I could do with some opinions on my next project, I’m looking for a load lugger but not something transit sized, with practicality, at least some semblance of economy, and at least some style – even if it has to modded into it. This project will not be starting till at least the spring, I like to plan my projects and if mods are too be made I tend to collect the bits I want prior to buying the car. Current choices are – Bedford Rascal/Suzuki Supercarry OK a bit of an odd one admittedly but recently I have kind of fell for the cutesy look of these things. I’m thinking a mild lowering job, tasteful 13 inch alloys, better seats, and ….a Suzuki swift GTI engine. As far as I can make out the F10A engine Rascals/Supercarry's came equipped with is the same/similar to the Swift GTI block and have matching gearbox bell housings. Board out rear and carpet. Front end restyled similar to the pictured one here, but minus as many vents as possible for a smooth look, and definitely omitting headlight eyebrows. Austin Maestro Van Another odd one, basically take one Maestro van, fit Maestro car front wings, plastic bumper and full size headlights. Maestro car door trim panels and carpet and better seats, board out rear and carpet, insert Perkins turbo diesel engine from Montego and enjoy Vauxhall Carlton Estate Thinking 2.3 TD version if I can find one (fit one from a saloon if not, though prop shaft solution could be interesting). GSI3000 front bumper and possibly skirts, front struts from same to lower front and lower rear to match. Sierra Estate I found this picture ages ago while surfing, and cant for the life of me remember from where, but anyway. A Sierra estate much the same as this (not sure about the oval exhaust) with 2.3TD from Mk3 Granada (the Granny cross member is supposed to bolt straight up to the Sierra) with a high ratio Granny LSD axle (again swappable with minor mods) Mk2 Granny estate See picture, exactly like that minus black grill and red stripes, probably with Mk3 Granny TD engine, though this could be challenge to fit as I’m fairly sure the Mk3 cross member doesn’t fit, although a Mk3 Granny axle is supposed to which could give cheap LSD – are the alloys on the one in the picture Penta’s And last but not least Volvo 700 series or 240 Estate Don’t know much about Volvo’s having had nothing to do with them before, but for reliable load lugging Volvo tend to be the king. Anyone know much about the 700 series diesel engines.
Last Edit: Feb 1, 2006 21:33:17 GMT by steve3
philly
what bout a 5 series touring, in the weeds, fat wat wheels, de chromed, your bank manager woul'nt know if it was his 3 o clock or if he was getting done over again
spaceframe mini project, bmw 635csi, mx5
bstardchild
Club RR Member Number: 71
Opinions and advicebstardchild
@bstardchild
Club Retro Rides Member 71
Vauxhall Carlton Estate Thinking 2.3 TD version if I can find one (fit one from a saloon if not, though prop shaft solution could be interesting). GSI3000 front bumper and possibly skirts, front struts from same to lower front and lower rear to match. Top car - dog engine...... Sorry but the 2.3 puff boosted lump is both long in the tooth exceptionally tractor like and downright unreliable - esp if engine oil changes aren't carried out frequently Now the 3.0 12 V 5 speed manual version will do 30+ mpg on a run and will pull anything you car to put in or tow behind it - it will achieve 137mph banging away on the limiter all day long too!! I've had two now and one was used to drag a Monza GSE on a 1 tonne trailer back 100 miles and we forgot teh trailer and car was there - the guy in Bedford in a pimped XR3i who thought he outdrag us from the lights got a big shock too - totally wasted him ;D Oh and I'm a bit biased here so i won't comment on the other choices except the sooty van - that would be cool
Any of those would be cool, IMHO... bigest problem with estates/vans is finding one that's not been driven into the ground, and then some... Have you thought about a MK3 Astra estate/van? XE transplant, slammed on steels, NATO green....
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
Guess what I'm going to suggest? Volvos are solid, lug massive loads, have huge roof rack potential and if you find a GLT, all the toys. There's plenty on the bay, or take a look on the Volvo club forum www.volvoclub.org.uk/forum/forumdisplay.php?f=28Always loads there. Parts are cheap and plentiful. I'm getting boring now, aren't I......
Peugeot 307sw - Suzuki SV650S - MX5.
Had'nt thought about the Astra estate/XE combo - food for thought.
