Now, you may be wondering why there are two cables. Well, I'm not using any kind of Idle control valve with these throttle bodies, in an attempt to simplify things, so the second cable is the original choke cable, to give me a manual fast idle control Cruise control without all the vacuum/electrickery gubbins! Must say this whole set up is looking pretty impressive.
Why no IAC valve?
Do you reckon it'll be done for RRG?
Koos
I don't run any IAC on my throttle bodies either, just needs a few seconds of tickling when stone cold but it'll idle all day then.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
^^^ That's exactly why. For the sake of sitting stationary for 30 seconds or so I'm quite happy to offset that against simplicity. After all, I'm only really interested in it's performance flat out! lol One way oR another, it WILL be at RRG. Hopefully with all this elastictrikery gubbins doing what it should, but at last resort, I'll bolt all the carbs back on In other news, I did try to start it tonight. I tried, but failed. For some reason there's no crank signal reaching the ECU. It's not showing in Tuner Studio when cranking, but the ECU checks out with the Stim. Tomorrow shall be a day of investigation!
Phil H
Club RR Member Number: 133
VR sensor backwards? Swap the wires and see if it's happier?
MrSpeedy
East Midlands
Aug 10, 2015 21:43:47 GMT
VR sensor backwards? Swap the wires and see if it's happier? Nail on the head! As the VR sensor wasn't marked, I'd (incorrectly) assumed it wasn't polarity sensitive. I was wrong. Did some more research, swapped the wires, and.........life!
bstardchild
Club RR Member Number: 71
Aug 10, 2015 21:46:42 GMT
Great news - amazing what knowledge is out there!!!
MrSpeedy
East Midlands
Aug 10, 2015 21:49:58 GMT
So,
It's been a couple of days, I've had a 'time out' and after some fettling, it curse word RUNS!!!!!!!!!!!
Setting are 'straight out the box' and it's running properly rich, but, it's running!
Now the rich running at low speed could be down to the cam, but that will get dialled out over the next few weeks, but once you clear it's throat and get over 3500rpm, it's an absolute beast!
To say I'm happy, is a massive understatement!
Davenger
It's only metal
Club RR Member Number: 140
Aug 10, 2015 22:21:03 GMT
Frigging epic! looking forward to a proper look at RRG
Aug 10, 2015 22:23:30 GMT
Yay! Sounds brill!
Aug 10, 2015 22:51:05 GMT
Oh dear me, YES!
Phil H
Cheers for the cookie!
It's probably the most common issue with a fresh MS install - as you say, there's no clue as to which way round to connect it.
Well done though - it runs; that's the main thing!
Great news! That thing sounds almost pornographic
Speedle
In the words of George Takei... Oh my!
MrSpeedy
East Midlands
Cheers for the cookie! It's probably the most common issue with a fresh MS install - as you say, there's no clue as to which way round to connect it. Well done though - it runs; that's the main thing! Yeah, thanks for planting the seed in my mind. It made me look further into it Thanks for all the comments folk. The video doesn't really do it justice, but I'm still smiling from the sound this morning!
Aug 11, 2015 12:55:43 GMT
Looks good,sounds even better.
Aug 11, 2015 17:18:38 GMT
So, It's been a couple of days, I've had a 'time out' and after some fettling, it curse word RUNS!!!!!!!!!!! Setting are 'straight out the box' and it's running properly rich, but, it's running! Now the rich running at low speed could be down to the cam, but that will get dialled out over the next few weeks, but once you clear it's throat and get over 3500rpm, it's an absolute beast! To say I'm happy, is a massive understatement! That sounds really exciting and what an achievement. Couldn't help notice the CLARK C500 yard forklift truck in the background , will that be getting some EFI?
MrSpeedy
East Midlands
Aug 11, 2015 21:17:01 GMT
So, It's been a couple of days, I've had a 'time out' and after some fettling, it curse word RUNS!!!!!!!!!!! Setting are 'straight out the box' and it's running properly rich, but, it's running! Now the rich running at low speed could be down to the cam, but that will get dialled out over the next few weeks, but once you clear it's throat and get over 3500rpm, it's an absolute beast! To say I'm happy, is a massive understatement! That sounds really exciting and what an achievement. Couldn't help notice the CLARK C500 yard forklift truck in the background , will that be getting some EFI? It's actually a Caterpillar V50 lift truck ;-) Perkins 3.152 diesel, so no efi possibilities. Lol
Last Edit: Aug 11, 2015 21:17:17 GMT by MrSpeedy
adam73bgt
Club RR Member Number: 58
Cor! that looks and sounds epic!
MrSpeedy
East Midlands
I took it for a little drive round the estate last night. It sounds like actual thunder!! LOL. No more videos now though, you'll all have to wait for RRG to hear anymore
