ChrisT
Club RR Member Number: 225
Oct 21, 2023 14:25:50 GMT
Got some sound deadener for the passenger footwell, ordered it in ‘stealth’ black but only remembered it should have been black after cutting up and fitting it, never mind, the carpet will cover it. Before.. Stinger roadkill not stealth black. Templates made. Cut out. Fitted. Ignore the misaligned/randomly spaced Jubilee clips, they will be sorted when the hose joiner turns up.
Last Edit: Oct 21, 2023 14:33:12 GMT by ChrisT
ChrisT
Oct 21, 2023 14:57:36 GMT
Originally in the footwell there was a piece of fibreboard under the carpet to make the area flatter, did away with it a long time ago but have decided it wasn’t a bad idea so going to replicate it in steel. Fly press tooling I made a while back for adding strengthening ribs to steel, ideal for this job.. Made a pattern Transferred it to steel and added some ribs which deformed it a little too much. Beat it about a bit Fits like so. Left it at this point as I’m still figuring the routing of the bonnet release cable in this area and I’ve also realized I welded up the hole for the speedo cable, hoping I can run it elsewhere rather than have to re-drill the bulkhead.
Last Edit: Oct 21, 2023 15:03:58 GMT by ChrisT: re-order photos
ChrisT
Oct 21, 2023 15:15:47 GMT
After a tidy up so I could get round to the drivers side I bit the bullet and started cutting away knowing it was going to be like the other side, forgot to take a before picture but this is part of the garage MOT repair section cut out. Obviously this side is going to be harder to work on with fuel lines, wiring loom, pedal box, brake lines and other stuff to work round. It may all end up getting removed….
ChrisT
Oct 28, 2023 11:41:24 GMT
Weekly update, removed the front wing and made a start on removing anything that would be in the way, brake lines, master cylinder, steering column, pedals etc… A few years ago I decided to run the loom out of the engine bay and through the wheel arch to tidy it up, that’s probably going to need a plug/socket putting in it so I can move it out the way. Nice shiny hose joiner turned up at last. Now I can see what I’m up against and it’s quite daunting. Along with the various layers of MOT patches in the footwell/A pillar area the chassis rails are in worse condition down where the cross member bolts to them than the other side but the upper section looks better, will find out in due course….
Last Edit: Oct 28, 2023 12:42:20 GMT by ChrisT
Oct 28, 2023 15:04:39 GMT
Are there any panels / section’s available for the Manta Chris, that will make it all less daunting?
ChrisT
Oct 28, 2023 17:19:33 GMT
Are there any panels / section’s available for the Manta Chris, that will make it all less daunting? Not that I can find, TBH they’re not difficult panels to make up, it’s just seeing it like this and not knowing the best approach. Will probably start with the pedal box area, then trans tunnel and work across, leaving the chassis rail until last. I like to have a plan in my head before I start something, even if I don’t stick to it….
ChrisT
Not a great deal achieved this week, boss has gone off to Australia for most of November and left me in charge so haven’t been able to focus/concentrate on the Manta over the week as usual. So, after spending the morning sorting out the sticking handbrake and bent mudguards on the Sprinter flatbed ready for tomorrow morning, I did get a couple of hours on the car. Before… A few filled holes. Ground some of the welds down.. The steel around where the steering column comes through is very thin and welding up the holes near it wasn’t going to work, may have to re-fabricate the whole area….
Last Edit: Nov 5, 2023 15:55:20 GMT by ChrisT
ChrisT
Thought I’d have a quick practice at putting a flange on a hole in steel as I had the appropriate ‘tooling’ to hand…. Cut a 50mm hole in some scrap, put it all in the fly press and this is the result… Looks good to me, steering column rubber fits…
ChrisT
Absolutely no progress made on this the last couple of weeks with weather, social life and stressing over work, but did get sent a few photos which brought a tear to my eye. My 200sx is still around and looking mighty fine, glad someone has sorted it and having fun but I really regret selling it.
ChrisT
Dec 31, 2023 12:49:38 GMT
Nothing to report on the Manta, still a bit daunted about how to progress on the driver’s side, hoping the new year will bring some enthusiasm…. BMW seems to be running ok, seen a few miles over the last month - up to Barnard Castle and back, then over to Leeds/Bradford one snowy Sunday morning and down to the other side of Taunton the other day. On the way back around Evesham this happened (wife took photo)… Treated it to a quick wash yesterday.
ChrisT
Apr 27, 2024 18:31:01 GMT
Considering it’s 4 months since last update not a lot has been done, apart from the usual procrastination and questioning my choice of pastime, but the last month or so since the weather has improved I have been slowly tackling it. Cut away a lot of the old repairs to reveal what I’m up against and it’s not looking very good. The rot doesn’t seem to go as far up the chassis rails as the other side but it does go further down them, which I’ve remade. There’s also the A pillar structure which will need replacing, once the chassis rails are complete and putting some strength back into the area. Again it’s been a voyage of discovery remembering what repairs have been done at what point, the footwell/floors were MOT repairs which explains the quality and layers of steel, the inner wings were done by a professional but he had to make good to the previous repairs. Lower chassis crossmember mounting point. The start of making a new one, don't seem to have pics of the finished item.. Part of the new floor put in for MOT, it is all solid, just needs this side tidying up. After cutting back the chassis rail to sound metal I've put some U section in to bride the join. New steering hole for column. This area about done. The collapsible steering column needs some work too, probably best to replace it if I can find one, along with a new bearing at the bottom as that fell to pieces when removing it.
Last Edit: Apr 28, 2024 0:32:56 GMT by ChrisT
ChrisT
Apr 27, 2024 18:35:00 GMT
And in other news I got some more pics from the latest 200SX owner, looks stunning ….
Last Edit: Apr 27, 2024 20:46:52 GMT by ChrisT
