johnrh
Great pics, thanks.
The red one is very sweet. I also quite like the concept of the yellow one, but the choice of wheels/colour/mirrors isn't my taste.
You're right to put the correct tyres on. After all, it's a critical part of the chassis design and (hopefully) your only contact point with the road. I shelled out for XVSs on my DS and it totally transformed the driving experience (previously on Vredstein).
That cracked tyre photo is scary... would want to go above 20 mph on that.
Cheers
John
Last Edit: Sept 6, 2009 8:05:53 GMT by johnrh
Sept 16, 2009 21:48:49 GMT
I f*ckin love this car, my parents both had GS's when I was young, my mum had a bright yellow saloon & my dad had a pale blue estate, & years later they bought a cream GSA hatchback (super quiet, in mint condition). My dad always said they handled like they were on rails, super roadholding, & yes, the seats don't like sunlight. I always wanted to get one & see if I could fit an alfa romeo flat 4 water cooled engine in it? Lovely car though, & I'm all for keeping these things original, well done.
1985 BMW 525e (eta) for sale 1973 BMW 2002 touring
Siert
Sept 17, 2009 14:59:02 GMT
Thanks nutgone! Shall I give you some dimensions so you can drool about fitting that Alfa engine a bit more?
My car is now back to looking what it looked like at the top of page 2 though, as I'm replacing bad hydraulic hoses including the one rubber T-piece on the pump under the left timing belt.
Sept 22, 2009 16:23:46 GMT
Would like to know if it's possible to translpant alfa lump, as I remember some citroens had belt driven hydraulic pump which would make it easier. I showed my dad these pages, for a moment he thought it was from the "cars for sale" section & got all excited. He's also well into his motorbikes, so got suitably excited when he saw the citroen works bike with GSA engine. Good luck with the hydraulics work, these older systems seemed to be better put together than the later ones, but everything's a bit harder to get to.
Siert
Sept 22, 2009 19:29:51 GMT
The GS engine is very far forward with the gearbox behind it. If I'm not mistaking the Alfa's have a transaxle in the back, if you bolt that directly to the engine it may fit length wise... but I think you'd have lots of problems. First of all, aren't they Alfa engines watercooled? I doubt there would be space for a radiator left in front of the whole engine/transaxle assembly. Secondly, the transaxle is most probably wider than the Citroen gearbox so you'd get into trouble with the brakediscs which are on the inside of the driveshafts, just besides the gearbox.
DS's have a belt driven hydraulics pump, so you could probably use that, if you can find the space to mount it. The GS pump is driven from a plunger that comes out of the side of the oil pump.
The original engine is already a tight fit in some places. As this forum proves many things can be done, but I think this would be very difficult.
Siert
Sept 22, 2009 19:33:59 GMT
Besides taking the hydraulics apart I also did some work on the carburator. This is what it looked like: Really dirty float chamber, low mileage isn't good for everything... And this is what it looks like now
berendd
why do I need 3 keys for one car?
Sept 22, 2009 19:50:43 GMT
that's a thorough clean up!
Siert
Oct 11, 2009 20:23:15 GMT
For Citroen hydraulics hoses "Ligarex" pliers are recommended. I ordered them from a Citroen webshop in the Netherlands. This is what they look like: And this is what you can do with them: Well, I put everything back together and the first problem I had was that my engine was running badly. The CO reading was 7% and it wasn't at all affected by turning the mixture screw on the carburetor A quick Google for Weber carburetor picutures revealed that the one spring I had left over should have been behind the accelerator pump membrane So I put it back and tuned it to the right idle speed and 2,5% CO. Car runs much better than it ever did, and it never ran bad to start with. Result! Unfortunately, the next morning there was hydraulics fluid under the car. Well, it seemed I have another problem... what happend is that when I took everything apart I cut a 5cm long hose that connects a plastic piece of tube to a metal piece of tube thinking that it was just a hose. Unfortunately its inner diameter is about 4mm on one end, and about 2mm on the other end I hoped to fix it by using a longer piece of normal 4mm hose and multiple clamps but it turned out that really was wishful thinking. Well, I'll have to find a proper solution to it. In the mean time I've fitted my towing hook :-)
Nov 17, 2009 16:57:03 GMT
That has to be the coolest boot i have ever seen.
Siert
Nov 17, 2009 21:55:54 GMT
any updates on this Not much. The hydraulics still leak a little from somewhere, but I'm not even sure if its from one of the parts I took apart or from something that was already dripping before. As winter has already more or less arrived here I registered the car out of traffic and put it in its usual inside parking spot. I now co-own a Citroen BX as a donor mainly for my 309, but I may also find some useful hydraulic hose linkage pieces. I'll have to have another good look at the system in spring. I don't expect any major trouble. I did use the hook before taking the car out of traffic. It worked really well, the supension and brakes really are good for towing. We didn't put much load on the trailer (two 309 rear axles) so the lack of power wasn't a problem. I've also decided the car will get a professional respray some time after driving it to RRG10
I've also decided the car will get a professional respray some time after driving it to RRG10 If you fancy a small detour via northern Germany on your way to the Netherlands you´re more than welcome to stay at "Oldbus garages" ;D
1978 Citroën GS Clubretrowagen1234
@GUEST
any updates on this after driving it to RRG10 you may not be the only GS there all being well ;D
Love those cars. Yours looks awesome. In 1996, in NZ, I did an appraisal on a very very cool and bright orange GS Estate with full orange vinyl interior, the guy wanted too much for it unfortunately the deal fell apart.
Last Edit: Nov 18, 2009 9:06:40 GMT by MokeMan
Siert
I've also decided the car will get a professional respray some time after driving it to RRG10 If you fancy a small detour via northern Germany on your way to the Netherlands you´re more than welcome to stay at "Oldbus garages" ;D Thanks, I'll consider it!
Jan 24, 2010 20:06:43 GMT
Jan 31, 2010 21:28:42 GMT
Cool car
Siert
I registered this back in traffic use now that the snow has melted (at least of the roads) and hopefully taken all the salt with it. I had some problems as after running the engine warm I found that I couldn't select any gear as the clutch wouldn't disengage. This is probably due to my storage being to humid. Unfortunately other cars with snow on their roofs driving in and out of the parking garage all the time and then melting down means that it would have had an easier time standing outside in the freezing (dry!) cold.
It took me a while to figure out the right way to force the clutch to come loose, but I finally realized that the only way is to select first gear with the engine switched off, and then try to start the engine with the clutch pedal depressed. After a small jump forwards the clutch popped loose and the car now drives just like it always did...
Siert
Apr 18, 2010 20:45:16 GMT
Apr 19, 2010 14:03:22 GMT
Cracking pictures! You don't need fast to have fun in a Citroën! Glad you enjoyed it.
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
