Frankenhealey
Club RR Member Number: 15
So, had a mount given way, or is it just the springs settling and the clearance disappearing? Originally to jiggle the whole bl00dy thing about we used elongated holes on the custom engine mounts so the most likely thing is that the mounts have moved. The front spring packs are huge and there is no discernible difference between loaded and unloaded with the Healey on top. Before you start your Austin I'd make a cardboard Cummins engine replica and check it fits the hole. I was talking to a chap yesterday who was converting an AWD RL, so it's the same layout, and he's had to open up the cockpit and make a new engine cover. I definitely don't want to do that.
glenanderson
Club RR Member Number: 64
Aug 16, 2019 10:06:33 GMT
Don’t worry, there’ll be plenty of mocking-up before I do anything irreversible. 😃 I’m quite lucky in that I’m replacing a 5.1 litre 6-cyl diesel which was available in a 5.7 variant, with a 5.9 6-cyl that’s actually fractionally smaller and lighter, and the sump configuration etc. is the same. My issue will be in getting all the ancillaries in without altering the external silhouette. I’m not bothered about it intruding into the cab a little more, although it shouldn’t, because unlike the goddess, most of the original engine/gearbox is either under the floorboards or out in the snout. I do foresee some convoluted plumbing though, particularly if I can’t get the radiator/intercooler pack infront of the Cummins without modifying the bonnet.
Frankenhealey
Sept 2, 2019 11:50:10 GMT
Leedle bit of work on the old girl this weekend. Got the tilt off for the bows to go to Weldtec for a 100mm extension so the cab roof and the tilt finally line up after the cab lift. At the same time we're going to have 2 more longitudinal roof bars retro fitted, one each side, to reduce the puddling on top of the tilt. My cunning plan #23179 of using webbing was an improvement but not wholly successful see below Having ascertained that it was the gearbox mounts that had moved we didn't need to move her on to hardstanding so we could use my patented 'Log/stump riser' system to get a 5 ton bottle jack to the right height. The problem was that the 63 year old original gearbox mounts had collapsed! Who'd have guessed that? Me of course, but hindsight is 20-20 vision. A new design was mocked up with the help of a pencil and a piece of cardboard and should be ready for next weekend. The NEC is only 9 weeks away. Time to panic!
Sept 2, 2019 12:35:59 GMT
I hate to ask, but is that Elastoplast on the exhaust?
Frankenhealey
Sept 2, 2019 12:53:41 GMT
I hate to ask, but is that Elastoplast on the exhaust? It's an exhaust bandage. We're going to make up a new system but as this year was all about shakedown/shakeapart runs it would have been daft in case stuff had to be moved.
Sept 2, 2019 13:05:51 GMT
Sorry Just looked like the stuff you used to buy at Boots the chemist fot doin' knees and similar. Note, as a northern lad, that's pronounced Bootses the chemist.
Last Edit: Sept 2, 2019 13:06:23 GMT by georgeb
Frankenhealey
Sept 2, 2019 14:09:14 GMT
Note, as a northern lad, that's pronounced Bootses the chemist. Aye lad, I remembers it well. My miner Granddad had a pitman's terrace 'cottage' at the back o' the Bootses factory in Beeston. You know, long row, 2 up / 2 down with the crapper down the little garden past the little beds of leeks that grew so well in the sooty, damp ground for some reason. When I stayed I had to sleep on an old sofa in the back parlour and he always said that if I got caught short at night, because they didn't have a second chamberpot, just climb up the kitchen chair and go in the sink rather than creep in the dark to the little brick outhouse. What you don't do is creep upstairs at 3am and wake your snoring granddad with the phrase ' Granddad I did what you said but do you have any toilet paper?'. I was not the favourite grandchild for a while. I was well acquainted with Bootses bandages as being a rather solitary child (and an effete southerner to boot when on my northern holidays) some rough boys pushed me into Bulwell Bogs for a laugh. At the time this was a section of industrial river with turgid water, sucking ooze and a fine selection of discarded housewares and old bikes. I managed to twist out of the way of the ooze, hoping to land in the water, but instead hit the side of my head on an old bedstead. You know what head wounds bleed like and I had to walk half a mile, sopping wet and bleeding like a stuck pig back to Granddads. The rough boys had legged it as soon a my head appeared over the side of the river bank. As soon as he saw me Granddad wrapped my head in one of his old vests, not thank God his old pants (I'd seen those) and carried me to the doctors. Child bleeding to death gets you to see the doctor pretty sharpish, a quick swab, flush with iodine, 12 stitches and a turban of Bootses bandage. Back to Granddads, put to bed on the sofa, no painkillers except for an aspirin before sleep but I was allowed to listen to what I wanted on the radio for the first time ever and he bought me a Beano. I had a mild notoriety with the local kids for a short while, asking to see the stitches and commenting on my bright purple ear from the iodine. A week later I went home down south and all that came about from it was the conviction of my friends that it really was grim 'oop north and an interesting scar. Sometimes as my hair thins someone new will mention it and I just tell them that I had to have my tonsils out the hard way. Kid's today don't know how easy they have it!
