Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Got a bit more done Tapered channel made from 2 1/2" angle to join O/S front and rear chassis sections........ Rest of front section wrapped in 6mm plate Ram in place............ Extention plates welded into lower arm to accept ram.......... I've just got to weld the bump-stop perches back on clean up all the welds and I can move on to the body
Chops
Apr 27, 2010 23:36:26 GMT
Next was welding the bump-stop perch back in place then at the end of March I lost my storage so it was on to another trailor and off to rented accomodation. bump-stop......... on the move again
Chops
Apr 27, 2010 23:49:28 GMT
Last Edit: Apr 27, 2010 23:50:37 GMT by Chops
Holy curse word dude Amazing work!
Holy curse word dude Amazing work! Motion Seconded.
wanted, 25th hour. Required daily, cash waiting
Chops
Apr 28, 2010 20:33:10 GMT
Thanks
Chrisâ„¢
This is clearly filler material.
Apr 28, 2010 21:32:13 GMT
Looks awesome, what a beautiful car too ;D
Also, maximum respect for towing it with the beamer!
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
Chops
Jun 28, 2010 23:14:26 GMT
Last Edit: Jul 14, 2010 23:13:54 GMT by Chops
Chops
Jul 15, 2010 22:53:59 GMT
Chops
Jul 15, 2010 23:18:36 GMT
On the engine I've changed all the core plugs, broken manifold studs, all the large gaskets (sump, valve covers, manifolds etc) and chucked some new temporary oil in. The sump neaded a bit of TLC (with a hammer) because it was stoved-in and touching the oil pick-up so, seeing as it was off, I gave it a coat of paint. Next I decided to answer that question that's probably been on all our minds for so long.............. "Can you fit a 383 big block back into a C-body in your lunch break on your own? OK maybe not everyones mind but I was wondering................... .....................Um..... yeah, you can
Last Edit: Jul 16, 2010 23:26:56 GMT by Chops
ha ha ha dude you need an s on your chest and some funky pants ;D , so ready for bug jam then ? what about RR gathering ?? top work as always
THE ONLY WAY IS LOW !!!!!!!
Jul 16, 2010 15:01:58 GMT
are you keeping the AC pump? those things are super heavy
10mpg
Club RR Member Number: 204
Jul 16, 2010 22:09:32 GMT
Last Edit: Jul 16, 2010 22:10:34 GMT by 10mpg
Jul 16, 2010 22:44:32 GMT
a tad over 20 kilos actually, and you can't get the gas for that old stuff now.
Chops
Jul 16, 2010 23:21:55 GMT
what about RR gathering ?? Nah, still got the rest of the body to do and fit the juice. Next year hopefully are you keeping the AC pump? those things are super heavy Yes it acts as an idler for the alternator so I'm leaving it on for now Judging by the several sheets of 3mm steel in the chassis and the 1/4 of a ton of batteries in the boot, + pumps, lines, rams I doubt he's bothered by an extra 15kg of A/C compressor ;D ;D It was only 2 sheets but they were 6mm not 3mm a tad over 20 kilos actually, and you can't get the gas for that old stuff now. I happen to know someone who claims to have access to some of the old school naughty gas you speak of so I'm hoping to get the air-con going again one day
How awsome is this thread? I only just stumbled on it! Jammy curse word
10mpg
what about RR gathering ?? Nah, still got the rest of the body to do and fit the juice. Next year hopefully Yes it acts as an idler for the alternator so I'm leaving it on for now It was only 2 sheets but they were 6mm not 3mm a tad over 20 kilos actually, and you can't get the gas for that old stuff now. I happen to know someone who claims to have access to some of the old school naughty gas you speak of so I'm hoping to get the air-con going again one day You can buy conversion kits for a lot of the old AC compressors, quite a lot of the compressors are fine without major modification other than the valaves other than that it's just a case of changing all the O rings for modern ones... I'm not sure R12 is illegal to have, but you do have to have the correct permits ect, i think is is illegal for a garage to fill you car with it and I know it's illegal to empty your system by venting it to atomshphere, but i think you're higly unlikely to get done for filling your own car with it.. either way i'd just convert to 134a it's no biggy usually..
Last Edit: Jul 17, 2010 8:56:20 GMT by 10mpg
Chops
Jul 18, 2010 13:40:22 GMT
You can buy conversion kits for a lot of the old AC compressors, quite a lot of the compressors are fine without major modification other than the valaves other than that it's just a case of changing all the O rings for modern ones... I'm not sure R12 is illegal to have, but you do have to have the correct permits ect, I think is is illegal for a garage to fill you car with it and I know it's illegal to empty your system by venting it to atomshphere, but I think you're higly unlikely to get done for filling your own car with it.. either way i'd just convert to 134a it's no biggy usually.. Ahh, I didn't realise it was a do-able conversion, thanks for the info. In the 12 or more years I've had the car the A/C has never worked but as there is a bottle of R12 kicking around, I'll test the system with that first and if it's ok I'll probably convert to R134a
Chops
Jul 18, 2010 13:42:28 GMT
How awsome is this thread? I only just stumbled on it! Jammy jolly pain in the backside Cheers
Jul 18, 2010 20:04:36 GMT
I'd be tempted to just fit a modern pump and hoses, then you will have modern fittings for the filling gear and can run r134a. It will be lighter and smaller. Considering doing that on my Fury. I don't really like AC or need it but I do like things to work if they are there.
