stefan
If it isn't broken fix it till it is
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
stefan
Well engine craned into place, its tight!!!! and the rack will have to be moved forward and down! water pump clears the front of the suspension tower need a smaller oil filter (cosworth one should fit and I am told it is alot smaller front on gearbox shows how far forward it has had to move The A piller will not be to bad as these tyres are alot higher profile than the slicks. Hope to have the car out for a few rounds this year but that depends on time and funds.
rtlkyuubi
Low and Slow
Looking good matey! but how the feck can you work in that garage! give it a sweep! hahaha
stefan
It does need a bit of a shovel out I have to admit
its same as ohc so if cossy is shorter then should fit
theres more to life than mpg & to much power is just enough.
stefan
I am told the cossy is shorter so will have to have a look and find out.
stefan
Gearbox mount made up and welded in place, engine moved forward 8" to meet the regs.
tomorrow I will hopfully make up some engine mounts so I can remove the engine crane and mount the steering rack
luckygti
I need to try harder!
That is epic Really coming on now, looks spot on sitting on that chassis. What are the engine plans? Keeping it pretty standard?
stefan
Engine spec has to be pretty standard to meet the classic modifieds rules. www.classicmodifieds.co.ukI can run a tubular exhaust, mild cam and air filter but that is all.
luckygti
Ooh, Swaffham. That can't be that far from me and this looks like properly good racing. Might have to make an effort to get up to this.
stefan
Yes mate alot closer to you than me
stefan
Apr 16, 2011 20:21:50 GMT
Well engine is now in, bit higher than I would like bit then it had to go forward more than I would have liked Still have space for the rad, just. Not doing much to it at the moment as I have 90m2 of block paving to lay on the patio
stefan
Apr 17, 2011 16:59:39 GMT
That's gonna look awesome on those wheels. Loads of room to drop that alternator by the looks.
Matt
Mad Max
North West
May contain beard...
Apr 17, 2011 21:21:59 GMT
Ive long liked these, never driven one but always wanted to. This is going to be something very special! Cant wait to see its full awesomeness. Those wheels are fablong!
stefan
Apr 18, 2011 18:36:10 GMT
Is seems that later SE6 calipers and smaller discs will solve the clearence problems with 13" wheels
laks
Jul 29, 2011 22:21:09 GMT
any progress on this awesome racer?
Mamba
Jul 29, 2011 22:50:59 GMT
That's one way of using a Scimitar chassis and a DAF shell. Should handle very well and take off fairly well. Can'#t wait to see her done, she'll definitely look the part mate!!
[url=http://retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=105579 ]1975 Scimitar SE5a "Kato"[/url] 1978 Scimitar SE6a "Mamba" 1969 Land Rover Airportable "Summer"
stefan
Nov 26, 2011 20:47:27 GMT
Well no pictures yet but have moved the engine back as now allowed in the revised rules for scimitar chassis and made the prop shaft.
Trimed the rear arches some more as well as they were catching on the rear slicks
stefan
Nov 29, 2011 21:15:47 GMT
