Hi there! Come join in the fun, there needs to be more evolved XJ6's!
XJS 3.6 engine mounts, in their entirety. From where they bolt on to the front subframe, up to where they bolt onto the engine, including the rubber portion. Don't mix them up as they are left and right handed!
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
thank you! if there is anything i can help you With let me know.
hoping to get the engine mounted in my car before christmast so i can start on the wiring and plumbing. my plan is to use a haltech ecu who can handle the zero offset issue.fingers crossed!
Best of luck!
JanM has proved it can be done, I'm going to start collecting stuff and trying again while running an AJ6, and you're going for it too! All inspiring stuff...
Any chance you can start a thread on your car here? More Jag content is always good.
smeden
"Full throttle until you see God,then shift to second"
How is it going with you car Rich?
And Yes more Jag content! Where are you from in Norway! I Work on the Rigs.. Usually fly out from Bergen!
Cheers Chris
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
I'm at a stanstill. I'm working my butt off clearing the garden of trees and building rubble so I can move Ropey up to my new house from my parents.
i live in the east of norway,not far from oslo. i can make a thread here soon,when i have taken some photos!
janm
Rich,
Seems like there is a healthy interest for the old XJ6 among us scandinavian folks!
And Rich, good to hear that you´re not spending your day lying on the sofa, soon back on the right track...
norwegianxjc,
Best of luck with your project, will be interesting to follow!
I've just got wind of another AJ6 powered car on the way. 4.0 AJ6 into a S1.. the ranks of the evolved XJ6's are growing.
No sofa for me, not when there's trees need felling and brambles clearing. I want my car up at my house by christmas!
Dec 22, 2013 17:37:02 GMT
dbdb
Dec 22, 2013 18:01:46 GMT
It will be a lovely car when the 3.6 is up and running - and really quite quick. The AJ6 is an underrated engine in my view.
David
Dec 22, 2013 18:17:45 GMT
It looks like you've fitted the engine so that it sits vertically in the engine bay? The AJ6 engine is supposed to lean over to the right by 10-15 degrees.
Dec 22, 2013 20:26:17 GMT
It looks like you've fitted the engine so that it sits vertically in the engine bay? The AJ6 engine is supposed to lean over to the right by 10-15 degrees. thanks for responding. i think it sits wrong..but if i switch the Mounts it gets even worse.wrong Mounts maybe.
Dec 23, 2013 10:27:47 GMT
You seem to have the mounts on the crossmember the right way round, but I'm not sure about the metal mounts on the engine. I'll check Ropey out later and get back to you. I *think* you may need to move the one on the exhaust side (right photo) up to the next set of bolt holes.. the sump should sit level.
Dec 23, 2013 14:22:40 GMT
You seem to have the mounts on the crossmember the right way round, but I'm not sure about the metal mounts on the engine. I'll check Ropey out later and get back to you. I *think* you may need to move the one on the exhaust side (right photo) up to the next set of bolt holes.. the sump should sit level. you were right!lowered the one on the exhaust side.now sits right and sump is Level!
thank you!!
Glad it was something simple! How have you rigged the gearbox mount on your car?
Dec 24, 2013 11:40:39 GMT
i havent done it yet.i don't have the xjs mount so i think i will make a bracket on the box and mate it to the original mounts..
Dec 24, 2013 12:50:23 GMT
I have the XJS mount but I don't like it. I'm planning on modifying an original mount instead, as it locates it better. I don't like the almost unhindered movement toward the transmission tunnel the XJS mount allows.
janm
Dec 27, 2013 14:43:55 GMT
Hi Rich and norwegian, Here is some pics of the transmission mount for the Getrag 290 I made for my 1970 XJ6, don´t know if the location differs for the 265 boxes you are using but maybe to some guidance anyhow. imageshack.com/a/img836/5246/gnxp.jpgI don´t doubt that the original coil/spring/rubber mounting is a very subtle piece of construction but to have that working as intended, adjusted to the weight and length of the engine/ transmission and to the correct propshaft angles just seemed to become too complicated. Was easier to use a simple rubber mount, the one I have is intended for a Volvo trans or engine. Has worked ok so far, not noticed any excessive vibrations. Only consideration is the fact that the transmission mount is bolted directly to the chassi but the engine mounts to a already rubber supported subframe, could eventually be some unwanted tensions there. Will probably test some hydraulic mount later on. And a piece of advice about the rear end; noticed when I took the pictures that my radius arms bushings are beginning to come apart, could be a good idea to use some better material for those. The XJR6 engine, and especially combined with a manual, sure is a very nice swap indeed! / JanM
looks good janm!I'm doing something similar on mine.using a rubber mount.
One more question for you guys..did u use the s3 fuel tank? Never seen one before so wondered if it has a bigger outlet to the pump than the carburettor cars..
