Mar 11, 2009 14:44:15 GMT
Hello,
Just got myself a cheap daily - 1.8L Peugeot 205 turbo diesel, it's in really good nick and it's suprisingly quick (no really it is ... ) but ofcourse not quick enough! I've got an intercooler from a 200sx to stick on it and I can wind up the boost easy enough but I'm stuck on how to increase the fuel flow!?! It's not a common rail so don't know how to adjust the fuel pressure, any ideas?
Also if you've got other ideas of how to tune it that'd be great!
Cheers!
Mar 11, 2009 15:54:31 GMT
A popular tuning method for older diesels here is "screwing out" the fuel pump. Not sure if that's applicable to the 205 or not.
Mar 11, 2009 16:13:35 GMT
Screwing out?? Sorry if i'm being simple whats that!?!
Mar 11, 2009 16:33:55 GMT
I've got a 205 TD and I know what you mean about it being fairly rapid. I found with mine that making it light made squat of difference as i has 3 people and suitcases in the car and it was just as quick as when it was unladen ;D so i guess you're stuck with tuning it.
Fitting the intercooler would be a good start as it doenst even have one ;D
rysz
Mar 11, 2009 17:48:38 GMT
Mar 11, 2009 21:06:09 GMT
The Lucas pump isn't as easy to tweak as the Bosch pump found in other Peugeot diesels. www.club-306.com/guides/306_turbo_tuningHave a look here for some tips, I reckon many of them will be applicable to your 205
Last Edit: Mar 11, 2009 21:06:28 GMT by milfordcubicle
Cheers for all the links they've been really usfull Right I've been reading up on all this lot and found out i've got the dreaded lucas pump so no running it on chip oil! On the club-306 forum it dose say these can be tweeked by tuning the screw behind the rubber grommet in the front. Just wanted to double check I'm on the right track!
Mar 12, 2009 16:49:12 GMT
Bump!
Mar 12, 2009 20:15:35 GMT
Not sure like, because I've only done the mods on a Bosch pump.
