B-8-D
down to one car!!
Mar 25, 2010 20:58:20 GMT
You are a strange, strange individual B8D, but one who I like already. I've already greatly enjoyed reading this as I rather like diesel myself. You MUST run a straight through exhaust for that tractor/ industrial equipment sound goodness! well I'm hoping for just a 2" bore cherry bomb running diagonally down from the tubby and a turn out just behind the front wheel... I'm thinking the turbo will provide some silencing ;D si
conrad
Here to fix your cabin.......
Mar 25, 2010 21:32:26 GMT
Turbos do provide a bit alright, had a straight pipe on my 2.0 nissan diesel powered rekord which was WAY louder then my 318 TDS which is 1.7td and has full straight pipe around the same diameter. Same with a 2.8td isuzu trooper, the rekord was easily 15 percent louder than that, and the trooper had a 3 inch pipe exiting in fron of the rear wheel.
Personally i wouldnt see the need for a cherrybomb, and i'd be worried it's make it sound a bit odd. Though i'm open to hearing it, i just never bothered with them. The 318 tds that i have now has a dodgy random bits of pipe found lying around special on it, which i should really do something about but i cant be bothered.
Wow - top fabrication on that bracket - seemless welds! And great to see another estate on the road - even if you are putting a deisel lump in it. I respect the path your taking there, even though it makes me want to cry a little. The estates are rare as hell these days, especially on the road, but you know, your car. Loving the attitude and the skills though. top work
B-8-D
down to one car!!
Mar 30, 2010 17:41:35 GMT
ive not done a lot recently but its still a little closer to the day i fit it... ive now got a getrag 240 manta gearbox that ive had soaking in jizer for a week so it should be a bit cleaner when ive finished cleaning it.. ive got a prp flange for the gearbox now and ordered a new carlton ebc clutch kit.. although i will only use the friction plate and the release bearing does anyone want a new carlton pressure plate?? buck shee... i am on the lookout for a starter and a diesel pressure plate for it now if anyone has one? ive decided i want an oil cooler so ive fitted a sandwich plate under the filter.. and will run a oil stat and 15 row cooler... the newly painted water pipes are all on and so is the intake manifold all with new gaskets.. i still need to make a alternator adjuster and finish making the exhaust and turbo setup.. I'm toying with the idea of fitting a charge cooler and a intercooler or maybe just one or the other will take some more pics when ive made more progress.. si
Mar 30, 2010 17:44:47 GMT
Ive got a complete new chargecooler kit from a Nissan if you need one...
Koos
B-8-D
down to one car!!
Mar 30, 2010 18:19:49 GMT
Ive got a complete new chargecooler kit from a Nissan if you need one... cheers bud.. will keep it in mind but..... i have a legacy one that i could use but will prob make one tbh then i can make it the size and shape i need.. may even get another intake and build one into that?!! si
Hey bud, Did you pick up the box of bits I left for you at A52 at the last playday? I wasn't there long and I turned up pretty late in the day so must have missed you. Took me ages to find the box, was under a load of 924 parts
Faster. Faster. Until the thrill of speed overcomes the fear of death.
B-8-D
down to one car!!
Mar 31, 2010 17:01:06 GMT
Hey bud, Did you pick up the box of bits I left for you at A52 at the last playday? I wasn't there long and I turned up pretty late in the day so must have missed you. Took me ages to find the box, was under a load of 924 parts oo no i didnt know.... I'm all excited now.. whats in the box??? hopefully a starter maybe a clutch pressure plate etc.... si
droopsnoot
nowt wrong with "awfull check orange"..... I'm trying to resist a droopsnoot front... although may change the front lights in it for twin square... si I used to run a flat-front 1800 Firenza, and I fitted the twin square lights off a VX4/90. I thought it looked pretty good, but I never met anyone who agreed, and the light output was awful so I took them off again. Didn't need much modification to the grille as I recall. Still got the lights in my shed.
B-8-D
down to one car!!
back from the dyno day yesterday,,, I'm quite pleased.. 50.1hp... and 55ftlb torque.. not bad for a completely std 1159cc... actually appart from tappets need adjusting it seams its a really good engine...!!
well at least theres one good thing about the car... and I'm removing that bit!!!!! ha ha
and not bad since its only around 1hp down on sleeperviva's car.. which I'm sure he doesnt mine me mentioning! ;D ;D ;D si
Last Edit: Apr 5, 2010 11:14:50 GMT by B-8-D
B-8-D
down to one car!!
I'm also having ideas into using a vnt turbo.. but even though i think i can get my head around but not sure if they are going to be robust enough? hmmm decisions... si
conrad
Well you could jsut do what i' ddo, try it anyway, then if (more like when) something gos extremely wrong, you'll know to do something different the next time
B-8-D
down to one car!!
ive been just bolting a few bits on now bits have arrived.. new custom phospher-bronze spigot bush machined up and fitted.. new carlton friction plate with std TD pressure plate.. water pipes now on too.. and oil takeoff sandwich plate for oil cooler.. all shiny.. cleaned up the manta box was filthy.. now better not shiney but clean enough.. i put it next to the carlton gearbox just to see for size comparison.. ive still got a fair amout of little bits to do though.. make a gearlever setup.. make the turbo fit the manifold and rotate center housing.. make turbo oilfeed and drainback.. make turbo exhaust elbow to downpipe.. make alternator adjuster bracket.. make gearbox mount (wont be finished till i start fitting it to car) trim end of gearbox input shaft and fit gearbox.. fit starter and oilcooler pipes.. start and run on floor to check all is well then source intercooler/chargecooler and rad and fit.. si
B-8-D
down to one car!!
Apr 15, 2010 20:14:48 GMT
ok ive got the gearbox on and it looks more and more ready to fit.. but ive still got stuff to do.. front half of a random prop was found and the slider I adapted and drilled to suit.. si
Last Edit: Apr 15, 2010 20:19:48 GMT by B-8-D
B-8-D
down to one car!!
Apr 15, 2010 20:18:52 GMT
finally I get my wheels back and attack them with the drill.. with now the new stud pattern done I use the rest of a very rushed lunch break at work to bolt them on.. BEHOLD!!!! weller power.. ;D si
Last Edit: Apr 15, 2010 20:27:32 GMT by B-8-D
Apr 15, 2010 21:12:02 GMT
Looking good.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
rtlkyuubi
Low and Slow
Apr 15, 2010 21:16:34 GMT
Wellers and viva's go hand in hand ;D good job!
DutyFreeSaviour
The skillz some people have on this site annoys the bejeezus outta me ;D - in a nice way. Lovin' the car fella - engine work has me lost a little but that's easily done Looks excellent as is - cousin had a horrendously 70's orange one years back - ex funeral home body mover with bad paint job.... females in the family wouldn't get in it ;D Wathcing and learning - fantastic workmanship..... John
Colonelk
Club RR Member Number: 83
Apr 16, 2010 16:32:05 GMT
Wellers really go with the whole look. Love it
craig
Apr 16, 2010 17:26:54 GMT
I'm starting to like Wellers now.
and ducks....
