MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jun 11, 2009 20:29:01 GMT
Well, with these lovely summer nights, I've regained my mo-jo, managed to stay out the pub a bit and crack on with the Vitesse. To celebrate this I thought I'd share a little progress with you. After mashing the gearbox at Santa Pod last year the old gal has been layed up and quietly disolving as only BL tin does. So, old gearbox stripped out (in anticipation of the type 9 conversion), I ripped out the carpets (won't be needing them again !) and attacked the floorpans with a wirebrush and found them to be in remarkable good nick ! A coat of paint later; Then onto the bonnet. Last year I managed to find a very rare fibreglass front end for the Triumph, but it was a bit rough round the edges. (Legend has it they were made in very small numbers by Honeybourne but they never admitted it !), so out with the 'glass and filler. That should save a shed load of weight and no more tin-worm ! The engine is due to be replaced with this one which I have been working on for over 12 months now. Block is bored +0.020". New flat top pistons. Crank, flywheel and front pulley have been lightened and balanced. Final spec will also include flowed late spec 2500 head, lightened/balanced 'rods, flowed inlet manifold and 6-2-1 exhaust manifold. Carbs will be either HS6's or the pair of HS8's I have lying about, along with a fairly lairy camshaft which I have yet to aquire ! Oil cooler will also be fitted, possibly front mounted. p.s. it's actually painted RED not pink, it just looks that way on the photo !
Last Edit: Sept 4, 2015 9:32:23 GMT by MrSpeedy
Nice one.
Like the vans in the side of your pics.
More of them ?
MrSpeedy
East Midlands
The red one is awaiting resto but the grey one is a daily hack for the firm. I'll put some pics up in another thread !
MrSpeedy
East Midlands
Jun 18, 2009 19:58:24 GMT
OK, Li'l update. Been workin on the 'glass front end this week, what with the fine weather and all, so; 2 coats of high build primer later it looks like this; A little flatting and smoothin later, it's ready for some colour; Granted, it's not the best "spray booth" in the world, but it will suffice for building up until t's ready for the top coats. Not done any spraying for years, but it's coming back to me slowly. Don't you just love cellulose paints !
luckygti
I need to try harder!
Jun 18, 2009 20:38:22 GMT
Looks good. Have a real soft spot for the Vitesse. Like the Merc as well. Now I know where I got the idea for wanting to spray the Merc sides all black! Both nice cars ;D
MrSpeedy
East Midlands
With the Bonnet now finish sprayed i moved my attention to the gearbox conversion. Having got a billet of Aluminium off of e-bay (!!) i started machining it to fit the type 9 gearbox. Initial hole made with 4" holesaw; Then bored to size using boring head; Finally holes marked and drilled and ready to be welded to original bellhousing;
Hi MrSpeedy, why are you welding the Vitesse bell housing to the adaptor plate? Would it not be better to bolt them together? I am looking at a similar conversion for my MK2 as well. I have a Sierra 2 litre Type 9 gearbox to do the conversion and am buying the adaptor plate from Canley Classics. It works out cheaper including shipping than sourcing aluminium locally and getting it machined.
Adrian
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
chaz
Nice project mate, love the Vitesse have some nice memories of these cars. The Thames looks interesting too.
I am getting tempted to get a Vitesse, but it would have to be a Mk2 like yours.
Is looking nice.
MrSpeedy
East Midlands
ahebron; there's 2 reasons why i'm welding the plate to the bellhousing. My initial thought was indeed to bolt the two together but after lining them up the top 2 holes partially overlap and I can't see a reliable way to overcome this. The second reason is simply because I can ! lol. It's all being done by myself and on a budget. I did look at the conversions available ( frontline/jigsaw etc ) but couldn't justify the cost considering so far it has cost me 50 quid for the material and the gearbox !
Last Edit: Feb 21, 2011 15:09:15 GMT by MrSpeedy
MrSpeedy
East Midlands
Jul 22, 2009 13:05:57 GMT
Little update, as this got put on a back boiler whilst beavering away on the "Sprintfire" Finally got some shield gas so adaptor plate welded onto original bell housing. Gearbox bolted on; Trial fit in car; Looks good so far. Gearlever will require some tweaking for position and i can see me having to reposition the handbrake aswell as remove some metal from the tunnel !
PhoenixCapri
West Midlands
Club RR Member Number: 91
Jul 22, 2009 17:08:10 GMT
Just a little modding needed on the floor then! Nice project, bonnet is a great find, bet that saves a huge amount of weight?
Jul 22, 2009 22:03:48 GMT
You can move the T9 shift forward about 65mm without getting too technical. Not really enough - still interferes with the handbrake. Used a Toyota W58 in mine - which caused a different set of challenges...
Nick
MrSpeedy
East Midlands
Jul 23, 2009 12:00:54 GMT
Any more details on how the shifter is moved on the type 9 ?
Yes, the 'glass front end must be at least half if not less weight than the original. I can easily pick it up on my own !
MrSpeedy
East Midlands
Update time ! Tunnel cut back about 9inches for clearance on Gearbox which is now bolted in ( no clutch yet tho ! ) Handbrake moved back about 2 1/2 inches. Hoping to turn the cable end for end so adjuster is on outside of car to allow room for it all to work ! Old propshaft and exhaust removed for access but snapped 2 studs in ex manifold ! Still gives me an excuse to fit the tubular branch manifold i have sitting about !
DutyFreeSaviour
Missed this earlier - excelletn stuff. One of the few Trumps I love but haven't snagged yet. You're doing a quality job there too. Type 9 on the list of 'after MoT' for the shed. Watching with interest. You got the top coats on the bonnet setup yet? Top find in 'glass. Good luck with her...... p.s. - How are the outriggers looking?
MrSpeedy
East Midlands
Cheers. Yh, bonnet finish painted now. Not brill, but will polish up. Not looking for an A1 paint job, just clean it up at bit ! So far, she seems very solid underneath, altho i have found a tiny bit needs doin on the front outrigger by the bulkhead
Nice work Mr Speedy - its motivating me to get off my *rse and do something with my Mk1. ;D
Any chance of you making up another of those type 9 adaptors?
Koos
Nov 22, 2009 10:38:15 GMT
Are fibre bonnets so rare for a Vitesse? Or is it just that well made fibre bonnets are rare? I'm curious. Back in the day the fibre front end was the standard solution to terminal bonnet rot on Herald/Vitesse series cars, there used to be plenty of companies who'd supply you with one. OK, some of them were pretty awful copies, but rare? Not the way I remember it. I've got a fibre 1200 bonnet in my pile of tatty Herald bonnets. Pile of poo, or pile of dollars?
"Jeremy Clarkson, a man we motor enthusiasts need on our side like Lewis Hamilton's F1 car needs a towing ball and a Sprite Musketeer" My motor
Just been reading a post that says the Mt75 is a shorter box than the type 9 - maybe that would be a better swop?
IIRC fords use the same bellhousing, so the same adaptor would work???
Koos