jamesd1972
Club RR Member Number: 40
Sept 2, 2019 14:27:32 GMT
Sorry Just looked like the stuff you used to buy at Boots the chemist fot doin' knees and similar. Note, as a northern lad, that's pronounced Bootses the chemist. What the self adhesive stuff that reacts with skin on 9/10 people so it looks like there is a raw red version of it still still there even after the waxing removal process ? Nasty stuff, have no doubt it would hold an exhaust together ! James
samta22
Stuck in once more...
Club RR Member Number: 32
Sept 2, 2019 15:32:50 GMT
I agree, almost indestructible stuff. Having been patched up with it more times than I care to remember by my gran, I can even smell it sat here thinking about it...
Sept 2, 2019 16:37:55 GMT
Note, as a northern lad, that's pronounced Bootses the chemist. Aye lad, I remembers it well. My miner Granddad had a pitman's terrace 'cottage' at the back o' the Bootses factory in Beeston. You know, long row, 2 up / 2 down with the crapper down the little garden past the little beds of leeks that grew so well in the sooty, damp ground for some reason. When I stayed I had to sleep on an old sofa in the back parlour and he always said that if I got caught short at night, because they didn't have a second chamberpot, just climb up the kitchen chair and go in the sink rather than creep in the dark to the little brick outhouse. What you don't do is creep upstairs at 3am and wake your snoring granddad with the phrase ' Granddad I did what you said but do you have any toilet paper?'. I was not the favourite grandchild for a while. That made me giggle....
Sept 4, 2019 13:29:32 GMT
just climb up the kitchen chair and go in the sink rather than creep in the dark to the little brick outhouse. What you don't do is creep upstairs at 3am and wake your snoring granddad with the phrase of course, you wer lucky to 'av a sink. if we got caught short we had to pish in the glass on nans bedside table. she never did work out why her steradent kept going green.
Last Edit: Sept 4, 2019 13:29:52 GMT by darrenh
Frankenhealey
Sept 4, 2019 14:06:31 GMT
just climb up the kitchen chair and go in the sink rather than creep in the dark to the little brick outhouse. What you don't do is creep upstairs at 3am and wake your snoring granddad with the phrase of course, you wer lucky to 'av a sink. if we got caught short we had to pish in the glass on nans bedside table. she never did work out why her steradent kept going green. We didn't 'av a sink that was my Granddad. Ooooh that would've been LOOOOOXURY in our 'ole the the road with a cardboard box over it
Frankenhealey
Sept 11, 2019 14:11:28 GMT
Another part has arrived for the air system Off to the pneumatics place later in the week for the rest of the parts. It's so nice to have a bl00dy big engine compressor available for the air supply.
Sept 11, 2019 18:39:20 GMT
That's a neat gauge. I'd think it also be useful for "What you got in the system" versus "what it's set to".
--Phil
Frankenhealey
Sept 11, 2019 18:52:15 GMT
That's a neat gauge. I'd think it also be useful for "What you got in the system" versus "what it's set to". --Phil Yes, it's got twin needles so I can see what's in the front and back set. Or if I was crazy and fast enough I could make them left and right and set up for corners on the fly Anybody know if 1/4 inch and 6mm hose is interchangeable?
Sept 11, 2019 19:10:57 GMT
6mm is close to 1/4 but if your ferrules aren't designed for it they may not clamp 6mm externally as it's slight undersize.
You need height activated valves on the bags- as it sinks it opens up and then exhausts as it raises over limit
Not quite Citroen but still. And now, with an air system, you need an air seat. You need one. Neeeeed.
--Phil
Last Edit: Sept 11, 2019 19:12:26 GMT by PhilA
Phil H
Club RR Member Number: 133
Sept 11, 2019 19:56:53 GMT
Anybody know if 1/4 inch and 6mm hose is interchangeable? Not where push in fittings are concerned, no. Adaptors to go from one to the other are off the shelf though.
glenanderson
Sept 11, 2019 20:46:49 GMT
I don’t know about the goddesses, but the Bedford S type they’re based on has nowhere near enough physical space beneath the seats for an air suspension mechanism.
Frankenhealey
Sept 11, 2019 21:34:15 GMT
I looked at air seats but there was two problems, height and the strength of the floor. Also it wouldn't look very 'classic'
Sept 11, 2019 21:49:11 GMT
I looked at air seats but there was two problems, height and the strength of the floor. Also it wouldn't look very 'classic' Eat beans, as well as air suspension it has a heating element.
74 Mk1 Escort 1360, 1971 Vauxhall Victor SL2000 Estate.
