May 28, 2010 19:12:40 GMT
had a bit of time today so thought id add a sunroof first quick draw on the roof ![](http://i49.tinypic.com/2dbl2tg.jpg) then cut the buggar out ![](http://i49.tinypic.com/1773fl.jpg) refit and seal ![](http://i47.tinypic.com/3517af6.jpg) ![](http://i47.tinypic.com/1zfr40z.jpg) quick roof inside trim job done ![](http://i49.tinypic.com/muct1e.jpg) quick caddy pics ![](http://i47.tinypic.com/35a0xt0.jpg) ![](http://i49.tinypic.com/5dj5o6.jpg) ![](http://i50.tinypic.com/xbdzl4.jpg)
lol thanks guys , ps ive had a small problem , (only a small one lol) turbos knackerd , so thought id go searching and found this ![](http://i48.tinypic.com/2j1v811.jpg) geniune garrett gt40 turbo ,but the hot side looks a little big 1.14 so anyway adaptord it on , and its too laggy , after trying to find a smaller houseing to match the compressor wheel i got no joy without having to buy a new internal turbine blade ,,,so had a idea ,, yes you gessed chop it up i thought if i chop the snail down has to compress less voloume of air , so here goes , first rip some lumps off ![](http://i50.tinypic.com/10x9ic0.jpg) then looks somert like this ![](http://i48.tinypic.com/2ujtnpj.jpg) ![](http://i47.tinypic.com/9gkgus.jpg) then got some 5mm plate cut and welded 2 striped to keep the turbo twinscroll and christ feels evil lol ![](http://i45.tinypic.com/2i6e9uc.jpg) approx 200mile , few pics ![](http://i50.tinypic.com/m8mrsx.jpg) ![](http://i50.tinypic.com/2zs4t9y.jpg) you,ll notice how big that turbo is and how small ive managed to get the turbo hotside ive had it nice and glowing too ... ![](http://i48.tinypic.com/2yo99he.jpg) ![](http://i47.tinypic.com/2yv9edx.jpg)
Bloody hell, is there nothing you won't fettle?! You're a legend ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
Al.
Colonelk
Club RR Member Number: 83
DUDE! Making your own hotside!!! fecking legend!!!! Hows it work welding then? as isnt the exhaust housing cast?
My god, he's making his own bloody turbos now, what next ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
Last Edit: Jun 1, 2010 20:27:28 GMT by claymore
mattyj
you sir are a legend
Free Focus - soon to be roadworthy Corsa B 1.4 Sport - x16'd Cable tie edition - Dead Ford Ka - Sold BMW 318is - sump scraper - Sold ![:(](//storage.proboards.com/forum/images/smiley/sad.png) Citroen Relay lwb - gone like the rest
My head just exploded!!!!
WITCH !!!!!!!!!!!!!
![](http://i89.photobucket.com/albums/k235/fast-dub/newavatarcopy.jpg) SPLIT RIMS ARE FOR WINNERS
You sir are a god
That is all
pmsl everytime i check i have to laugh with the responces ,brilliant , right he was the problem ,i needed a large turbo with quick spool ,for air effiency which they don't make , as this turbo is/or was a geniune garrett gt40 4intake , problem was the hotside it was too laggy due to size of i , 1.14 t4 twinscroll , so after searching for another hotside//but smaller they don't do one , so next option chop the buggar , yes its cast , but its cast steel with nickel contnt so can be welded ,,, so after chopping a large area off , and useing spring high tenile steel 5mm thick ,i knew it would work but how well was another story , anyway 4 hours later , it was time to try , bare in mind ,when first fitted i had major turbo lag and showing 5000rpm before boost came in , after customizing the hotside I'm in boost at 2600rpm ,lol with no surge and will pull clean to 30psi , mental , but i dearnt risk trying to tunie anymore as I'm on stock headbolts lol ,, no point in buying exspensive pistons/rods/bolts etc , long as its tunied its fun ,,, its when you get greedy and go that bit more then somert jumps out of the engine ,pmsl ,,
YOU WHAT! lol this is epic, 30psi on stock pistons aswell?!! Awesome. Never seen that done before but it makes so much sense! Mind, you've introduced quite a bit of pumping loss now but it's the only way to go, and better in my opinion than having a smaller turbo working it's tits off and dropping efficiency. Will be good to see how the cast holds up ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Did you have to pre-heat the housing loads? And was it with your tig machine? Once again legendary stuff!
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
very nice lol, keep the updates coming
Porsche 944
ezpez
Jebus! i love this project! Mad skills mate, keep up the quality work!
havent looked for a while AM and your car is so awsome now!
love the wheels the only thing personally I'm not too keen on is the side exit. i would Then again its your car! once its slammed will look so cool on the steels!!
427
Praise The Lowered
Much better on the steels. Makes it look a little more like a sleeper, even if it doesn't sound like one! Awesome fabrication stills as always mate. Cheers
VND
Jun 22, 2010 10:26:46 GMT
Amazing build dude. Amazing.
Jun 22, 2010 10:50:08 GMT
Argh, thought there was an update then! Anything else been happening Adaptorman? Have you fitted harrier jets? A cannon? A Merlin V12? :-)
Al.
Jun 24, 2010 17:48:27 GMT
(cant really say anymore than that can you.....)
Jun 25, 2010 14:42:46 GMT
this is absolutely epic, backyard engineering FTMFW ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
ghetto
Jun 27, 2010 21:18:33 GMT
u sir apart from being a legend also need some sort of counselling hahaha but apart from your "yeah that should work attitude" i love this truck this should be on the front cover of a mag NOW
