haven't done much to the car, but I figured it was time to give a bit of an update. I took the car out for a drive before it got painted and there was an issue once I started going up and down hills. My Initial thought was that my float was off and that I needed to set it; then I was told that i was shooting a stream of gasoline out of the rear of my car. since it has been on jacks and level there hasn't bit a drop of gas leak out of it, but today when I finally checked the damage this is what i found. note: the size of the hole did not change after i took it off of the tank. seeing this, and the lack of wanting to buy an unneeded line, I decided to plug the hole and just remove my evaporator tank. It was a PITA due to me not wanting to drop the fuel tank, but all in all I made all the lines work and fit. After I took care of the Evap removal I set my floats, and am I ever glad I did because they were both well off... After the floats were set, I really wanted to paint my wheel wells. Here are the befores... The most common color that I have seen used is either body color, or some form of black... I found a can. and this is what followed. because after all there is no better color that matches ultra-flat deep forest green and satin black like metallic gold. And then my ebay headlights came in; some curse word bulbs in a glass front housing all for $20 shipped to my door! and as much I hate seeing yellow glass on the road... I really think they would look smashing with my color scheme; for now though, I will stick with these. I'll get my 240sx caliper brackets in on the 2nd of march, and I'll post some updates shortly after that!
Feb 26, 2010 15:18:18 GMT
Yes! The gold arches look deadly! Ha!
Feb 26, 2010 18:14:06 GMT
Yes! The gold arches look deadly! Ha! Genius! Although would be pretty pointless in the UK with all the cr*p on the roads here.
carmad
Feb 26, 2010 18:27:35 GMT
i dunno what to say gold inner arches
nugget
Feb 26, 2010 21:55:10 GMT
Legend! LOL repost this on the MG owners club forum, it'll catch on
Feb 26, 2010 22:32:31 GMT
fasntast! post the link of the thread, I am curious what they have to say about it.
will
Feb 26, 2010 23:12:49 GMT
Lovin the paint
Sven
Feb 27, 2010 20:31:14 GMT
Mighty!
1969 Chevrolet 4x4 C10 Pickup 1969 VW extended cab pickup (doka) 1980 Volvo 240DL 1995 Mazda Miata MX-5 2007 Toyota FJ Cruiser 2007 Dodge Ram 2500 Cummins Diesel 2011 MK Indy R (building)
Feb 27, 2010 20:57:47 GMT
I've gotta give it to you; That colour combination is pure brilliance! It's a feat to get a car with golden inner arches to look classy rather than tacky! Can't wait to see it finished.
Bookmarked ;D
Last Edit: Feb 27, 2010 21:12:55 GMT by skidracer
1968 Gilbern Genie 1969 Lincoln Continental MK3 1974 Datsun Cherry 100A 1979 Ford Mustang 2.3 Twincam 1987 Toyota MR2 1991 Eunos Roadster V-spec 1994 Toyota Supra SZ
carmad
tofu
Feb 28, 2010 14:59:01 GMT
this is looking fantastic... that colour scheme looks the nuts
Feb 28, 2010 16:13:31 GMT
Coming together well. Those lights really work quite nicely
I was able to get some free power with an L28 (n42 & n47), thanks to a guy on hybridz; so I will be in the process of transferring what I need from my spare engine onto it. On a build note, my MM 240sx brake calipers came in and to my surprise they match my wheel wells! Then after a few cigarettes, a trip to the dump, and an engine/tranny dismantle I finally got the rear brakes installed! while it isnt the prettiest of brake connections it will work. in order for it to work I had to grind off the tab that aligns the stock banjo. Tomorrow I will get them bled, and then the first shots of the car on the ground with the 15x10s. Then I play the waiting game, probably till thursday, when my carburetor kit comes in and hopefully get the L24 running while I have fun with the L28. --Those guys over on the MG forum didn't seem to like me so much guess it just didn't hit them that the whole point of having a build thread is to show off what you can do. After all cars are toys; why not just have fun with them.
Never mind them man, you're a legend to the rest of us! Looking forward to seeing this on the wheels and on the ground. You'll have to get a video up when its running again. Excuse my Datsun engine ignorance but what were you able to get fromt he other engine?
there is a marginal 10hp difference from the L28 to the L24, but I picked it up because i think my engine will go soon and I like the idea of a back up. If i really wanted power I would talk to my neighbor who has a stroker 350 v8 sitting in his garage that was meant for his stock car. but that idea will come after i get a welder
Ah right, always good to have a back up alright. If I really wanted power I would talk to my neighbor who has a stroker 350 v8 sitting in his garage that was meant for his stock car. but that idea will come after I get a welder That's the spirit!
So now for the next bit of building... After the brakes were bled it came time for me to intall the e-brake cables onto the brakes themselves. now while Modern Motorsport sells a bracket with cleavis bolts and cotter pins for $30, I knew that I would be able to get the job done for significantly cheaper. And I was able to do just that, total cost = $0 here is where the e-brakes lines sit in comparison to the caliper started with the idea of using a bracket that came off of the drum brakes, but it turned out that the holes were too close together and I don't have the right tools to make the holes longer. So then I looked around for what I had, and then found some Plumbers Tape. folded it twice and cut. and sure enough the spacing for the larger hole was the perfect distance between the e-brake line and the caliper bracket. just to show you the actual thickness of the bracket, here is it compared to the modified bracket that I was going to use. here is the test install, I say test because these bolts will be replaced with some clevis bolts and cotter pins when I head to the hardware store tomorrow; which will bring the total cost to about $5usd oh and to get the e-brake line to stay in the 240sx e-brake bracket I swaped the brackets on the calipers so that they would have a near perfect angle to the caliper itself, and then used two 7/16" spring washers and an extra brake line holder thing. and by the way, that line is not moving anytime soon. In order to get the e-brake lines to have less slack, and significantly less rubbage on the drive-axle, I crossed the lines above the differential and viola! With some slight change of location to the sping that holds them up and out of the way the stock e-brake lines are now in the perfect length. I will add a clip here and there to remove all of the rub tomorrow.
Stu
Welcome back, love the new project!
'89 BMW E30 325i Sport, '04 MINI Cooper S, '09 Volvo V70 D5