I've got a GSI3000 12 valve and while I could get 27mpg (on the fuel computer) on a long run 17mpg was normal urban, though once got it down to 9mpg giving it some serious hoof through Nottingham at 6am while late for work. Bit of a bummer about the 2.3TD engine, as your the Carlton guru on here do you know if the Frontera 2.5TD lump is a) any better b) would match a 2.3 gearbox
525tds touring, cheap, good engine (tuneable!) look for an ix as they were four wheel drive.
J
bstardchild
@bstardchild
I've got a GSI3000 12 valve and while I could get 27mpg (on the fuel computer) on a long run 17mpg was normal urban, though once got it down to 9mpg giving it some serious hoof through Nottingham at 6am while late for work. Bit of a bummer about the 2.3TD engine, as your the Carlton guru on here do you know if the Frontera 2.5TD lump is a) any better b) would match a 2.3 gearbox Not a clue on the later engines sorry - Vauxhall stopped making cars I like in 1994 12V poor mpg is 99% down to the AFM spring needing a reset makes a massive difference - the other 1% is down to the number of leaks possible from the fuel rail (sorted on all my cars )
thevert
Mini builder
Drift Car? a Volvo ? never! There damn cheap to
Shoulda bought Ferg's 300C estate!
There was that RWD Mazda 323 estate someone posted that was on eBay.
12V poor mpg is 99% down to the AFM spring needing a reset makes a massive difference - the other 1% is down to the number of leaks possible from the fuel rail (sorted on all my cars ) That sounds interesting. How do you do that then?
1972 Fiat 130 1985 Talbot Alpine 1974 Lancia Beta Saloon 1975 + 1986 Mazda 929 Koop + Wagon 1982 Fiat Argenta 2.0 iniezione elettronica 1977 Toyota Carina TA14 BEST CAR EVER!!!!!!!! 1979 Datsun B310 Sunny 4-dr 1984 Audi 200 Quattro Turbo 1983 Honda Accord 1.6 DX GONE1989 Alfa 75 2.0 TS Mr T says: TREAT YO MOTHER RIGHT!
mk1 escort van, volvo 240
once again rocking with 1117cc and 4 gears!
filmidget
East Midlands
Mostly Lurking
The diesel in the Volvo 740's is a VAG unit and not wonderful. The petrol 2.3 turbo intercooled however is very wonderful.
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
bstardchild
@bstardchild
12V poor mpg is 99% down to the AFM spring needing a reset makes a massive difference - the other 1% is down to the number of leaks possible from the fuel rail (sorted on all my cars ) That sounds interesting. How do you do that then? Without Liability?
Had'nt thought about the Astra estate/XE combo - food for thought. I've got a GSI3000 12 valve and while I could get 27mpg (on the fuel computer) on a long run 17mpg was normal urban, though once got it down to 9mpg giving it some serious hoof through Nottingham at 6am while late for work. Bit of a bummer about the 2.3TD engine, as your the Carlton guru on here do you know if the Frontera 2.5TD lump is a) any better b) would match a 2.3 gearbox The later 2.5 and 2.8 are both isuzu engines much better than the 2.3`s. I am not sure whether they would fiut the 2.3 gearbox though. Frontera`s have an isuzu gearbox and I am not sure if any engines from fronteras bolt onto normal vauxhall boxes. I was told a lot of years ago that the 2.4cih frontera engine wouldnt bolt to a manta gearbox. The 2.5`s and 2.8`s are also used in the vauxhall brava pickups and its possible to get those in 2wd so you could get a box from one of those.
Panda Matt
Datsun Owners Club Wannabe
Why hasn't anyone mentioned the merc w123 estate? Get a diseasel and you've ticked all the boxes surely. Also, cult car, will go up in price in a few years if well looked after IMHO, you could actually make money on it! £750, 12mths t&t and it's an IOW-registered car
bstardchild
@bstardchild
Well I'll phrase it another way It's easy to screw it up and get it wrong regarding the AFM - if it's without liability it's not my fault if you don't follow the insturctions to the letter and end up with a mess
Fair enough!!! I was only asking, i'm not going to hold you responsible for anything if I burn my house down! I don't even have a senator, I just wondered what it entailed.
bstardchild
@bstardchild
Fair enough!!! I was only asking, i'm not going to hold you responsible for anything if I burn my house down! I don't even have a senator, I just wondered what it entailed. It applies to an awfull lot of Vauxhalls and Opels in fact a lot of cars with bosch AFM's - I won't thread jack here any more I'll find the pictures and do a separate post
