ruffgeezer
Attracts french tat.
Sept 10, 2009 21:26:54 GMT
We're having a clearout of the field at work, and this little lady is up for the chop: Given that she's terminally rotten having sat in long grass for 7 years, her frilly undercarrage is well beyond saving, needless to say, I've salvaged a fair bit from her to bolster the smurf's build. Also for the chop are these (the 2cv went a while back) I'm using part of the nearest to the camera to solve the rear arch issues, can you guess what it is yet?
Chris™
This is clearly filler material.
Sept 10, 2009 22:16:03 GMT
My opinion is you should make it mostly standard on the outside, but deck it over some steels. Bit of a sleeper maybe? Cool build anyway, don't see many modded AXs at all really
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
ruffgeezer
Sept 10, 2009 23:08:15 GMT
Yeah, but i can't bring myself to bin the bonnet, i mean skulls aren't my thing really but someone has put a lot of work into them.
BiAS
Insert witty comment here
Club RR Member Number: 147
Sept 10, 2009 23:17:48 GMT
You've got the parts on the other one to make it a really good sleeper. Can you get round the rear wheel issue by using this to figure out what offset and width wheels you need to be shopping for? If you were to run steels you could run different front and rears to get them tucked nicely.
(car+wheels)-rideheight=WIN
ruffgeezer
Sept 10, 2009 23:38:06 GMT
Well the normal offset is 18-20, I've dropped a et25 bx steelie on the back and that *just* clears, but that's only on the high profile, mega skinny rubber, I had a go at pulling the arches but due to the construction, there just isn't enough give in them.
I'll be losing the skirts in due course as well as the front bumper, but I might have to fit some sort of arch over the front wings as my mot tester isn't too keen on poke.
Sept 11, 2009 12:39:21 GMT
I'd make it a proper barry wagon. I think it'd upset more people that way rather than looking standard.
Matt
DutyFreeSaviour
Sept 11, 2009 13:06:11 GMT
My AX GT was made of tinfoil! Surely you can get a bit o' give in the arches and get 'em pulled....... flatten those lips with the vinyl hammer and get a couple of scaffold pipes. Thinner to start then full blown roller - you know it makes sense. Excellent choice of engine - it'll fly!
ruffgeezer
Sept 11, 2009 17:12:24 GMT
Its easier on the gts as the panel is flat, this has a lot of curves to it because of the rear door, and I'm needing around 1/4" or more, its not just rubbing the arch, they are actually resting on the tyres.
Sept 11, 2009 17:15:36 GMT
Mmmm Cut the arch out and weld in about 1/4" of new metal to yours attach the arch back on..? Or possibly get jiggy with the fibergash? Alternatively get some wheels with an offset to suit.
Daily: Spazda Mx5
'A52's Fastest steak eater 2010'
Sept 11, 2009 19:03:22 GMT
Ford wheels are often 40ish et, get some, and some really skinny rubber, and the pipe trick, and voila, plenty of room for the wheels.
Last Edit: Sept 11, 2009 19:03:38 GMT by dude
Sept 11, 2009 19:35:50 GMT
can u fit the gti arches? i took a jig saw to my flat arches and fitted gti arches, that will make them 40 mm higher and maybe out of the way.
if we don't come down hard on these clowns we'll be up to our balls in jugglers!
ruffgeezer
Sept 11, 2009 20:39:19 GMT
I've something in hand to sort the issue, et40 rims would be rubbing up the inner arch a treat, so I think I'm going for a subtle mod.
ruffgeezer
Sept 16, 2009 20:17:44 GMT
Ok so I took temporary custody of this sad little number last week: I have relieved it of a load of parts which are soon to be making their way onto the smurf. Front bumper didn't put up much of a struggle as all the mounts were rotted out: I took the opportunity to get a decent rear bumper and tailgate too (no pics of the parts I removed though :S):
Sept 17, 2009 0:15:23 GMT
if that is a BX GTi 1.9 manal and it still there can you drop me a pm with some more pics of it please. Been trying to track a one down for donkeys
Current Fleet: 2004 Audi A4 1.9tdi Sport Avant 2014 Ford Fiesta 1.25 (wifes car, curse word box) 1987 Volkswagen Polo CL
ruffgeezer
Sept 17, 2009 19:52:06 GMT
Heh, sorry its just a late high spec turbo d with a knackered injector pump, there was a gti here at one point but it was boned, so has been squished.
ruffgeezer
Sept 17, 2009 22:26:08 GMT
Well since my parent's are having a fresh roof put on the garage, I had to make smurf moveable, so check out my stance! I'm actually quite liking the bx steels look, so I might try and dig out a full set: The back is only this high as I've jammed a block of wood under the bumpstops, you can't move the bloody thing otherwise. Looking nearer finished, but lots of annoying little jobs to do.
ruffgeezer
Sept 18, 2009 14:31:29 GMT
ruffgeezer
Sept 20, 2009 17:06:10 GMT
Made a little more progress on the aestetics today as I've not had time to pick up the replacement gearlinkages. So to compare, old vs older, I was going to clean the bumper before I fitted it, ok that's a lie, I was never going to clean it. This is the scabby bumeyed crapbox without the front end on, I trial fitted the vtr radiator, its only a little bigger than standard so to save arsing around, I'll fit a new standard one instead. Front end completed with a grille from my rusting in pieces gt, "the purp" Hammerite, it smells bad but covers a skanky panel nicely. The bonnet will shut better once I've refitted the catch, I hope! Another thing I rescued from the condemned ax at work was the door panels, I nearly took the seats but they were soaking wet. Old panel out: 80's tastic panel in: On an aside note, you get big eff off birds round here, I hope this one doesn't take a curse word or it could get messy! I've polished me skulls, its a shame there is a metric boatload of deep scratches on it, but from a mile away, you'd never know it! Coming to the side of the car, I've pulled the sideskirt off, I'm not sure if I'll leave if off or just jetwash the paint off it and refit it in black. OEM look is the way, I found a set of new spree badges in the garage, complete with measurements as to where to put them. The close of play, doesn't she look shite great?
Sept 20, 2009 17:20:19 GMT
That's really coming along! The BX steels are definitely FTW! They look damn good. Not so enthusiastic about the bonnet - I like the skulls, it's that blue border with it that makes me feel a bit queasy! ;D "Spree" badges are excellent too - it's gonna be embarassing a few unsuspecting folk off the lights is this!
ruffgeezer
Sept 20, 2009 20:15:52 GMT
Yeah if you look closely on the pics, you can see red paint peeking through the border on the right hand edge, I'm just not sure if i could fetch the paint of without ruining it.
