Nov 25, 2014 22:58:36 GMT
Thanks georgeb, Its rewarding fitting parts that wont have to come off again, But saying that, i spent all evening fitting a closer plate to the bulkhead, with holes and grommets for 2 x hoses, the engine wiring and turbo pipe, then realised its all got to come off so i can tighten a hose clip on the chargecooler which cannot go in till i have tested the water pipe connections.
Dec 22, 2014 20:54:16 GMT
connected up and running Got to get the cold start tuned a bit better and rethink the cooling Currently the heater pump pulls hot water out of the back of the heads and i have routed it to the rear rad. This is heating the rad up before the thermostat opens, all a bit wierd. Might have to restrict the water flow or re route it into the return pipe to the engine
mattrb
Dec 22, 2014 21:18:00 GMT
I love this car and what you're doing with it.
Please keep the updates coming.
I've been following it for months but I decided it was about time I showed some appreciation. I know these threads don't write themselves. Awesome stuff.
Matt
Dec 22, 2014 22:29:22 GMT
My choice for most anticipated car of 2015
mattrb
Dec 23, 2014 10:37:14 GMT
My choice for most anticipated car of 2015 Agreed. A close second is this though:
Dec 23, 2014 13:51:33 GMT
My choice for most anticipated car of 2015 Agreed. A close second is this though: And only six miles from me
eurogranada
Dec 29, 2014 10:09:41 GMT
That engine looks fabulous in there! So clean! Amazing job!
Whilst waiting for a modification to the thermostat housing, started the bodywork. Doing the roof, door shuts, and inside faces of the doors. Primer filler, block flat, primer, wet flat, colour, then laquer. When those bits are done, hang the doors and repeat the process with the external panels.
m3240z
Jan 19, 2015 22:30:14 GMT
] Nice progress Alan be carful the dry layers of paint on that plastic sheet don flake off on the top coats
Jan 22, 2015 19:44:14 GMT
Your not wrong Terry. After the second coat of primer was rubbed back we removed all the masking up and did it again. Johns handywork........ Have you started a thread on your next Z ??
Last Edit: Jan 22, 2015 19:45:15 GMT by sierra1off
eurogranada
Nice!
mattrb
Feb 21, 2015 19:29:36 GMT
Can't wait to see the next progress pictures.
Feb 22, 2015 18:25:55 GMT
Mattrb. Just for you. Drove it out of the garage Now put the final paint on
820
Feb 22, 2015 18:40:12 GMT
Great stuff, a milestone in a cars progress, to be driven after so much work, looking good.
mattrb
Feb 22, 2015 20:03:03 GMT
Brilliant.
What are your plans for the wheels or are they a secret?
Mar 19, 2015 23:52:25 GMT
Wheels are secret!! Fitted the charge cooler under the dash.(well most of it ) The tricky bit of getting the pipes to the inlet connected Them the tricky bit of getting the sides closed off and the pipes from the turbo's on Still got the thread through the pipes for the coolant from the charge cooler to the front rad ! Boost valve fitted and wired in
Last Edit: Mar 19, 2015 23:56:17 GMT by sierra1off
steveg
I thought the charge cooler was a really flash interior heater ! That's all getting to production car levels of fit this is going to be one hell of a great car when it's done. Shame all these bits will be hidden away.
skoze
Haven't checked in on this for a while - if it's this exciting to catch up on, how on earth are you holding out?
richrolls
Club RR Member Number: 38
Mar 20, 2015 20:47:27 GMT
Mattrb. Just for you. Drove it out of the garage Now put the final paint on I read "Drove it out of the garage" Hold breath in anticipation.
Mar 22, 2015 22:30:36 GMT
Very close to driving again. I think i have finished underneath, scoop made for the rad. Another pair of hoses under the dash for the charge cooler, filled and pump tested. Need to fit the dash trim, but the knobs that operate the heater damper goes through the dash to the heater. Had to release these from the heater that is now buried behind the charge cooler You can see the end of the outer cable between the blue hose and the Y piece. Not fun !!!
