Feb 10, 2009 18:21:27 GMT
Got a problem with my 2001 ex-AA T4 - it's a 2.5 TDI.
It won't select 5th or Reverse. I had hoped it was the linkages but after a bit of a look today it doesn't seem to be The problem seems to be inside the gearbox with the selecter I think
Anyone else had this problem?
Has anyone got a link to a picture of an exploded view of the gearbox (a Haynes Manual type line drawing would be good) showing how it should all look if I get to the 'take it apart' stage.
Many thanks.
Currently driving a 1972 BMW 1602 as my daily. Don't ask about previous cars - there have been way too many and I stopped counting at 160!
Feb 10, 2009 20:02:45 GMT
just a not but you'll also need to tell people the bhp as they are different gearbox's
but ill check my bentley manual and see if i can get ekta working.
dan
Last Edit: Feb 10, 2009 20:03:32 GMT by mortcars
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
Feb 10, 2009 20:05:16 GMT
Common problem on the 2.4/2.5 T4 boxes, mine has a full rebuild in 2007 becuase of a similar problem, now I've lost synchro on second. I don't think its a very strong box.
Feb 11, 2009 10:12:13 GMT
Common problem on the 2.4/2.5 T4 boxes, mine has a full rebuild in 2007 becuase of a similar problem, now I've lost synchro on second. I don't think its a very strong box. sent you a PM
Feb 11, 2009 17:10:33 GMT
Replied
Feb 11, 2009 18:15:51 GMT
Hi i had a similar problem with mine could not get 1st or 5th and it turned out to be the clutch master cylinder. Not to bad of a job to change its above the clutch pedal inside. Cylinder cost about £75 i think.
RYZ Customs
craig
Feb 11, 2009 21:28:18 GMT
just a not but you'll also need to tell people the bhp as they are different gearbox's but ill check my bentley manual and see if I can get ekta working. dan I thought the ex AA vans were a different box all together? They were all 102hp but different from the normal 102hp vans?
Feb 12, 2009 10:46:06 GMT
Reverse is left and up, VAG gearbox
Reverse right and down, non-VAG gearbox
Feb 12, 2009 11:38:24 GMT
just a not but you'll also need to tell people the bhp as they are different gearbox's but ill check my bentley manual and see if I can get ekta working. dan I thought the ex AA vans were a different box all together? They were all 102hp but different from the normal 102hp vans? ive heard that before too. Reverse is left and up, VAG gearbox Reverse right and down, non-VAG gearbox i thought it was 5th thats the difference
Feb 12, 2009 20:17:44 GMT
Reverse is left and up, VAG gearbox Reverse right and down, non-VAG gearbox ok, now I'm confused - what other box was put in the ex-AA vans then?
Feb 13, 2009 10:20:00 GMT
Reverse is left and up, VAG gearbox Reverse right and down, non-VAG gearbox ok, now I'm confused - what other box was put in the ex-AA vans then? Some had VW boxes (reverse left and up), others had Fiat boxes (reverse right and down). The easiest way the check is have a look at the gearbox from underneath (as well as the reverse gear obviously!). The VW box has a removable end plate with a VW stamp on... ...whilst the Fiat box does not have any end plate... If you are not already a member/user, the VW T4/T5 forum is a wealth of information.
