Oct 17, 2008 10:54:54 GMT
My brother has just brought a '96 Peugeot 306, although the bodywork needs a bit doing to it, the main problem is the stupid keypad immobiliser. I know these have problems when the battery is low, but there is enough more than enough power there. Sometimes it will work first time, other times you have to type the code in a few dozon times to get it off. How do you bypass/remove the keypad? Peugeot can do it but they charge money, and their price will probably be more than the car cost. I have a good idea of what to do, but just want it confirmed. Obviously its not really a subject you want to discuss on a public forum so if anyone can help could they PM me please Thanks! [edit] Forgot to ask, is the keypad and the ECU linked in? [/edit]
Last Edit: Oct 17, 2008 12:46:15 GMT by MiniDan
Kyle67
Oct 17, 2008 11:36:54 GMT
A lot of the problems with 306 alarms and keypads is caused by a wiring block. Peugeot, in their wisdom, placed the offending block just above the throttle pedal. This gets a good kicking as a pastime, causing bad/loose connections. Pain to get at if you aren't very nimble, but worth the effort of cleaning and making sure all the terminals are pushed in place before ripping the keypad out.
Ratchet
The user formerly known as Thomas
Oct 17, 2008 14:29:17 GMT
Is the car diesel by chance? if it is, its pretty easy to bypass. Also it might be to old to have it but on some of the cars which have both a keypad and remote locking you can bypass the keypad.
Competition is the law of the jungle, but cooperation is the law of civilization.
1971 vw beetle 1200 1978 international loadstar 1700 4x4 1987 landrover 110 1994 Yamaha FZR600r 2010 honda CBF100GT
Oct 17, 2008 14:32:42 GMT
We used to look after a fleet of them. I remember on the ones we looked after, if you entered the wrong code too many times you would get away with disconnecting the large round wiring connector below the n/s headlamp at the chassis leg for a few minutes!
Oct 17, 2008 14:38:23 GMT
Is the car diesel by chance? if it is, its pretty easy to bypass. Also it might be to old to have it but on some of the cars which have both a keypad and remote locking you can bypass the keypad. Nope, 1.6 petrol. and yea, its not got remote locking. I know with the remote ones you can get the code to activate for a few minutes or something when the fob is pressed or something like that.
qwerty
Club RR Member Number: 52
Oct 17, 2008 21:48:36 GMT
Any more progress on this? I have a 106 with similar problems.
Oct 17, 2008 22:22:45 GMT
Type code in Start car Unplug wire from back of keypad Sorted Works on all 106, not sure about owt else.
spacekadett
F*cking take that Hans Brrix!!
Oct 17, 2008 22:27:02 GMT
Type code in Start car Unplug wire from back of keypad Sorted Works on all 106, not sure about owt else. Deffo works on 306's as well, we had to do it to one a few weeks back Only thing to remember is, if the battery goes flat, you will have to plug it back in to start it but you can unplug it again afterwards
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Oct 17, 2008 22:29:50 GMT
Only thing to remember is, if the battery goes flat, you will have to plug it back in to start it but you can unplug it again afterwards Not on 106s - I've dealt with ECUs unlocked this way and even when off the car for months they stay unlocked 306s may be different though...
Good to know it's so easy to unplug them! They are a pain in the .
