Mark
A bit more progress on the e30 and the red bits are now the same shade of orange as MIB my e21 daily. I think it looks way better for it too! 8) We've also replaced the cracked front screen and single wiper conversion. The brake upgrade has been just a case of going with Wilwood dynalite 4 pot calipers and some decent pads. I can't rate Wilwood highly enough and have used them for a couple of years with no issues at all. They're incredibly light too, especially when you compare them to OE cast items! The 16'' TSW rims are really just so that I can keep the Toyo888's for the track and sprints. They're just too expensive to use on the street in winter. They're not great in ice either. All that's left is to fit the new LSD and track a slight oil weep from somewhere that I hope isn't serious! I'm going to run it as a daily for a couple of weeks to get used to how it feels as it's very different to an e21. I don't mean drive like a lunatic on public roads but just get used to the feel, the brakes and the handling so that when I do make it to a track-day, it doesn't overwhelm me when I start trying to get the most out of it. It's no M3 I know, but being so much lighter than a standard car it should be great fun. I noticed my local rubbish tip has a weigh bridge and I plan to go make use of it so I can see just how much weight I've been able to lose from it? MIB is going in for some paint very soon. It still looks good but being a daily driver that does between 10 & 12k miles a year it has a few blemishes that need sorting before rust takes a hold. I have a pair of new front wings and stones etc have punished the sills and rear lower panel behind the back wheels. I'll also get the hole welded up from where I removed the second wiper. It's had a piece of sticky-backed plastic over it for the past 2 years! It's such a good colour match that no-one has noticed it but I know it's there. I also want the original seat mounts chopped out and the proper Corbeau seat mounts bolted to the floor directly so I can finally get some headroom. If anyone has a small business they'd like to advertise there's room for a new livery. We're not talking big bucks either and I know RPM did pretty well for exposure on my old e21 track car.
Last Edit: Jan 18, 2012 8:58:27 GMT by Mark
BMW 320d (fridge on wheels)
Mark
Jan 21, 2012 22:07:09 GMT
Mark
I've been working on rebuilding the BBS split-rims that I bought cheap a few weeks ago. I also discovered just why it was that they were so cheap in the first place! The donkey that had stripped them down had snapped several bolts and must have used a hammer & chisel to split the outer rim from the barrel. I managed to get the sheared bolts out - eventually - and ran a tap down the threads to clean them up. I polished the outer lips with polishing compound by hand and it has to be one of the most boring jobs ever. They came up OK though and most of the pitting polished out. The only real worry was sealing the lip and the barrel when putting them together. I was worried the chisel marks or whatever they are, would cause air leaks. Luckily though, the silicon I used seems to have done the job. Anyway, this was the end result yesterday, once they were finally ready for new valves and tyres. I'm pretty chuffed. While my orange e21 is off having wings and paint I'm running the track car as a daily driver. The best thing about that, is that I'm getting used to how different it feels. It's not what you'd ever call comfy but it'll definitely put a smile on your face when you take it out for a blast through the lanes. It sounds bloody lovely too!
Mark
Jan 29, 2012 18:47:22 GMT
Last Edit: Jan 29, 2012 18:48:36 GMT by Mark
Mark
Feb 15, 2012 11:44:39 GMT
Mark
Feb 17, 2012 21:54:24 GMT
iane
Feb 17, 2012 22:58:40 GMT
Wow!!! You've been busy! That reminds me my e12 needs some minor work underneath.
Mark
Can you do any welding yourself Ian? Hopefully there won't be any horrors but be sure to check where the brake lines and stuff run along and keep crud against the floorpan & sill seam.
There are a couple of oily jobs to be done too. The 'O' ring for the dipstick tube needs replacing, as it started weeping, plus there's a similar weep from one of the diff seals. The diff had been rebuilt but, because it had been stored prior to fitting, one of the seals must have dried out but its easily sorted.
One of the best changes has been chopping out the OE seat brackets. Whenever you fit different seats in an e21 they end up being way too high. It's probably only a couple of inches but as I'm nearly 6' 3'' anyway, there's not much in the way of headroom. Now though, we've fitted the Corbeau runners that came with the seats and I can finally feel that I'm sat in, rather than on, the car when I drive it.
