Sept 5, 2009 21:45:35 GMT
Hi all. I really-really needed a ride that I could use now, so I ended up with a nice old Renault. Both of my Mitsubishis are in pieces so, can use them now can I. Now the Renault. It's a sedan version of the R11. It has a 1.4L engine with 65 horses. It's body is in pretty good shape. Underneath, the mufflers are blown apart and the fuel tank and axles are a bit rusty but the floor is in mint-condition. So far I've cleaned the starter+solenoid and replaced the alternator. The radiator still needs to be fixed or replaced. There's no other engine trouble, it starts fairly easily when pushed and it runs smoothly if you count out the tractor noise it makes without a muffler(or two). PS! If anyone has a wiring diagram for it, I'd appreciate Pics* Hopefully result
Last Edit: Sept 5, 2009 22:24:26 GMT by sapporo80
sparko
Sept 5, 2009 22:33:53 GMT
*cough*
Sept 9, 2009 20:55:29 GMT
Bless you ;D I haven't used "the stick" on any of my cars so far. So if anybody could guide me trough the proper procedures then I might just hit my Renault with a stick So far, the car starts by key now The starter motor didn't have power connected to it
Last Edit: Sept 9, 2009 21:00:47 GMT by sapporo80
Sept 9, 2009 21:09:26 GMT
They're fairly easy to lower- the front is just coil springs- the rear... I have a workshop manual that outlines the correct procedure for adjusting the rear ride height, might be able to scan it- it's for the US variant but underneath they're 99% the same. If anyone else has a "real" R9 manual, shout now
Sept 9, 2009 21:15:39 GMT
Please do explain & teach me the art of "stick hitting"
Last Edit: Sept 9, 2009 23:12:06 GMT by sapporo80
Sept 9, 2009 23:30:14 GMT
Sept 15, 2009 19:35:09 GMT
When lowering, do you think i would need stiffer torsion bars? Have: Leak-less radiator and a working FM radio (car's original) just had to whack it a few times to get the FM transistor to work again But now I'm puzzled... I don't remember what wires go to witch thermostat... so my car doesn't show me any readings and/or temperatures...
Sept 15, 2009 23:37:56 GMT
I've had several R11's and a 9, they are fantastic cars, seriously THE most under-rated small/medium car of it's time (so much better, more comfortable & better equipped than escorts or astras). The later ones with the twin choke webber carbs are best (look out for a manifold+carb in breakers yards, if you've got the crappy single choke solex, you won't believe the difference) torsion bar should put up with being knocked down a spline or two. The 1.4 engines are virtually bullet-proof, just don't over-heat it (although water pump seals usually blow before the head gasket). Rad shouldn't be difficult to find, you can modify pretty much any 9 or 11 rad to fit very easily. Electrics weren't the best, but the more basic ones usually have most things still working. I would love to drive one again, they're so rare over here now, & I covered so many miles in them, did over 20000miles in one year in my first 11 (my first ever car), it had over 168000 on the clock when I put it in storage, then I gave up the storage unit with all the cars in it (4 renault 11's a 21 and an old volvo) after I couldn't keep up with the rent!
1985 BMW 525e (eta) for sale 1973 BMW 2002 touring
Sept 16, 2009 1:36:18 GMT
The sender for the temperature gauge is at the top of the engine, passenger side, just behind the water pump pulley. If you've got the one with the fuel injection (I don't think the Broadway was injected?) then the sender(s) on the gearbox end of the cylinder head work the ECU for the injection.
Nutgone: Makes me wonder what would have happened to the 9's sales if they sold the 2-door variant with the 2.0 engine in that I have over here... probably would have eaten a lot harder into Ford and Vauxhall's market share of the era.
--Phil
Sept 17, 2009 20:21:07 GMT
Oct 10, 2009 20:47:14 GMT
Got My Car Some New Engine-mounts and Lights Also changed the oils. Both in the engine and in the transmission. Philips BlueVision - Parking lamps Philips X-treme Power - Low-beam lamps Osram Night Breaker - High-beam lamps
Last Edit: Oct 10, 2009 20:54:42 GMT by sapporo80
Cor - memories! My Dad had a 9 Broadway back in the late Eighties. Only a 1.2 though.
Well done for not following the herd and going for something different!
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
Last Edit: Nov 3, 2009 17:55:36 GMT by sapporo80
1986 Renault R9 BroadwayRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Saw alot of these when I was in Turkey on holiday (don't see many in th UK anymore ) Very cool although it needs a good old sticking
Working on it Found some lowering springs (-35mm) and new shocks. But, what manufacturer shocks should i buy? Lowering springs are V-Maxx... Still need to open-up the rear torsion suspension so i could lower it a bit
Nov 10, 2009 19:12:34 GMT
wonder, wonder...what's beige, yellow and just passed MOT today?
Last Edit: Nov 10, 2009 19:21:48 GMT by sapporo80
Nov 15, 2009 16:53:10 GMT
Just a recap: Done: New headlights New side repeaters New front repeaters Leak-less radiator Working alternator New fuel filter New engine bushings New rear brake cylinders To-Do/Need: Fuel tank Stabilizer bushings New front and rear shocks front springs A new windshield But atleast it works
Chris™
This is clearly filler material.
Nov 15, 2009 20:58:32 GMT
Please drill it into the ground, like the photoshopped picture!
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
Nov 16, 2009 22:18:48 GMT
