Nov 19, 2009 18:53:35 GMT
35mm springs will probably not lower it at all (experience) try to find a pair of megane 1 1.9 td lowering springs ,PI makes them . they do fit with a little brute force and they will be about 10-15mm loose between the top and bottom spring cups . the weight of the car will take care of that however. and this the drop you get with them lowering the rear is probably going to be a pita assuming the bars would be rusted stuck . should be closed type rear axle on the 1.4 ,so with a bit of luck they may free easier .
Nov 21, 2009 10:29:31 GMT
Last Edit: Nov 21, 2009 10:32:06 GMT by sapporo80
Nov 21, 2009 14:17:25 GMT
Wow that brings back memories as I passed my driving test in a 9. I have not seen one of those on the road in years.
Dec 21, 2009 19:53:38 GMT
Bad news, Reno's water pump is making horrid noises, but I hope it will last til' next month
Last Edit: Jun 7, 2010 12:19:36 GMT by sapporo80
Last Edit: Jun 7, 2010 12:20:32 GMT by sapporo80
Jan 16, 2010 23:50:15 GMT
Have been driving around with my new water pump for over a week Also put new stabilizer bar (outer) bushings Still having a cold starting problem...And theres a annoying squeak in the rear suspension when theres more weight on it that one person. But otherwise it's a very good runner
Last Edit: Jan 16, 2010 23:51:54 GMT by sapporo80
Lex
日本車 <3
Great
Resto-UKal
Recap: Everything works Just changed the front brake lines(both), outer steering arms need to be changed(i have those standing-by), all four wheel bearings need changing, oil needs to be changed and that's it VS. VS. VS.
jr19
that's a beige beauty, love it!
Heh, this was my mum's first car when she passed her test around 9 years ago. She had the 11, 1.4 auto, in green with beige interior. All I remember about it was, it was comfy, and the worst starter in the world. it NEVER ever started first time, sometimes taking upto 2 pr 3 minutes of cranking to work lol. Sadly, some old coger smashed into the back of it when it was parked and destroyed it She then bought a MK2 Golf after that ;D
1992 Sierra XR4x4
Jul 14, 2010 22:09:56 GMT
Jul 14, 2010 22:17:11 GMT
Ou yeah... Forgot to mention, all wheel bearings are changed, water temp. indicator is working now, new brake shoes @ da back, full year of MOT, steering arms changed, control arm bushes and ball joints changed... that is all
Jul 25, 2010 21:16:41 GMT
Last Edit: Jul 25, 2010 21:17:36 GMT by sapporo80
a realy nice Motor you have. could you tell me where do you get your new Headlights?
rodney
Jul 26, 2010 10:34:57 GMT
cool old bus , used to have a 11 turbo , easy to lower the rear keeping your old torsion bars,.
Jul 26, 2010 10:41:02 GMT
a realy nice Motor you have. could you tell me where do you get your new Headlights? My Renault's headlights are made by "DENJI" www.denji.com/index-1.htm, those don't even have the "e" marking on the glass. But I got them cheap from a online car parts shop. Good Idea OÜ www.acar.ee/ <- choose English from the top-right corner But I've heard that "DEPO" makes lights for older cars also. www.depoautolamp.com/ Then you should look up a DEPO lights dealer. Both "DENJI" & "DEPO" are Taiwan manufacturers I think...
Last Edit: Jul 26, 2010 17:16:53 GMT by sapporo80
Jul 26, 2010 15:46:20 GMT
Nice! Liking that a lot. If I ever have time / money / space in equal amounts I'd have another like a shot!
Jul 26, 2010 17:11:24 GMT
a realy nice Motor you have. could you tell me where do you get your new Headlights? Wagner make them, in both single and twin-filament flavors. --Phil
a realy nice Motor you have. could you tell me where do you get your new Headlights? Wagner make them, in both single and twin-filament flavors. --Phil The Renault R9 & Alliance headlights aren't the same. The Alliance mostly had the US standard lights (4"x6"), but the European R9 had bigger lights than the usual 4"x6", but smaller than the 7 7/8"x5 5/8" standard. FFF'n weird lights
Got me some new shocks yesterday. "Magneti Marelli" front struts and "Cofap" rear shocks. (comfort line) Also got a protection kit, top mounts & bearings for the new shocks. Weekends filled Will try to lower @ the same time i change the shocks.
