ud-uk
Living the French dream!
Feb 23, 2017 16:07:42 GMT
How much would it be for 2 identical small ones? I have 2 rear doors on my van both about 15" square. A small backflash with just 'CF' on each about 3" or 4" high would be ace. Ill have a measure and see what size would work. They would be £8.00 inc for the pair, let me know if you're interested and I'll get them made up cheers Mark
1991 Transit Dormobile, The Sweet Bus - SOLD - Now trading in the Bristol area
1991 Mercedes 230 CE - SOLD
1987 Renault Express van - SOLD-
1995 Vauxhall Calibra SE4
Feb 23, 2017 16:44:27 GMT
Yep, very much interested. Ill measure up to see what size they want to be and get back to you.
Thanks.
I bought one for my Mk2 Fezz, but it seems to be longer than the screen it's self (it's like 40 inches, but the back flash is 45'') and the striping doesn't seem as long as others, as opposed to the font its self.
F503 FRM - MK2 Ford Fiesta - (Mo Filla, No Thrilla)
T527 LCJ - S2 Peugeot 106 - (Donor car for an AX GTI - scrapped) CA57 GWP - MK6 Fiesta Zetec S - (Daily derv go-kart)
gezzard
Club RR Member Number: 69
Hi, I've looked on your eBay listings but can't see any Renault ones, would it possible to get one in red?
ud-uk
I bought one for my Mk2 Fezz, but it seems to be longer than the screen it's self (it's like 40 inches, but the back flash is 45'') and the striping doesn't seem as long as others, as opposed to the font its self. All the backflashes are made 1250mm wide, this allows the stripes to be trimmed to suit, the remaining length of the stripes will be different for each car depending on the length of the text obviously.
ud-uk
Hi, I've looked on your eBay listings but can't see any Renault ones, would it possible to get one in red? Hi yes I can list some Renault backflashes, I'll try and get them listed on ebay tomorrow all the best Mark
ud-uk
Hi, I've looked on your eBay listings but can't see any Renault ones, would it possible to get one in red? Hi I have now listed some Renault backflashes, the item number is 201844135762 cheers Mark
Got my CF ones fitted, looks ace, pic in my build thread.
For future reference though, and maybe to help others, can you give some fitting tips?
I followed the instructions. Cleaned window thoroughly with panel wipe. Misted window with soapy water, positioned sticker then started squeezing the water out with a credit card.
But even after 10 mins of HARD squeegeeing, when I tried removing the backing it just kept peeling off the sticker. I ended up having to hold the sticker on the window with the credit card while I peeled the backing off and had to cut the backing into loads of pieces so I could keep it all in the right place. I even had one section just fall off. Even after hard squeegeeing the sticker itself onto the glass if the backing touched it again it pulled the sticker off again.
I got it on eventually, seems ok, but was a nightmare to do.
What did I do wrong?
Too much soap (used a couple of drops of dish soap)?
ud-uk
Got my CF ones fitted, looks ace, pic in my build thread. For future reference though, and maybe to help others, can you give some fitting tips? I followed the instructions. Cleaned window thoroughly with panel wipe. Misted window with soapy water, positioned sticker then started squeezing the water out with a credit card. But even after 10 mins of HARD squeegeeing, when I tried removing the backing it just kept peeling off the sticker. I ended up having to hold the sticker on the window with the credit card while I peeled the backing off and had to cut the backing into loads of pieces so I could keep it all in the right place. I even had one section just fall off. Even after hard squeegeeing the sticker itself onto the glass if the backing touched it again it pulled the sticker off again. I got it on eventually, seems ok, but was a nightmare to do. What did I do wrong? Too much soap (used a couple of drops of dish soap)? Glad to hear your flashes look good, sorry to hear you had a bit of a drama fitting them, there could have been a little to much soap, just a small drop is enough, just to make the water slippery. The key really is to leave the graphics to dry properly before removing the application paper, hours not minutes when the temperature is cold, in the summer you could remove the paper after about 30 minutes and it should be fine. I think you didn't leave them to dry properly before trying to remove the paper, glad you got them sorted in the end.
Got my CF ones fitted, looks ace, pic in my build thread. For future reference though, and maybe to help others, can you give some fitting tips? I followed the instructions. Cleaned window thoroughly with panel wipe. Misted window with soapy water, positioned sticker then started squeezing the water out with a credit card. But even after 10 mins of HARD squeegeeing, when I tried removing the backing it just kept peeling off the sticker. I ended up having to hold the sticker on the window with the credit card while I peeled the backing off and had to cut the backing into loads of pieces so I could keep it all in the right place. I even had one section just fall off. Even after hard squeegeeing the sticker itself onto the glass if the backing touched it again it pulled the sticker off again. I got it on eventually, seems ok, but was a nightmare to do. What did I do wrong? Too much soap (used a couple of drops of dish soap)? Glad to hear your flashes look good, sorry to hear you had a bit of a drama fitting them, there could have been a little to much soap, just a small drop is enough, just to make the water slippery. The key really is to leave the graphics to dry properly before removing the application paper, hours not minutes when the temperature is cold, in the summer you could remove the paper after about 30 minutes and it should be fine. I think you didn't leave them to dry properly before trying to remove the paper, glad you got them sorted in the end. I didnt leave them to dry at all! I thought just squeegee out and peel Thanks, ill know next time I do any decals, this was my first try so figured id done something wrong
Hi, I've looked on your eBay listings but can't see any Renault ones, would it possible to get one in red? Hi yes I can list some Renault backflashes, I'll try and get them listed on ebay tomorrow all the best Mark Cool, cheers! I'll get a pic once mine is fitted I had a bit trouble last time trying to get it straight and in line!
Hi yes I can list some Renault backflashes, I'll try and get them listed on ebay tomorrow all the best Mark Cool, cheers! I'll get a pic once mine is fitted I had a bit trouble last time trying to get it straight and in line! I measured and put bits of masking tape on the outside to give me somewhere to aim at when putting the decal on the inside.
Cool, cheers! I'll get a pic once mine is fitted I had a bit trouble last time trying to get it straight and in line! I measured and put bits of masking tape on the outside to give me somewhere to aim at when putting the decal on the inside. Good egg - will give it a go when the weather decides to be dry, then!
ud-uk
Hope everyone is keeping busy with their cars, it will soon be show season again.
Just a quick note to say I'm still making these Backflashes, there is a large selection in my eBay shop, if you search for my seller id - mtgraphicsandover - or I can make them bespoke for you.
All the best. Mark
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
Could you do one for the mk2 Escort? But i would like (if at all Possible), VAUD Or even VAUD ESCORT Thank you.
voodoo57
I don't like Ebay......
ud-uk
Could you do one for the mk2 Escort? But i would like (if at all Possible), VAUD Or even VAUD ESCORT Thank you. Yes that's no problem to do that, I think VAUD ESCORT might be to may letters to fit, but I'll check tomorrow when I'm at work and see how it looks.
voodoo57
Yep, Vaud would be fine, cheers, chat soon.
ud-uk
Yep, Vaud would be fine, cheers, chat soon. Here is both options, let me know what you like.
voodoo57
Great! Vaud Escort please, just one other Q' does it have to be Red? and how much in total anyway including U.K postage, Thanks again, I like this A LOT!
