over the garage and wander round it staring at various bits... I must admit I might have started looking for Avengers for sale as well
Davenger
It's only metal
Cheers dude I must admit, there were a few times I thought about giving up, but I'm an idiot and decided to struggle on Avengers are cool though, much better than the MK1 Escrot I used to have
vulgalour
Apr 25, 2020 14:30:17 GMT
there were a few times I thought about giving up, but I'm an idiot and decided to struggle on We should start a club, that can be the theme.
Davenger
It's only metal
Apr 29, 2020 12:27:09 GMT
The stubborn idiots club. I think it would have quite a large membership
Davenger
It's only metal
If you're ever having doubts. If you're ever thinking that you can't do it. Just remember, It's only metal, it's not going anywhere, and you can do it. Rust is not smarter than you. It can be replaced with something good, just like a bad boyfriend or girlfriend. You can do better, it just takes time x
Sorry for the soppy drunken post, but it's bloomin true
ovimor
North East
...It'll be ME!
May 11, 2020 13:47:49 GMT
The stubborn idiots club. I think it would have quite a large membership I could never consider joining a club that would have me as a member.... *where do I sign OVIMOR
Last Edit: May 25, 2020 8:04:58 GMT by ovimor
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
Davenger
It's only metal
May 11, 2020 23:07:44 GMT
The stubborn idiots club. I think it would have quite a large membership I would never consider joining a club that would have me as a member.... *where do I sign OVIMORBack of a fag packet and drop it off at the nearest loony bin
Davenger
It's only metal
May 12, 2020 20:28:35 GMT
Used my day off productively. Adjusted the valve clearances, cyclinders 3 and 4 had managed to close the gaps for some reason. Fixed my heater fan, it had come loose and was jammed against the housing. Fitted my re-covered dashboard, and wired in a stereo. First time I've had a stereo in the car in the 12 years I've owned it.
Davenger
It's only metal
May 24, 2020 22:06:59 GMT
You know when you look at something, and you just know it's exactly what you need? Axle spacer from an old screw on bike hub I had kicking about has just taken all the slack out of my clutch cable. Clutch pedal bites much higher now. Don't know whether to get used to it or adjust the cable. Also got the stereo working, as I'd forgotten to hook up one of the power leads
Last Edit: May 25, 2020 11:09:48 GMT by Davenger
Davenger
It's only metal
Lost all drive on the A14 on sunday Expect lots of pictures and grumpiness in the next few days
vulgalour
Jul 29, 2020 17:09:04 GMT
Boo. Hopefully nothing too terminal.
Davenger
It's only metal
Jul 29, 2020 17:12:33 GMT
Pulled the gearbox out today. Found out the welds have split on the bell housing, so that'll need welding up again. Also found out why I lost drive. It's not worn out, it's disintegrated Plenty of life left in that So I've got my parts on order, just need to find someone to tig weld the bell housing
vulgalour
Jul 29, 2020 17:33:22 GMT
Too many hard launches in the traffic light grand prix!
What a nuisance for you. Easily sorted once you've found a welder?
teaboy
Make tea, not war.
Jul 29, 2020 20:36:55 GMT
What a nuisance for you. Easily sorted once you've found a welder? Looks like they didn’t add enough filler rod when they welded it. Should be ok if he gets it welded properly.
Davenger
It's only metal
Jul 31, 2020 22:31:42 GMT
Yeah. I've got a mate who can TIG aluminium, just waiting for him to get some more gas.
Davenger
It's only metal
Moderately productive day Got the remnants of my old spigot bearing out. What's left of the old needle roller bearing And fitted my new brass spigot bush, and the clutch Also dropped the bell housing off with my mate to get tigged up
Davenger
It's only metal
Aug 14, 2020 20:32:37 GMT
vulgalour
Aug 14, 2020 21:09:51 GMT
Shouldn't that be a lot less bubbly and a lot more penetraty?