Next on the agenda will be removing the rear seat, re-carpet and rear cage. I also want to fit a 75bhp shot of Nitrous but that won't be for a while yet as I have the TWR/Alpina to restore first.
teaboy
Make tea, not war.
Feb 18, 2012 10:10:40 GMT
It just goes to show just how much corrosion can fester under the surface. It's only been 4 years since the last time the shell was stripped and painted I didn't realise it was such a rotten old dog Mark ;D Four years doesn't seem very long for it to get like that, even in daily use. Nice to see the old girl getting some love, it is still one of my favorites.
Mark
Feb 18, 2012 11:07:19 GMT
It just goes to show just how much corrosion can fester under the surface. It's only been 4 years since the last time the shell was stripped and painted I didn't realise it was such a rotten old dog Mark ;D Four years doesn't seem very long for it to get like that, even in daily use. Nice to see the old girl getting some love, it is still one of my favorites. ;D Just proves you can't polish a turd but you can roll it in glitter! I know what you mean though, but then again, there's been plenty of rain, snow, ice and road salt in that 4 years and it lives outside 24/7. Roll on Tuesday when it finally comes home. There are a few subtle changes too, like the Engelmann mirrors I've had sat around since I first bought it. They weren't cheap but when you break them down into their component parts, to paint them, you get to see just what good quality parts they are and why they cost so much to buy! Hopefully, I'll get some decent pics.
Feb 20, 2012 20:13:48 GMT
Looks like you made the right decision to get it sorted before it got too bad
Mark
Feb 20, 2012 21:00:56 GMT
I think so Tony. When my 6 numbers finally come up I'll have the whole shell media blasted and galvanised prior to repairs and repaint. It'll be time to slot in the V10 engine from an M5 then and full Group 5 arch kit with mammoth BBS splitrims to fill them. Who needs Ferraris? I had hoped to be getting MIB back tomorrow but there was a delay getting the fitting kits for the Engelmann mirrors. Mick @ Pristine has removed the OE door mirrors and made up some blanking plates. Early cars didn't have the large plastic mirrors but the whole window frame changed when they were brought in. These come off. These go on. The group 2 cars had Engelmann mirrors. The lottery win look. I know where this genuine ex works car is for sale too - £40k though.
Mark
Feb 24, 2012 20:56:35 GMT
rodney
Feb 24, 2012 22:14:39 GMT
thats lovely,.
GT4ME
Feb 24, 2012 22:32:00 GMT
That looks great Mark, you must be well pleased with it. Lewis,
Mark
Feb 24, 2012 22:43:30 GMT
Mick @ Pristine did a really great job and it's nice to know there's no rust anywhere anymore. I might even go for a blast up to Race Retro this weekend?
Bigdoors
cherwelldoors.com
Feb 25, 2012 10:20:03 GMT
Fanbleedingtastic!!! Can't wait to get mine back on the road with it's new power ;-)
Mark
Mar 22, 2012 12:29:25 GMT
Since coming back from www.pristinebodyworks.co.uk I have been racking up the miles with MIB in daily use once again. A week or so ago though, the exhaust developed a really annoying rattle at about 1800rpm. It sounded like a loose clip or something but closer inspection revealed a couple of manifold nuts were loose! 12mm spanner in hand I figured I would just nip them up but they simply pulled out with my fingers and revealed the thread was stripped. Not good. A combination of not much room and hands like shovels means I think I will struggle to re-tap the head with a new, coarse thread. I'm thinking that if I have to go to the trouble of taking the engine out, to re-tap the threads, I may as well take the opportunity to do a few other jobs? I'd like a proper 6 branch rather than the modified stock e36 item and the OE fuse box and wiring loom could also be junked in favour of fitting a modern fuse box & fuses and custom loom. I can pretty up the whole engine bay. So, fingers crossed, the manifold lasts with 2 less bolts while I save my pocket money. Anyone else fitting an M52 engine, be sure to fiddle with your nuts! Seeing as the weather is getting better I also refitted my Minilites and 888's. The Yokohamas were great during the winter but they couldn't compete with 888's on a sunny day. Especially along country roads.
Bigdoors
cherwelldoors.com
Mar 22, 2012 13:43:50 GMT
EPIC!!!! I wish I had more spare time to get mine finished.
